Where is AN4307SW.zip ?
robroz
I'm trying to use necryption library, but I cannot find any related files on web site - I found only an4307 pdf.  There is a pointer in this document .
Download the software for AN4307 (AN4307SW.zip) from www.freescale.com.
But only pdf document is returned if I search for AN4307SW.zip on www.freescale.com.
Anyone has better pointer ?
Bulek.
Tags (2)
JimDon
Senior Contributor III
google always find things better that the freescale site search.
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MCF51JM&fpsp=1&tab=Design_Tools_Tab#
Then open "lab and test software" down the page.
TomE
Specialist II
That link doesn't work any more. Neither using NXP's search. Neither does using Google. Navigating to the current (modified for Phone use) MCF51JM page and looking through the Software list finds it.
The software is now apparently called:
Using the CAU and mmCAU in ColdFire+<sup>&#174;</sup><sup>&#174;</sup>, ColdFire+ and Kinetis<sup>&#...
https://www.nxp.com/webapp/Download?colCode=AN4307SW&Parent_nodeId=1201542323437713916659&Parent_pag...
After demanding personal details and filling in a form about "Export Control", nothing... The "Download" page doesn't do anything. There's an "Export Control FAQ link that doesn't do anything either.
Pasting the above link into a browser the SECOND time worked though.
(Edit) And the User Guide is:
http://cache.freescale.com/files/32bit/doc/user_guide/CAUAPIUG.pdf
Tom
bobpaddock
I have found that some of the downloads from this system will only work when using Firefox.
They do not work correctly with Chromium or Internet Explore.
JimDon
