TJA1100 pin4&16 ; C26 & C28
jerrry
Hi community .
I have a question about the TJA1100. Im searching for the use of the two capacitors C26 & C28 shown in the schematic at the end of TR1329.pdf. I ooked up TJA1100.pdf too, but didn't get any answer. It's about the pins 4 & 16. These two pins are for the VDDA(1V8) and VDDD(1V8) and are generated by LDO internally. So what are the two capacitors  C26 & C28 shown in TR1329.pdf for?
Am I right with my guess that they are just for stabilization?
If you have any other helpfull documents refered to the TJA1100 please let me now.
Thanks in advance.
Jerrry
TomasVaverka
Hi Jerome,
Those capacitors are needed for external buffering of the LDO to stabilize the voltage.
Attached you can find the application hints for TJA1100 for your reference.
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct". Thank you.
TomasVaverka
Hi Jerome,
Tomas
jerrry
Hi Tomas,
thank you for your response and your attachment.
This helps me alot.
Jérôme
