Hello Pavel
I meet the same problem with you now.Did you solve it?
My board is IMX6Q-SDB.The mPCIE card is RTL8111e or RTL8111f.
(1)
root@freescale /app/net$ifconfig
eth0 Link encap:Ethernet HWaddr 00:04:9F:02:6E:25
inet addr:192.168.2.67 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:109724 errors:0 dropped:903 overruns:0 frame:0
TX packets:7501 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:17633802 (16.8 MiB) TX bytes:1108875 (1.0 MiB)
eth1 Link encap:Ethernet HWaddr 00:13:3B:0E:D1:10
inet addr:10.0.0.1 Bcast:10.255.255.255 Mask:255.0.0.0
RX packets:18112 errors:0 dropped:142 overruns:0 frame:0
TX packets:23 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1537208 (1.4 MiB) TX bytes:1494 (1.4 KiB)
Interrupt:155 Base address:0xe000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:14 errors:0 dropped:0 overruns:0 frame:0
TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1136 (1.1 KiB) TX bytes:1136 (1.1 KiB)
(2)
root@freescale /app/net$ ping 10.0.0.2
PING 10.0.0.2 (10.0.0.2): 56 data bytes
64 bytes from 10.0.0.2: seq=0 ttl=64 time=10.165 ms
64 bytes from 10.0.0.2: seq=1 ttl=64 time=0.230 ms
(3)
When I use the commad tftp ssh and iperf to test it ,all to be failure.
root@freescale /app/net$ ssh -v root@10.0.0.2
OpenSSH_4.3p2, OpenSSL 1.0.1c 10 May 2012
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Connecting to 10.0.0.2 [10.0.0.2] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug1: identity file /root/.ssh/identity type -1
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.3
debug1: match: OpenSSH_5.3 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_4.3
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
It stops here.
