Can't generate Key for CW. Get message...
JackAbbott
The call to lmcrypt failed.
Tried to invoke method public java.lang.String GenerateLMCryptLicense.generate(java.lang.String,java.lang.String) throws java.lang.Exception with arguments java.lang.String,java.lang.String. The arguments do not match the signature.; nested exception is: java.lang.IllegalArgumentException: java.lang.ClassCastException@1cdd76a
trytohelp
Hi Jack,
Following feedback received by other customer the problem has been solved.
Pascal
NXP Technical Support
trytohelp
Hello Jack,
Similar to Lmcrypt error when generation CW key
As you can see I've performed several tests on my side  and it's working.
Can you try again ?
Pascal
