the error of IDES32 Design Studio for ARM v1.1 - Windows  installation fail
enwei
I recently downloaded the newly released IDES32 Design Studio for ARM v1.1 - Windows  from website: S32 Design Studio IDE|NXP;
I'd like to try the new IDE for S32K and KEA SW development.
But I got the license activation request, and whether I choose online(of course, my internet is OK) or offline with the Activation ID the system sent to me by e-mail when I download it, I will got the following error with online activate:
and offline activate generate a request file(named request.xml) as attached and request respone as below window:
and then the installation will be rolled back and failed.
so I wonder:
  1. why the IDE need license? is it a free software?
  2. how can I activate my license and get the IDE installed on my computer?
I also attached the installation log for your reference.
please help, thanks a lot~!
Best regard,
Enwei Hu.
Original Attachment has been moved to: request.xml.zip
Original Attachment has been moved to: S32_Design_Studio_for_ARM_v1.1_Install_02_14_2016_23_49_25.log.zip
Original Attachment has been moved to: S32_Design_Studio_for_ARM_v1.1_Install_02_14_2016_23_34_11.log.zip
TomasPaez
Can you please mention if offline action is working on your side?
regards
fergusmccracken
Hi Tomas,
Sorry about the delay replying, I got pulled into another project and only back to this today.
I currently have your temp activation ID working, however my activation ID still does not work.
When I open S32 and go to help/Freescale Licenses i see the following (this is the temp license):
However, when I return the temp license and enter my own it waits for a send, then closes the license dialog and shows this:
This happens whether I use online or offline activation methods.
I am continuing to use the temp license you provided, but I would be very appreciative if you are able to help me work through this issue.
Also, I tried to PM you my request and activation files, however I don't have your email address and i'm not able to message you through the NXP community website unless you 'follow' me first.
Many Thanks,
Fergus
stanish
Hi Fergus,
Could you possibly give a one more try? I made an adjustments on your account on the licensing server.
I'm pretty confident it should work now.
BTW: have you tried to activate S32DS using your original Activation ID on the same machine or you've tried on more then one computer?
Thanks!
Stan
jianlongzhang
Hi Tomas,
Yes. I tried again, both online and offline are OK now. Thank you very much.
BR, Jianlong
TomasPaez
Please send me your entitlement IDs
Go to order history and look for the entitlement ID, must be named S32DS-IDE-ARM_XXXXX
I would like to see your request.xml and reponse.xml files
One question , do you have previous 1.1 version installed on this machine?
run a test using this temp activation ID as test, thank you.
37D6-B186-B306-B6AA
thank you
fergusmccracken
Hi Tomas,
My Entitlement ID is S32DS-IDE-ARM_88583937.
The request/activation xml files seems to contain information specific to my account and computer, is there a way to private message these to you rather than posting them on the public forum?
It still failed for me with my original code when I tried again yesterday. However I tried with your temp activation ID and it seemed to work fine (i cancelled the installation before it could complete). Unfortunately your temp activation code now seems to be installed on my computer. When I run the installation again it now seems to find your activation code by automatically and doesn't ask me for my code anymore - is there a way I can change the activation code once S32 is already installed?
Fergus
stanish
Hello Fergus,
Yes you can activate or return actiation directly in S32DS IDE:
go to Menu Help -> Freescale Licenses:
Click open:
Return license.
you can activate it back easily by pasting the activation code into "Activation ID" entry and click on "Activate"
Stan
jianlongzhang
Hi Tomas,
I tried this morning, using my activation code. And it works now. I think the problem failed yesterday may be server time out. Highly appreciate your help and support!
B.R.
Jianlong Zhang
martin_kovar
I tried to replicate your problem, but everything works correct. I chose online registration and I did not receive any error. It is possible that activation server has some outage. Please try install once more and make sure you enter correct Software Activation Code during installation. You find your software activation code at the email, which you used during registration.
Martin
enwei
Hi Martin,
In fact, I have tried several times in differernt time and on deferent computers(at least another 2 PCs), as my install log listed:
I always got the same error as above mentioned, FNP error 50041: Failed to connect to the license server or operations sever.
the install log shows more info:
Installation: Unsuccessful.
21 Successes
5 Warnings
1 NonFatalErrors
1 FatalErrors
Action Notes:
None
Install Log Detail:
Check Disk Space:         C:\Freescale\S32__v1.1
                          Status: SUCCESSFUL
                          Additional Notes: NOTE - Required Disk Space: 1,627,787,818; Free Disk Space: 47,385,763,840
Install Directory:        C:\Users\B46398\AppData\Local\Temp\313305.tmp\
                          Status: SUCCESSFUL
                          Additional Notes: NOTE - Directory already existed
Install File:             C:\Users\B46398\AppData\Local\Temp\313305.tmp\vcredist_2013_x86.exe
                          Status: SUCCESSFUL
Expand Archive:           C:\Users\B46398\AppData\Local\Temp\313305.tmp\vcredist.zip
                          Status: SUCCESSFUL
Execute Command:          C:\Users\B46398\AppData\Local\Temp\313305.tmp\vcredist_2013_x86.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\B46398\AppData\Local\Temp\313305.tmp\FNPLicensingService\FNPLicensingService
                          Status: SUCCESSFUL
Install File:             C:\Users\B46398\AppData\Local\Temp\313305.tmp\install_fnp.sh
                          Status: SUCCESSFUL
Install File:             C:\Users\B46398\AppData\Local\Temp\313305.tmp\license.jar
                          Status: SUCCESSFUL
Expand Archive:           C:\Users\B46398\AppData\Local\Temp\313305.tmp\Activation.zip
                          Status: SUCCESSFUL
Execute Command:          java -jar C:\Users\B46398\AppData\Local\Temp\313305.tmp\license.jar install -prod S32DS-IDE-ARM_v1.1
                          Status: SUCCESSFUL
Execute Command:          java -jar C:\Users\B46398\AppData\Local\Temp\313305.tmp\license.jar verify -feature Activated -version 1.1 -prod S32DS-IDE-ARM_v1.1
                          Status: SUCCESSFUL
Execute Command:          java -jar C:\Users\B46398\AppData\Local\Temp\313305.tmp\license.jar activateUI -testFNO false
                          Status: SUCCESSFUL
                          Status: SUCCESSFUL
Install Uninstaller:      S32 Design Studio for ARM v1.1(Install All Uninstaller Components)
                          Status: SUCCESSFUL
Install Directory:        C:\Freescale\S32_ARM_v1.1\_S32 Design Studio for ARM v1.1_installation\resource\
                          Status: SUCCESSFUL
Install File:             C:\Freescale\S32_ARM_v1.1\_S32 Design Studio for ARM v1.1_installation\resource\iawin32.dll
                          Status: SUCCESSFUL
Install File:             C:\Freescale\S32_ARM_v1.1\_S32 Design Studio for ARM v1.1_installation\resource\remove.exe
                          Status: SUCCESSFUL
Install File:             C:\Freescale\S32_ARM_v1.1\_S32 Design Studio for ARM v1.1_installation\resource\invoker.exe
                          Status: SUCCESSFUL
                          Status: ERROR
                          Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Uninstall File:           C:\Users\B46398\AppData\Local\Temp\313305.tmp\vcredist_2013_x86.exe
                          Status: WARNING
                          Additional Notes: WARNING - The file does not exist
Uninstall File:           C:\Users\B46398\AppData\Local\Temp\313305.tmp\FNPLicensingService\FNPLicensingService
                          Status: WARNING
Uninstall File:           C:\Users\B46398\AppData\Local\Temp\313305.tmp\install_fnp.sh
                          Status: WARNING
Uninstall File:           C:\Users\B46398\AppData\Local\Temp\313305.tmp\license.jar
                          Status: WARNING
Uninstall Folder:         C:\Users\B46398\AppData\Local\Temp\313305.tmp\FNPLicensingService
                          Status: WARNING
                          Additional Notes: WARNING - The path does not exist
Remove Registry Entry:    5 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\null
                          Status: SUCCESSFUL
Error occurred while installing the following Action, hence rolling back the installation....!
Action Name:              Trigger Rollback Action
Action Description:       Trigger Rollback Action
Error Details as below:
This action rolls back the Installation.
https___community.freescale.com_servlet_JiveServlet_downloadImage_2-614150-140990_S32DS+for+ARM+v1.1+install+error.jpg
please help to give me some suggestions, thanks~!
stanish
Hello Enwei,
Thanks for your question.
This is a known issue and it will be fixed in the next release.
It's caused by the fact that Windows users may have spaces and special characters in their names, e.g. “Johnny Depp” or “Phocée” that affect things.
Workaround:
1) Create an empty folder, e.g. “c:\temp”
2) Type “rundll32 sysdm.cpl,EditEnvironmentVariables” and set TMP variable from its default “%USERPROFILE%\AppData\Local\Temp” to that folder name “c:\temp”
3) Ensure that your changes accepted – now “set TMP” should return “TMP=c:\temp”
4) Install S32DS
Hope it helps!
Stan.
jianlongzhang
Hi Stan,
I have a similar issue as Fergus. I failed installing S32DS for ARM v1.2 today. The install tool asked for activation code of v1.1 and I entered code under my account (the code is for v1.2 ?). It rolled back and failed. Does anything I should do? Thank you very much.
BR, Jianlong Zhang
TomasPaez
I was able to test your ID, with successful results, could you test again now , I have reset the IDs,  and I expect now to be working.
Thank you
jianlongzhang
Hi Tomas,
Thank you for your checking. I tried just now, but maybe because of sever's timeout (for both online and offline), I failed with below reasons. I will try to install later, hope it will work. Thank you.
BR, Jianlong
fergusmccracken
Hi Tomas,
Thanks for your response! Unfortunately I still get exactly the same behavior as before:
and then it says Rolling Back Install:
I also tried the offline activation method with exactly the same results.
Fergus
fergusmccracken
Hi Stan,
I'm experiencing a similar issue to what described above while installing "S32 Design Studio for ARM v1.2 - Windows.exe" on windows 10. The Activation code works correctly and says that the code is accepted, however it then proceeds to immediately roll back the install. The error in Enwei Hu's logs look identical to the errors in mine.
I tried your solution by changing the temp directory environment variable and it still failed with the same error.
Is there anything else I can try?
I've attached the installation log below.
Many Thanks,
Fergus
enwei
I want to know how the install to get the license activation verfication, vis FNPLicensingService.exe, how does it work?
whether it has something with my computer's windows firewall, will it block the FNPLicensingService.exe, how can I fix it?
thanks~!
