set CCM_CLKO1 to 11.2896MHzMHz
强王
in 3.10.53 kernel:
CCM_CLKO1(audio i2s master)is 24MHZ ,   how to set to 11.2896MHzMHz
I change
imx_clk_set_rate(clk[pll4_audio_div], 541900800);
to
imx_clk_set_rate(clk[pll4_audio_div], 90316800); //8*11289600
question:
clk_get_rate(data->codec_clk) print the value is 11289600,
but the clock is still 22.5MHZ(11289600*2) by  oscilloscope
Labels (2)
saurabh206
Senior Contributor III
Qiang
What is your kernel version?
For Linux Kernel 3.0.35
you can refer arch\arm\mach-mx6\clock.c
clk_set_rate().
Saurabh
强王
in 3.10.53 kernel:
I change
to
question:
saurabh206
Hi Qiang
Which clock you are measuring MCLK or Bit clock? if it is bit clock (SSI clock) than output clock is divided based on DIV2, PSR and PM parameter configuration.
You can check
强王
HI Saurabh:
     Could you upload the document of this picture
saurabh206
Hi Qiang
Please refer "IMX6DQRM.pdf"
60.7.4 SSI Clocking
Saurabh
gusarambula
Thank you, Saurabh, for the help! I'm sure this information will help other users of the communities.
强王
HI Saurabh and gusarambula:
I don't quite understand this picture
Can you tell me the code after the modification
强王
HI Saurabh:
the board is imx6q sabresd
i  measure GPIO_0
