Unable to download fsl-gpu-sdk-2.0.bin
bricdesigns
I'm trying to do a clean build of 3.10.53, but bitbake dies on the task trying to download fsl-gpu-sdk-2.0.bin.
Here's the full error message:
WARNING: Failed to fetch URL http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//fsl-gpu-sdk-2.0.bin;fsl-eula=true, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 4, no output
ERROR: Function failed: Fetcher failure for URL: 'http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//fsl-gpu-sdk-2.0.bin;fsl-eula=true'. Unable to fetch URL from any source.
Any thoughts?
Labels (2)
Tags (2)
gusarambula
One possible workaround is to download the file directly from the URL and marked it as downloaded.
cd fsl-resealse-bsp
wget http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//fsl-gpu-sdk-2.0.bin
cp fsl-gpu-sdk-2.0.bin downloads/
touch downloads/fsl-gpu-sdk-2.0.bin.done
Then try building again.
