How to use both sdhc0 and sdhc1?
jarodnan
I'm developing a custom board base on the VF610 tower board. I'm planning to use the sdhc0 with an eMMC (MTFC4GLDDQ-4M IT ) with 8 bit data lines as the boot media, and sdhc1 as an external SD storage. What modifications should I make to the u-boot and linux kernel source code?
And it is possible to use an SD card to boot a newly made boar to make the onboard eMMC bootable? Just set BOOT_CFG to SD boot?
Labels (2)
timesyssupport
Senior Contributor II
Custom hardware leveraging boot methods in this fashion are beyond what we are able to support in the general forums. Please contact [email protected] for dedicated engineering services to assist you.
Thank you,
Timesys Support
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ can you help with this case?
