Where is the documentation or examples for the Shell included in the KSDK 1.3 created by the KSDK Builder
已解决
跳至解决方案
1,757 次查看
tomtalkington
the Shell is included in the utilities folder but I cannot find any documentation or examples for it.  Are any available?
标签 (1)
1 解答
1,369 次查看
ivadorazinova
Hi Tom.
Unfortunately no. No other example and documentation are not available.
Have a nice day.
Iva
在原帖中查看解决方案
3 回复数
1,369 次查看
tomtalkington
I made the decision to move away from MQX as it will no longer be supported so I only included FreeRTOS in my SDK build. Going back to MQX would defeat the purpose of this exercise.  My project was working with MQX and its included shell.  My goal is to port to KSDK 1.3 with FreeRTOS.
My SDK includes a shell which is different from the one used with MQX. Is there any documentation of example code for this shell?
1,370 次查看
ivadorazinova
Hi Tom.
Have a nice day.
Iva
1,369 次查看
ivadorazinova
Hi Tom.
It depends, what option you choose in Kinetis Expert.
If you want to work with Shell, you must choose MQX option
after that you will see under middleware rtcs folder:
You can find Shell example under <KSDK1.3_path>\middleware\tcpip\rtcs\examples\shell
The Readme to RTCS Shell Application you will find in the same folder.
Documentation for the Shell - MQX RTOS RTCS User's Guide (IPv4 and IPv6) you will find at <KSDK1.3_path>\doc\tcpip\mqx_rtcs
I hope this helps you.
In case of any issue, please let me know.
Iva
