IMX8MPLUS SENSOR CALIBRATION FILES
venom
Currently i am working on imx415 camera sensor porting on imx8mplus ,i have customized my imx415 driver according to camera sensor porting guide.
What i don't have are the sensor calibration files. Now, even if i don't have calibration file is will my camera work and send data to ISP??
Is it really important that i have sensor calibration files??Can i skip that part or not??
For now, without any calbration files i cannot stream.I can see that it actually triggers a ioctl call "VIDIOC_QUERYCAP" in my sensor driver but after that i can see a isp driver log that enables streams and immediately disabling.  What might be the reason for this??.
LOG:
[ 194.089080] imx415 1-001a: Inside VIDIOC_QUERYCAP
[ 194.118862] enter isp_mi_stop
[ 195.511209] enter isp_set_stream 1
[ 212.626549] enter isp_set_stream 0
Thank you,
Regards Harsha.
Oswalag
the answer is yes, you need the calibration files as explained in the ISP New Camera Sensor Porting and Integration Guide for i.MX 8M Plus EVK.
venom
While streaming, I can observe the following logs. Could you help me understand what the possible reasons for this behavior might be?
I am not receiving frame end at all.
Oswalag
Please modify the DTS node as:
Configure 266MHz clock on the second MIPI-CSI2 port:
+&mipi_csi_1 {
+      #address-cells = <1>;
+      #size-cells = <0>;
+      clock-frequency = <266000000>;
+      assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_266M>;
+      assigned-clock-rates = <266000000>;
+      status = "okay";
+      port@1 {
+              reg = <1>;
+              mipi_csi1_ep: endpoint {
+                      remote-endpoint = <&jxf355_mipi_1_ep>;
+                      data-lanes = <2>;
+                      csis-hs-settle = <5>;
+                      csis-clk-settle = <0>;
+                      csis-wclk;
venom
I am using only one csi port & my device tree configuration is as follows:
imx415_0: imx415_mipi@1a {
     compatible = "sony,imx415";
     reg = <0x1a>;
     clocks = <0x1a>;
     assigned-clocks = <0x1a>;
     assigned-clock-rates = <0x16E3600>;
     clock-names = "csi_mclk";
     status = "okay";
     csi_id = <0x00>;
port {
      imx415_0_ep: endpoint {
                   remote-endpoint = <&csi0_ep>;
                   clock-lanes = <0x00>;
                   link-frequencies = /bits/ 64 <360000000>;
                   max-pixel-frequency = <0x00 0x1dcd6500>;
                  data-lanes = <0x01 0x02 0x03 0x04>;
csi@32e40000 {
       compatible = "fsl,imx8mp-mipi-csi\0fsl,imx8mn-mipi-csi";
       reg = <0x32e40000 0x10000>;
       interrupts = <0x00 0x11 0x04>;
       clock-frequency = <0x1dcd6500>;
       clocks = <0x02 0x10f 0x02 0x61 0x02 0x10d>;
       clock-names = "mipi_clk\0disp_axi\0disp_apb";
       assigned-clocks = <0x02 0xaa>;
       assigned-clock-parents = <0x02 0x41>;
       assigned-clock-rates = <0x1dcd6500>;
       bus-width = <0x04>;
       csi-gpr = <0x74>;
       gpr = <0x5b>;
       power-domains = <0x5b 0x01>;
       status = "okay";
       phandle = <0x10e>;
port {
          csi0_ep: endpoint {
                     remote-endpoint = <&imx415_0_ep>;
                     data-lanes = <4>;
                     csis-hs-settle = <0x0F>;
                     csis-clk-settle = <0x10>;
If my sensor is in continuous mode does it work??
%3CLINGO-SUB%20id%3D%22lingo-sub-2296006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3ECurrently%20i%20am%20working%20on%20imx415%20camera%20sensor%20porting%20on%20imx8mplus%20%2Ci%20have%20customized%20my%20imx415%20driver%20according%20to%20camera%20sensor%20porting%20guide.%3CBR%20%2F%3EWhat%20i%20don't%20have%20are%20the%20sensor%20calibration%20files.%20Now%2C%20even%20if%20i%20don't%20have%20calibration%20file%20is%20will%20my%20camera%20work%20and%20send%20data%20to%20ISP%3F%3F%26nbsp%3B%3CBR%20%2F%3EIs%20it%20really%20important%20that%20i%20have%20sensor%20calibration%20files%3F%3FCan%20i%20skip%20that%20part%20or%20not%3F%3F%3CBR%20%2F%3EFor%20now%2C%20without%20any%20calbration%20files%20i%20cannot%20stream.I%20can%20see%20that%20it%20actually%20triggers%20a%20ioctl%20call%20%22VIDIOC_QUERYCAP%22%20in%20my%20sensor%20driver%20but%20after%20that%20i%20can%20see%20a%20%3CSTRONG%3Eisp%3C%2FSTRONG%3E%20driver%20log%20that%20enables%20streams%20and%20immediately%20disabling.%26nbsp%3B%20What%20might%20be%20the%20reason%20for%20this%3F%3F.%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3ELOG%3A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B%20194.089080%5D%20imx415%201-001a%3A%20Inside%20%3CSTRONG%3EVIDIOC_QUERYCAP%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B%20194.118862%5D%20enter%20%3CSTRONG%3Eisp_mi_stop%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B%20195.511209%5D%20enter%20%3CSTRONG%3Eisp_set_stream%3C%2FSTRONG%3E%201%3CBR%20%2F%3E%5B%20212.626549%5D%20enter%20%3CSTRONG%3Eisp_set_stream%3C%2FSTRONG%3E%200%3C%2FP%3E%3CP%3EThank%20you%2C%3CBR%20%2F%3ERegards%20Harsha.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EWhile%20streaming%2C%20I%20can%20observe%20the%20following%20logs.%20Could%20you%20help%20me%20understand%20what%20the%20possible%20reasons%20for%20this%20behavior%20might%20be%3F%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20style%3D%22width%3A%20948px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375036iF66233E4DF61A481%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20alt%3D%22Screenshot%20from%202026-01-30%2016-21-45.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20am%20not%20receiving%20frame%20end%20at%20all.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3Ethe%20answer%20is%20yes%2C%20you%20need%20the%20calibration%20files%20as%20explained%20in%20the%26nbsp%3BISP%20New%20Camera%20Sensor%20Porting%20and%20Integration%20Guide%20for%20i.MX%208M%20Plus%20EVK.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20modify%20the%20DTS%20node%20as%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22uiOutputText%22%3EConfigure%20266MHz%20clock%20on%20the%20second%20MIPI-CSI2%20port%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26amp%3Bmipi_csi_1%20%7B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22cuf-entityLinkId%20forceChatterEntityLink%22%20data-id%3D%22%22%20data-hashtag%3D%22address-cells%22%20data-mention%3D%22%23address-cells%22%3E%3CA%20class%3D%22cuf-entityLink%20cuf-hashtag%22%20title%3D%22%23address-cells%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%23address-cells%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3D%20%26lt%3B1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22cuf-entityLinkId%20forceChatterEntityLink%22%20data-id%3D%22%22%20data-hashtag%3D%22size-cells%22%20data-mention%3D%22%23size-cells%22%3E%3CA%20class%3D%22cuf-entityLink%20cuf-hashtag%22%20title%3D%22%23size-cells%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%23size-cells%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bclock-frequency%20%3D%20%26lt%3B266000000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bassigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL1_266M%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bassigned-clock-rates%20%3D%20%26lt%3B266000000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bstatus%20%3D%20%22okay%22%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bport%401%20%7B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Breg%20%3D%20%26lt%3B1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmipi_csi1_ep%3A%20endpoint%20%7B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bremote-endpoint%20%3D%20%26lt%3B%26amp%3Bjxf355_mipi_1_ep%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bdata-lanes%20%3D%20%26lt%3B2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsis-hs-settle%20%3D%20%26lt%3B5%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsis-clk-settle%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsis-wclk%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%7D%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%7D%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%2B%7D%3B%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MPLUS%20SENSOR%20CALIBRATION%20FILES%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI%20am%20using%20only%20one%20csi%20port%20%26amp%3B%20my%20device%20tree%20configuration%20is%20as%20follows%3A%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%3CSTRONG%3Eimx415_0%3C%2FSTRONG%3E%3A%20imx415_mipi%401a%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bcompatible%20%3D%20%22sony%2Cimx415%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Breg%20%3D%20%26lt%3B0x1a%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bclocks%20%3D%20%26lt%3B0x1a%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bassigned-clocks%20%3D%20%26lt%3B0x1a%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bassigned-clock-rates%20%3D%20%26lt%3B0x16E3600%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bclock-names%20%3D%20%22csi_mclk%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bstatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bcsi_id%20%3D%20%26lt%3B0x00%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3Eport%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3CSTRONG%3Eimx415_0_ep%3C%2FSTRONG%3E%3A%20endpoint%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bremote-endpoint%20%3D%20%26lt%3B%26amp%3Bcsi0_ep%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bclock-lanes%20%3D%20%26lt%3B0x00%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Blink-frequencies%20%3D%20%2Fbits%2F%2064%20%26lt%3B360000000%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bmax-pixel-frequency%20%3D%20%26lt%3B0x00%200x1dcd6500%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20data-lanes%20%3D%20%26lt%3B0x01%200x02%200x03%200x04%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%3CBR%20%2F%3E%3CSTRONG%3Ecsi%4032e40000%3C%2FSTRONG%3E%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bcompatible%20%3D%20%22fsl%2Cimx8mp-mipi-csi%5C0fsl%2Cimx8mn-mipi-csi%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Breg%20%3D%20%26lt%3B0x32e40000%200x10000%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Binterrupts%20%3D%20%26lt%3B0x00%200x11%200x04%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bclock-frequency%20%3D%20%26lt%3B0x1dcd6500%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bclocks%20%3D%20%26lt%3B0x02%200x10f%200x02%200x61%200x02%200x10d%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bclock-names%20%3D%20%22mipi_clk%5C0disp_axi%5C0disp_apb%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bassigned-clocks%20%3D%20%26lt%3B0x02%200xaa%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bassigned-clock-parents%20%3D%20%26lt%3B0x02%200x41%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bassigned-clock-rates%20%3D%20%26lt%3B0x1dcd6500%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bbus-width%20%3D%20%26lt%3B0x04%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bcsi-gpr%20%3D%20%26lt%3B0x74%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bgpr%20%3D%20%26lt%3B0x5b%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bpower-domains%20%3D%20%26lt%3B0x5b%200x01%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bstatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bphandle%20%3D%20%26lt%3B0x10e%26gt%3B%3B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3Eport%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3CSTRONG%3Ecsi0_ep%3C%2FSTRONG%3E%3A%20endpoint%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bremote-endpoint%20%3D%20%26lt%3B%26amp%3Bimx415_0_ep%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bdata-lanes%20%3D%20%26lt%3B4%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bcsis-hs-settle%20%3D%20%26lt%3B0x0F%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bcsis-clk-settle%20%3D%20%26lt%3B0x10%26gt%3B%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7D%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3EIf%20my%20sensor%20is%20in%20continuous%20mode%20does%20it%20work%3F%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
