Support for P2020processor Cryptodev
papaiahgovinda
Dear Support Team,
We have already enabled cryptodev in kernel configuration.
But after booting that kernel image we were unable to locate any "cryptodev".
Like other devices  cryptodev is not present if we use the command cat /proc/devices Even the RDB does not have the cryptodev module.
So, can please help us regarding this.
Thanks & regards,
Dhiraj
bpe
I'm not sure what you meant with "enabled cryptodev in kernel configuration". Cryptodev module is a separate package
named 'cryptodev-linux'. Build the package and proceed as described here:
Building OpenSSL with hardware offloading support
Linux cryptodev does not register itself within procfs, you will not see it anywhere under /proc/ therefore.
It, however, creates a /dev/crypto node.
If you meant Linux native crypto API driver for P2020 SEC (Talitos driver), study the document at the link
below on how to enable and test it:
SEC Device Driver User Manual
Note, cryptodev works on top of Talitos, so you will need Talitos anyway.
Platon
bpe
Platon
papaiahgovinda
Dear Platon,
Thank you very much your support.
We tried earlier same way described there but we tried
bitbake fsl-image-minimal
instead of bitbake fsl-image-core.
and whenever we tried to insert that cyptodev module it was showing syntax error.
Now according to the link sent by you, we followed the instruction and It is working fine.
Module is loded succesfully.
With warm regards,
Dhiraj
