IMX8MPLUS SENSOR CALIBRATION FILES
1,349件の閲覧回数
venom
Currently i am working on imx415 camera sensor porting on imx8mplus ,i have customized my imx415 driver according to camera sensor porting guide.
What i don't have are the sensor calibration files. Now, even if i don't have calibration file is will my camera work and send data to ISP??
Is it really important that i have sensor calibration files??Can i skip that part or not??
For now, without any calbration files i cannot stream.I can see that it actually triggers a ioctl call "VIDIOC_QUERYCAP" in my sensor driver but after that i can see a isp driver log that enables streams and immediately disabling.  What might be the reason for this??.
LOG:
[ 194.089080] imx415 1-001a: Inside VIDIOC_QUERYCAP
[ 194.118862] enter isp_mi_stop
[ 195.511209] enter isp_set_stream 1
[ 212.626549] enter isp_set_stream 0
Thank you,
Regards Harsha.
4 返答(返信)
1,222件の閲覧回数
Oswalag
the answer is yes, you need the calibration files as explained in the ISP New Camera Sensor Porting and Integration Guide for i.MX 8M Plus EVK.
1,216件の閲覧回数
venom
While streaming, I can observe the following logs. Could you help me understand what the possible reasons for this behavior might be?
I am not receiving frame end at all.
タグ(1)
1,191件の閲覧回数
Oswalag
Please modify the DTS node as:
Configure 266MHz clock on the second MIPI-CSI2 port:
+&mipi_csi_1 {
+      #address-cells = <1>;
+      #size-cells = <0>;
+      clock-frequency = <266000000>;
+      assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_266M>;
+      assigned-clock-rates = <266000000>;
+      status = "okay";
+      port@1 {
+              reg = <1>;
+              mipi_csi1_ep: endpoint {
+                      remote-endpoint = <&jxf355_mipi_1_ep>;
+                      data-lanes = <2>;
+                      csis-hs-settle = <5>;
+                      csis-clk-settle = <0>;
+                      csis-wclk;
1,177件の閲覧回数
venom
I am using only one csi port & my device tree configuration is as follows:
imx415_0: imx415_mipi@1a {
     compatible = "sony,imx415";
     reg = <0x1a>;
     clocks = <0x1a>;
     assigned-clocks = <0x1a>;
     assigned-clock-rates = <0x16E3600>;
     clock-names = "csi_mclk";
     status = "okay";
     csi_id = <0x00>;
port {
      imx415_0_ep: endpoint {
                   remote-endpoint = <&csi0_ep>;
                   clock-lanes = <0x00>;
                   link-frequencies = /bits/ 64 <360000000>;
                   max-pixel-frequency = <0x00 0x1dcd6500>;
                  data-lanes = <0x01 0x02 0x03 0x04>;
csi@32e40000 {
       compatible = "fsl,imx8mp-mipi-csi\0fsl,imx8mn-mipi-csi";
       reg = <0x32e40000 0x10000>;
       interrupts = <0x00 0x11 0x04>;
       clock-frequency = <0x1dcd6500>;
       clocks = <0x02 0x10f 0x02 0x61 0x02 0x10d>;
       clock-names = "mipi_clk\0disp_axi\0disp_apb";
       assigned-clocks = <0x02 0xaa>;
       assigned-clock-parents = <0x02 0x41>;
       assigned-clock-rates = <0x1dcd6500>;
       bus-width = <0x04>;
       csi-gpr = <0x74>;
       gpr = <0x5b>;
       power-domains = <0x5b 0x01>;
       status = "okay";
       phandle = <0x10e>;
port {
          csi0_ep: endpoint {
                     remote-endpoint = <&imx415_0_ep>;
                     data-lanes = <4>;
                     csis-hs-settle = <0x0F>;
                     csis-clk-settle = <0x10>;
If my sensor is in continuous mode does it work??
タグ(1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2296006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MPLUS%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%E3%80%81imx8mplus%20%E3%81%B8%E3%81%AE%20imx415%20%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E7%A7%BB%E6%A4%8D%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%20imx415%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%E3%81%95%E3%81%A6%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%20ISP%20%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8C%81%E3%81%A4%E3%81%93%E3%81%A8%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%AE%E9%83%A8%E5%88%86%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%20ioctl%20%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%20%22VIDIOC_QUERYCAP%22%20%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%99%E3%81%90%E3%81%AB%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CSTRONG%3EISP%3C%2FSTRONG%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%AD%E3%82%B0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E4%BD%95%E3%81%AE%E7%90%86%E7%94%B1%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3F%E3%80%82%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3E%E3%83%AD%E3%82%B0%EF%BC%9A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B%20194.089080%5D%20imx415%201-001a%3A%20%3CSTRONG%3EVIDIOC_QUERYCAP%3C%2FSTRONG%3E%E5%86%85%3CBR%20%2F%3E%5B%20194.118862%5D%20%3CSTRONG%3Eisp_mi_stop%3C%2FSTRONG%3E%E3%82%92%E5%85%A5%E5%8A%9B%3CBR%20%2F%3E%5B%20195.511209%5D%20%3CSTRONG%3Eisp_set_stream%3C%2FSTRONG%3E%201%20%E3%82%92%E5%85%A5%E5%8A%9B%3CBR%20%2F%3E%5B%20212.626549%5D%20%3CSTRONG%3Eisp_set_stream%3C%2FSTRONG%3E%200%20%E3%82%92%E5%85%A5%E5%8A%9B%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%E3%83%8F%E3%83%AB%E3%82%B7%E3%83%A3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E8%A6%B3%E5%AF%9F%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AE%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%AA%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375036iF66233E4DF61A481%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%A8%E3%83%B3%E3%83%89%E3%82%92%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%AD%94%E3%81%88%E3%81%AF%E3%80%8C%E3%81%AF%E3%81%84%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82ISP%20%E3%81%AE%E3%80%8Ci.MX%208M%20Plus%20EVK%20%E7%94%A8%E6%96%B0%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5%E7%A7%BB%E6%A4%8D%E3%81%8A%E3%82%88%E3%81%B3%E7%B5%B1%E5%90%88%E3%82%AC%E3%82%A4%E3%83%89%E3%80%8D%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDTS%20%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22uiOutputText%22%3E2%E7%95%AA%E7%9B%AE%E3%81%AEMIPI-CSI2%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7266MHz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26amp%3Bmipi_csi_1%20%7B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22cuf-entityLinkId%20forceChatterEntityLink%22%20data-id%3D%22%22%20data-hashtag%3D%22address-cells%22%20data-mention%3D%22%23address-cells%22%3E%3CA%20class%3D%22cuf-entityLink%20cuf-hashtag%22%20title%3D%22%23%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%BB%E3%83%AB%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%23%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%BB%E3%83%AB%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3D%20%26lt%3B1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22cuf-entityLinkId%20forceChatterEntityLink%22%20data-id%3D%22%22%20data-hashtag%3D%22size-cells%22%20data-mention%3D%22%23size-cells%22%3E%3CA%20class%3D%22cuf-entityLink%20cuf-hashtag%22%20title%3D%22%23%E3%82%BB%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%23%E3%82%BB%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B266000000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL1_266M%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20%26lt%3B266000000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%E3%83%9D%E3%83%BC%E3%83%88%401%20%7B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20mipi_csi1_ep%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bjxf355_mipi_1_ep%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%20%26lt%3B2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20csis-hs-settle%20%3D%20%26lt%3B5%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20csis-clk-settle%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20csis-wclk%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%7D%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%20%7D%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%7D%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%201%20%E3%81%A4%E3%81%AE%20CSI%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%3CSTRONG%3Eimx415_0%3C%2FSTRONG%3E%20%3A%20imx415_mipi%401a%20%7B%3CBR%20%2F%3E%20%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22sony%2Cimx415%22%3B%3CBR%20%2F%3E%20%26lt%3B0x1a%26gt%3B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3CBR%20%2F%3E%20%3D%20%EF%BF%BD%3B%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%26lt%3B0x1a%26gt%3B%20%EF%BF%BD%3B%3CBR%20%2F%3E%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%26lt%3B0x1a%26gt%3B%20%EF%BF%BD%3B%3CBR%20%2F%3E%20%26lt%3B0x16E3600%26gt%3B%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%20%3D%3B%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%20%22csi_mclk%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3CBR%20%2F%3E%20csi_id%20%3D%26lt%3B0x00%26gt%3B%20%26%230%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E3%83%9D%E3%83%BC%E3%83%88%20%7B%3CBR%20%2F%3E%3CSTRONG%3E%20imx415_0_ep%3C%2FSTRONG%3E%20%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bcsi0_ep%26gt%3B%3B%3CBR%20%2F%3E%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%26lt%3B0x00%26gt%3B%20%26%230%3B%3B%3CBR%20%2F%3E%20%E3%83%AA%E3%83%B3%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%2F%E3%83%93%E3%83%83%E3%83%88%2F%26lt%3B360000000%26gt%3B%2064%3B%3CBR%20%2F%3E%20%E6%9C%80%E5%A4%A7%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%91%A8%E6%B3%A2%E6%95%B0%26lt%3B0x00%200x1dcd6500%26gt%3B%20%3CBR%20%2F%3E%26lt%3B0x01%200x02%200x03%200x04%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3D%3B%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%3B%20%7D%3B%20%7D%3B%20%7D%3B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%3CBR%20%2F%3E%3CSTRONG%3Ecsi%4032e40000%3C%2FSTRONG%3E%20%7B%3CBR%20%2F%3E%20%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22fsl%E3%80%81imx8mp-mipi-csi%5C0fsl%E3%80%81imx8mn-mipi-csi%22%3B%3CBR%20%2F%3E%20%26lt%3B0x32e40000%200x10000%26gt%3B%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%26lt%3B0x00%200x11%200x04%26gt%3B%20%3D%3B%3CBR%20%2F%3E%26lt%3B0x1dcd6500%26gt%3B%20%3CBR%20%2F%3E%26lt%3B0x02%200x10f%200x02%200x61%200x02%200x10d%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26lt%3B0x02%200xaa%26gt%3B%3CBR%20%2F%3E%26lt%3B0x02%200x41%26gt%3B%3CBR%20%2F%3E%26lt%3B0x1dcd6500%26gt%3B%3CBR%20%2F%3E%26lt%3B0x04%26gt%3B%3CBR%20%2F%3E%26lt%3B0x74%26gt%3B%3CBR%20%2F%3E%26lt%3B0x5b%26gt%3B%3CBR%20%2F%3E%26lt%3B0x5b%200x01%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%26lt%3B0x10e%26gt%3B%20%3D%3B%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%3B%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%3B%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%20%22mipi_clk%5C0disp_axi%5C0disp_apb%22%3B%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%3B%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%20%3D%3B%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%20%3D%3B%20%E3%83%90%E3%82%B9%E5%B9%85%20%3D%20%26%234%3B%3B%20csi-gpr%20%3D%20t%3B%20gpr%20%3D%20%EF%BF%BD%3B%20%E9%9B%BB%E6%BA%90%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%20%3D%3B%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%20%E3%83%95%E3%82%A1%E3%83%B3%E3%83%89%E3%83%AB%20%3D%3B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%3CSTRONG%3E%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%20%7B%20csi0_ep%3CBR%20%2F%3E%20%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bimx415_0_ep%26gt%3B%3B%3CBR%20%2F%3E%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%26lt%3B4%26gt%3B%20%3D%3B%3CBR%20%2F%3E%20csis-hs-settle%20%3D%26lt%3B0x0F%26gt%3B%20%26%2315%3B%3B%3CBR%20%2F%3E%20csis-clk-settle%20%3D%26lt%3B0x10%26gt%3B%20%26%2316%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8C%E9%80%A3%E7%B6%9A%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
