Could not open egl display
强王
Qt5_CinematicExperience -platform eglfs
result:
QEglFSImx6Hooks will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
then i set FB_MULTI_BUFFER=2 or QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
result:
root@imx6qsabresd:~# Qt5_CinematicExperience -platform eglfs
/usr/bin/Qt5_CinematicExperience: line 4:   432 Aborted                 /usr/share/cinematicexperience-1.0/Qt5_CinematicExperience $*
kernel:3.14.28
Labels (4)
Bio_TICFSL
Hi Qiang
Did you try export DISPLAY ?
refiktuzaklı
I have also this problem. I exported Display and applied Andrey's recommendation. it still gives same error could not open display
andreykononov
can you show full error log?
i make some changes to unify my scripts
#!/bin/sh
fb=/dev/fb$1
export QT_QPA_FONTDIR=/usr/share/fonts/
export QT_QPA_EGLFS_FORCEVSYNC=1
export QT_QPA_EGLFS_HIDECURSOR=1
export QT_QPA_EGLFS_FB=$fb
export FB_FRAMEBUFFER_0=$fb
export QT_QPA_PLATFORM=eglfs
export LANG=ru_RU.UTF-8
/path/to/program
now to start program on some display you can set framebuffer number
script.sh 2 &
refiktuzaklı
before your script
QEglFSVivIntegration will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
Aborted
after yourscript
Aborted
andreykononov
which framebuffer you using?
refiktuzaklı
I have check my frame buffer. I have just fb0. I changed fb=/dev/fb$1  with fb=/dev/fb$0 and error :
EGLFS: Failed to open /dev/fb-sh
EGLFS: Can't continue without a display
Aborted
andreykononov
for you my script whill be
#!/bin/sh
fb=/dev/fb0
/path/to/program
show output of this command
cat /sys/class/graphics/fb0/mode
refiktuzaklı
same error
Aborted
mode file is empty
andreykononov
its look like something wrong with your framebuffer driver. What board are you using and what linux on it?
refiktuzaklı
linux 4.11.4
board karo tx6u 8033
refiktuzaklı
can you show tree under /usr/lib/qt/plugins/egldeviceintegrations
mine is
# cd /usr/lib/qt/plugins/egldeviceintegrations
# tree
|-- libqeglfs-kms-egldevice-integration.so
`-- libqeglfs-kms-integration.so
0 directories, 2 files
must there be a libqeglfs_viv something like that? do I have missing file here?
andreykononov
root@MMC:~# tree /usr/lib/qt5/plugins/egldeviceintegrations/
`-- libqeglfs-viv-integration.so
0 directories, 1 file
root@MMC:~#
refiktuzaklı
I am using buildroot, I select imx-gpu-viv and qt5 egl support. however egl vivante integration is missing. I gues there is bug on integration of vivante for buildroot.
thank you Andrey
andreykononov
i'm using yocto, you can try it
refiktuzaklı
which board do you use? mine is karo
andreykononov
refiktuzaklı
yes I want to switch to yocto too, because imx does not support buildroot also buildroot community is not so wide as yocto. do you have any suggestion where to start?
andreykononov
i think better way to start from here, but take pyro branch, not dora like on this link, other the same
aveselinov
OP, could u please explain ur solution? Exporting DISPLAY doesn't work for me.
andreykononov
#!/bin/sh
export QT_QPA_EGLFS_FB=/dev/fb0
export FB_FRAMEBUFFER_0=/dev/fb0
/home/root/program &
work for me now
andreykononov
i have the same error, build yocto image jethro + Qt make start script
root@imx6qsabreauto:~# cat /bin/start.sh
#!/bin/sh
export LD_LIBRARY_PATH=/usr/lib
export QML_IMPORT_PATH=/usr/lib/qt5/qml
export QML2_IMPORT_PATH=/usr/lib/qt5/qml
export QT_QPA_PLATFORM_PLUGIN_PATH=/lib/qt5/plugins/platforms
export QT_QPA_EGLFS_PHYSICAL_WIDTH=1920
export QT_QPA_EGLFS_PHYSICAL_HEIGTH=1080
#export QT_QPA_EGLFS_FB=/dev/fb2
#export FB_FRAMEBUFFER_0=/dev/fb2
export DISPLAY=:0.0
and still have same error
root@imx6qsabreauto:~# start.sh
/bin/start.sh: line 12:   458 Aborted                Qt5_CinematicExperience
