Enabling OpenSSL on U-Boot
kanimozhi_t
Contributor V
I want to add OpenSSL to U-Boot and referred code on root/lib/rsa/rsa-sign.c. However, when I try to build with added openssl headers in hab.c I'm receiving "openssl/pem.h: No such file or directory" this error.
The modified make command is as follows:
make CFLAGS="-lcrypto -lssl" ARCH=arm CROSS_COMPILE=$toolchain
Can someone help me in adding the OpenSSL support on U-Boot? Thanks in advance.
Tags (4)
Yuri
