eMMC and SLC (enhanced) mode ?
jaakkokuivala
I'm on Linux 3.0.35 on a "standard" i.MX6Q SabreSD board and have an eMMC.
How do I change the eMMC to enhanced mode ?
Cheers, Jaakko
Danube
Hi Sir,
As I remember Micron eMMC has SLC mode function.
You can download document from  https://www.micron.com/-/media/documents/products/technical%20note/emmc/tn5205_emmc_linux_enablement...
If you enable SLC mode , you can't change to MLC mode. (Like OTP function)
Hi Jaakko
seems one can use special mmc utility, like below
i.MX6: eMMC hangs at mkfs "discard"
