TCP_Process_ack() unblocks RTCS_selectset() regardless of sockset
daido
I'm using MQX 4.0.2.2.
TCP_Process_ack() unblocks RTCS_selectset() regardless of sockset.
Undesired Scket handle is returned.
It was no such a thing until in MQX 4.0.1.
Already corrected in MQX 4.1.0 ?
Martin_
You're right, there is such problem. In sosel.c, function _SOCK_select_signal:
         /* check if sock is on the select waiting list (array) */
//         if (!flag)
            for (i = 0; i < parms->sock_count; i++)
                if (parms->sock_ptr[i] == sock)
                    break;
            if(i >= parms->sock_count)
                continue;
I think just comment out line 2 in the above code snippet should help.  (remove the !flag condition).
There will be a new BSD-like select() function in next MQX release. MQX 4.1.0 still has this problem.
Martin_
//         if (!flag)
                    break;
                continue;
