License check failed: License server system does not support this feature.
hpyovo
I want to use command tool which in cw_mpc5xxx_2.10\PowerPC_EABI_Tools\Command_Line_Tools\,but i find the linker license is failed,more info is below:
D:\Freescale\cw_mpc5xxx_2.10\PowerPC_EABI_Tools\Command_Line_Tools>mwasmeppc -fu
llLicenseSearch
### mwasmeppc Usage Error:
#   Nothing to do:  no source or object files specified
Errors caused tool to abort.
D:\Freescale\cw_mpc5xxx_2.10\PowerPC_EABI_Tools\Command_Line_Tools>mwcceppc -ful
lLicenseSearch
### mwcceppc Usage Error:
D:\Freescale\cw_mpc5xxx_2.10\PowerPC_EABI_Tools\Command_Line_Tools>mwldeppc -ful
lLicenseSearch
### mwldeppc Driver Error:
#   License check failed: License server system does not support this feature.
#   Feature:       Win32_Plugins_Link_PPC
#   License path:  D:\Freescale\cw_mpc5xxx_2.10\Bin\..\license.dat;
#   FLEXnet Licensing error:-18,147
#   For further information, refer to the FLEXnet Licensing documentation,
#   available at "www.macrovision.com".
The mwasmeppc and mwcceppc license is ok,but mwldeppc license failed, why?
I use LMTools Utility  Diagnostic Feature Win32_Plugins_Link_PPC, I got messege below:
License file: D:\Freescale\cw_mpc5xxx_2.10\license.dat
"Win32_Plugins_Link_PPC" v8, vendor: metrowks
  License server: hpyovo-PC
  floating license no expiration date
  TS_OK: Checkout permitted when client is using terminal client
  Requests from the same USER/HOST do not consume a new license
This license can be checked out
License file: D:\Freescale\cw_mpc5xxx_2.10\PowerPC_EABI_Tools\Command_Line_Tools\license.dat
No licenses for Win32_Plugins_Link_PPC in this license file
Anyone can help me, how do i fix the problem?
jorge_plascencia
Hi liu zq,
Sounds like they did not get a linker license increment in their license.dat file.  Please add this increment to the license.dat file:
INCREMENT Win32_Plugins_Link_PPC metrowks 8.000 30-may-2020 uncounted \
F41E210428AF VENDOR_STRING="PPC linker" HOSTID=ANY \
ISSUER="Freescale Semiconductor" ISSUED=17-apr-2012 NOTICE=N/A \
SN=N/A START=2-jan-2012 TS_OK
Should that not solve the issue, please submit a support request to the license team.
jorge_plascencia
Hi liu zq,
Duewee
Dear Jorge,
In the past I've successfully used the extension to my license.dat file below. However, I've noticed that this patch is not working anymore. The key seems to be expired since May 2020.
Can you provide me with an updated extension to my license file?
hpyovo
Hi  jorge_plascencia,
I get the same wrong with your increment . I diagnostics the Win32_Plugins_Link_PPC,and i get the result below.
I use command line,  the license still check failed such as below:
lLicenseSearch
      1. mwldeppc Driver Error:
  1. License check failed: License server system does not support this feature.
  1. Feature: Win32_Plugins_Link_PPC
  1. License path: D:\Freescale\cw_mpc5xxx_2.10\Bin\..\license.dat ;
  1. FLEXnet Licensing error:-18,147
  1. For further information, refer to the FLEXnet Licensing documentation,
  1. available at "www.macrovision.com".
[email protected]
 From: jorge_plascenciaDate: 2016-06-14 03:41To: liu zqSubject: Re: - License check failed: License server system does not support this feature.
NXP Community
reply from jorge_plascencia in CodeWarrior Licensing - View the full discussion
Hi liu zq, Sounds like they did not get a linker license increment in their license.dat file.  Please add this increment to the license.dat file:  INCREMENT Win32_Plugins_Link_PPC metrowks 8.000 30-may-2020 uncounted \ F41E210428AF VENDOR_STRING="PPC linker" HOSTID=ANY \ ISSUER="Freescale Semiconductor" ISSUED=17-apr-2012 NOTICE=N/A \ SN=N/A START=2-jan-2012 TS_OK Should that not solve the issue, please submit a support request to the license team. Regards,
Reply to this message by replying to this email, or go to the message on NXP Community
Start a new discussion in CodeWarrior Licensing by email or at NXP Community
Following License check failed: License server system does not support this feature. in these streams:
Inbox
This email was sent by NXP Community because you are a registered user.
You may unsubscribe instantly from NXP Community, or adjust email frequency in your email preferences
