UUU tools memory consumption
1,381 次查看
ruben_boelinger
Senior Contributor II
we build our own frontend around the UUU tools for programming and flashing Andorid in a production case. We recognized that the the tools require a lot of memory as it loads / buffer the full OS image ( in our case Android with approx 1.2 - 1.4 GB) into the host memory.
Is there any way to reduce the memory needs ? We often come to some virtual memory limit. Would be a compressed image (bz2) help for that ?
0 回复数
