Intermittent issue with NNAPI Delegate returning identical inference results on imx-5.10.52-2.1.0 an
daisuke_arai2
I am working on the i.MX 8M Plus platform with BSP version imx-5.10.52-2.1.0 (Yocto-based Linux). I have occasionally encountered an issue when using the NNAPI Delegate, where the inference results unexpectedly remain the same even when the input images are changed. This problem seems to occur intermittently rather than under a specific condition.
Could you kindly explain why this issue occurs, and whether switching to the VX Delegate in imx-6 or later versions would resolve it?
Thank you in advance for your support.
%3CLINGO-SUB%20id%3D%22lingo-sub-2153429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIntermittent%20issue%20with%20NNAPI%20Delegate%20returning%20identical%20inference%20results%20on%20imx-5.10.52-2.1.0%20an%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20working%20on%20the%20i.MX%208M%20Plus%20platform%20with%20BSP%20version%20%3CEM%3Eimx-5.10.52-2.1.0%3C%2FEM%3E%20(Yocto-based%20Linux).%20I%20have%20occasionally%20encountered%20an%20issue%20when%20using%20the%20NNAPI%20Delegate%2C%20where%20the%20inference%20results%20unexpectedly%20remain%20the%20same%20even%20when%20the%20input%20images%20are%20changed.%20This%20problem%20seems%20to%20occur%20intermittently%20rather%20than%20under%20a%20specific%20condition.%3C%2FP%3E%3CP%3ECould%20you%20kindly%20explain%20why%20this%20issue%20occurs%2C%20and%20whether%20switching%20to%20the%20VX%20Delegate%20in%20%3CEM%3Eimx-6%3C%2FEM%3E%20or%20later%20versions%20would%20resolve%20it%3F%3C%2FP%3E%3CP%3EThank%20you%20in%20advance%20for%20your%20support.%3C%2FP%3E%3C%2FLINGO-BODY%3E
