iMX8QM-MEK: SUSPEND AND WAKEUP IN ANDROID 9 AUTOMOTIVE
Search instead for
No ratings
This the document for SUSPEND and WAKE-UP in IMX8QM-MEK platform
Wake up done by following,
  1. M4  debug UART
  2. A53 debug UART
  3. Power Key
Source: imx-p9.0.0_2.1.1-auto-ga
  • CONFIGURATION
         Disable the default wake-up - RTC Timer (Patch - Disable_auto_wakeup.diff)
  • SUSPEND
     1. Command  Line,
            # echo mem > /sys/power/state
     2. Dumpsys Command
            # dumpsys activity service com.android.car inject-vhal-event 0x11410a00 4,2
  • WAKE-UP
    1. BUTTON
         By pressing the power-key SW3 (0.5s)
     2. DEBUG UART
         Enable debug UART wake-up
         # cat ./sys/devices/platform/5a060000.serial/tty/ttyLP0/power/wakeup
         disabled
         # echo enabled  > ./sys/devices/platform/5a060000.serial/tty/ttyLP0/power/wakeup
         TO WAKEUP
                  Press the ENTER Key 2 times
3. M4 UART WAKEUP
                       Apply the RPMSG patch (L4.14.98.diff)
                                       # cat./sys/devices/platform/5a070000.serial/tty/ttyLP1/power/wakeup
         disabled
         # echo enabled > ./sys/devices/platform/5a070000.serial/tty/ttyLP1/power/wakeup
Type some input in M4 Cosole
Version history
Last update:
‎08-05-2020 10:00 AM
Updated by:
