Build System Derived Toolchain:
1,972 次查看
1990rahulreddy
I have install cross tollchain using SDK, but, when I start ecplise, it showing nothing in "Target Architecture",
also, I am confuse in Toolchain root location & sysroot location.
I have install toolchain in /opt/fsl-imx-x11/3.14.52-1.1.0/
标签 (3)
5 回复数
1,660 次查看
aravinthkumarja
Senior Contributor II
Hi RahulReddy
Toolchain location --> Cross compiler path
sysroot location --> Filesystem path
You should specify both location properly, Then it will work. I hope it will help full for you.
Aravinth
1,660 次查看
1990rahulreddy
I am able to get it in "Standalone", but not in "Build System "
1,661 次查看
aravinthkumarja
Hi RahulReddy
Can you elaborate your issue, Exactly issue i didn't get.
Aravinth
1,661 次查看
1990rahulreddy
I have created new thread, please give solution..
object detection using haarcascade
1,661 次查看
gusarambula
I'm just adding the information marked as an answer from the new thread for completeness:
Building OpenCV on ubuntu hardfloat rootfs for i.MX6Q
