IAP code, unable to jump on user application for LPC11UXX(Cortex M0)
mayd
HI,
As i am trying to write IAP for firmware upgradation on LPC11UXX, found difficulty in jumping to the new user application.As there is no VTOR register is available (for Cortex-M0), trying with SYSMEMREMAP register (for remap Vector table). Though it is not working fine.
Carlos_Mendoza
Hi Mayur,
I think that the following application note might be helpful for you, it explains the In-Application Programming capabilities of the LPC11U6X and also provides guidance to interrupt handling during flash IAP calls:
http://cache.nxp.com/documents/application_note/AN11511.zip
Let me know if it helps!
Carlos Mendoza
Technical Support Engineer
