IMX6SL/EINK,
MACHINE=imx6slevk source fsl-setup-release.sh -b build -e x11
bitbake fsl-image-qt5
root@imx6slevk:/usr/share/xcb# uname -r
3.14.28-1.0.0_ga+g91cf351
root@imx6slevk:/usr/share/xcb# export DISPLAY=:0.0
root@imx6slevk:/usr/share/xcb# Qt5_CinematicExperience
Qt Warning: Could not find a location of the system's Compose files. Consider setting the QTCOMPOSE environment variable.
libGL error: dlopen /usr/lib/dri/vivante_dri.so failed (libGL.so.1.2: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: vivante_dri.so
libGL error: failed to load driver: vivante
libpng warning: iCCP: known incorrect sRGB profile
^C
root@imx6slevk:/usr/share/xcb# Qt5_CinematicExperience --platform xcb
