Linux build issue (L3.0.35_4.0.0)
keitanagashima
Senior Contributor I
Dear Sir or Madam,
Hello.
I couldn't build the Linux BSP (L3.0.35_4.0.0).
Board: MX6DL SABRE-SDP
BSP: L3.0.35_4.0.0
Host PC: Ubuntu 9.04
I referred to Setting_Up_LTIB_Host.pdf and i.MX_6Solo6DualLite_Sabre-SDP_Linux_User_Gudie.pdf
I tried this command : "./ltib -m config"
But, the build failed.
Refer to attached error log and please tell me advice.
Keita
Original Attachment has been moved to: host_config.log.zip
Tags (2)
keitanagashima
Dear All,
Thank you for your support.
Build succeeded!
I describe my procedure.
[Environment]
BSP: L3.0.35_4.0.0
Host PC: Ubuntu 12.04
Virtual Box: 4.2.10
[Install package for LTIB]
sudo aptitude -y install gettext libgtk2.0-dev rpm bison m4 libfreetype6-dev
sudo aptitude -y install libdbus-glib-1-dev liborbit2-dev intltool
sudo aptitude -y install ccache ncurses-dev zlib1g zlib1g-dev gcc g++ libtool
sudo aptitude -y install uuid-dev liblzo2-dev
sudo aptitude -y install tcl dpkg
sudo apt-get install texinfo
sudo apt-get install texlive
[Remove directory]
sudo rm -Rf /opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37
sudo rm -Rf /opt/freescale/ltib/usr/src/rpm/BUILD/libtool-2.4.2
[Change the ltib script]
sudo vi ~ltib/ltib
Comment out (#) the line as shown below in ltib script.
Package                Minimum ver   Installed info
#zlib                   0             not installed
Keita
keitanagashima
Dear All,
Build succeeded!
[Environment]
BSP: L3.0.35_4.0.0
Virtual Box: 4.2.10
[Remove directory]
sudo vi ~ltib/ltib
Keita
Yuri
Perhaps it makes sense to try recent Ubuntu / Debian releases as a host OS.
i.MX Linux BSP Environment Setup
LeonardoSandova
Specialist I
According to the log, you need to install the texi2dvi before running ltib.
/bin/sh: texi2dvi: command not found
make[2]: *** [flex.pdf] Error 127
make[2]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37/doc'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37'
make: *** [install] Error 2
error: Bad exit status from /home/guest/ltib/tmp/rpm-tmp.29045 (%install)
Leo
keitanagashima
Dear Leo,
Hello.
I tried to command of "sudo apt-get install texi2dvi"
But, it couldn't get the texi2dvi package.
And, I tried to build again.
./ltib -m distclean
./ltib
Check the following error log.
Processing platform: Host support packages
using /home/guest/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: m4
Processing: bison
Processing: flex
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Tue Jul 30 09:40:44 2013
Ended:   Tue Jul 30 09:40:45 2013
Elapsed: 1 seconds
These packages failed to build:
flex
Build Failed
Keita
LeonardoSandova
Specialist I
Keita,
in case the app you are trying to install is not found, you need to figure out which packages installs the app. Google is your friend, but also the app 'apt-file' (if you do not have it, install it) is. Once installed it you can try:
$ apt-file find texi2dvi
a2ps: /usr/bin/texi2dvi4a2ps
a2ps: /usr/share/man/man1/texi2dvi4a2ps.1.gz
manpages-ja: /usr/share/man/ja/man1/texi2dvi.1.gz
manpages-zh: /usr/share/man/zh_CN/man1/texi2dvi.1.gz
manpages-zh: /usr/share/man/zh_TW/man1/texi2dvi.1.gz
texinfo: /usr/bin/pdftexi2dvi
texinfo: /usr/bin/texi2dvi
texinfo: /usr/share/man/man1/pdftexi2dvi.1.gz
texinfo: /usr/share/man/man1/texi2dvi.1.gz
texinfo-doc-nonfree: /usr/share/doc/texinfo/html/Format-with-texi2dvi.html
texlive-pictures-doc: /usr/share/doc/texlive-doc/support/texdraw/texi2dvi.gz
texlive-pictures-doc: /usr/share/doc/texlive-pictures-doc/support/texdraw/texi2dvi.gz
as you can see, the texinfo package (as suggested by Hemal), is the one you need to install.
Leo
keitanagashima
Hi Leo,
I could see following by apt-file find texi2dvi.
r-base-core: /usr/lib/R/library/tools/help/texi2dvi
r-base-html: /usr/lib/R/library/tools/html/texi2dvi.html
r-base-latex: /usr/lib/R/library/tools/latex/texi2dvi.tex
texlive-pictures-doc: /usr/share/doc/texlive-doc/texdraw/texi2dvi.gz
texlive-pictures-doc: /usr/share/doc/texlive-pictures-doc/texdraw/texi2dvi.gz
I had already installed the texinfo package.
But, the texlive package couldn't be installed by sudo apt-get install texlive (as suggested by Hemal).
When I install the texlive, dpkg of package management system was broken...
Keita
Yuri
Are old repos applied, as recommended in section 1.2 (Update Sources.list to Point to Old-releases Repository) of "Setting_Up_LTIB_Host.pdf"
hemalgandhi
Hi Keita
Install below package can fix the error
if you need more info please refer below link.
https://community.freescale.com/message/314749#314749
Hemal
keitanagashima
Hi Hemal,
I tried to below command.
So, I repair the /etc/texmf/fmt.d/10texlive-latex-base.cnf.
(The following are out of comments.)
#latex           pdftex         language.dat-translate-file=cp227.tcx *latex.ini
#pdflatex      pdftex          language.dat-translate-file=cp227.tcx *pdflatex.ini
And, using command of "sudo dpkg --configure -a"
But, LTIB couldn't build the BSP.
Keita
