Evaluation of MYIR's i.MX 8M Mini based SOM and EVM
The MYC-C8MMX CPU Moduleis designed by MYIR, which is an ARM embedded System-on-Module (SoM) based on NXP’ i.MX 8M Mini Quad Application Processor. The MYD-C8MMX development board is built around the MYC-C8MMX CPU Module, it is a complete evaluation module for your prototype and reference design. It is capable of running Linux and Android OS and provided with plenty of software resources. Typical applications are for Industry Control, Smart City, Smart Home, HMI, Internet of Things (IoT), etc.
Let’s see a video introduction of the MYD-C8MMX development board.
https://youtu.be/FL_CZiSMYsM
The MYC-C8MMX CPU Moduleis using the MIMX8MM6CVTKZAA (MIMX8MM6DVTLZAA) processor chip which is among the NXP i.MX 8M Mini family and combines advanced 14LPC FinFET process technology to provide more speed and improved power efficiency. It has a quad Cortex-A53 core which operates at speeds of up to 1.6 (1.8) GHz. It also has a general-purpose Cortex-M4 400 MHz core processor for low-power processing. Some parameters and target applications of the processor chip are listed below for reference.
Parameter
Value
Core: Number of cores (SPEC)
4
Core Type
Arm Cortex-A53
Operating Frequency [Max] (MHz)
1600 (MIMX8MM6CVTKZAA)/1800 (MIMX8MM6DVTLZAA)
L2 Cache (Max) (KB)
512
Co-Processor Type
Arm Cortex-M4F
Co-Processor Frequency (MAX) (MHz)
400
External Memory Supported
DDR3L SDRAM, DDR4 SDRAM, ECC, LPDDR4 DRAM, NAND FLASH, NOR FLASH, QSPI
GPU 2D / GPU 3D
1x shader, Vivante GC320, Vivante GCNanoUltra
The chip only has MIPI-DSI and MIPI-CSI interfaces and no HDMI or other display interfaces. It can support wide working temperature range from -40 to 105 Celsius degree. MYIR’s MYC-C8MMX CPU Module can support working temperature from -40 to 85 Celsius degree.
Parameter
Value
HW Video Encoder / Decoder
HD1080p60 H.264, HD1080p60 H.265
Video/Display features
MIPI-CSI, MIPI-DSI
PCIe
PCIe 2.0 x 1
Audio Specific Modules
8-ch PDM input, SAI
USB Controllers
2
Serial Communication
1 x PCIe 2.0,3 x SPI,4 x I²C,4 x UART
Junction Temperature ()
-40 to 105 (MIMX8MM6CVTKZAA), 0 to 95 (MIMX8MM6DVTLZAA)
Target Applications of i.MX 8M Mini Processors
Automotive
Smart City
Heating Ventilation, and Air Conditioning (HVAC)
Automatic Vehicle Identification
Motorcycle Engine Control Unit (ECU) and Small Engine Control
Fleet Management
Inventory and Supply Chain Management
Industrial
Public Address Systems
Air Conditioning (AC)
Transport Ticketing
Building Safety
Building Security
Smart Home
Digital Signage
Audio/Video (AV) Receivers
Energy Gateway
Gaming Console
Heat Metering
Home Control Panel
Hospital Admission Machine
Home Security & Surveillance
Image Analytics
Home Sensor
Industrial Control
In-Home Energy Display
Industrial HMI
Major Home Appliances
Machine Visual Inspection
Robotic Appliance
Smart Lighting
Set Top Boxes
Smart Power Socket and Light Switch
Small and Medium Appliances
Two-way Video Conferencing
Smart Speaker
Vision, Advanced Sensing and Processing Board
Soundbar
Surround Sound and Sound Bars
Mobile
Wireless or Networked Speakers
Cable
Hearables
Technologies
Input Device (Mouse, Pen, Keyboard)
Voice Assistants
Smart Watch
Voice Control
Wireless Charging Pad
Wristband
The MYC-C8MMX CPU Module is a minimum system with PMIC, CPU, RAM (DDR4), Flash (eMMC, SPI Flash) and clock, plus an Ethernet PHY chip. A number of peripheral and IO signals are access through two 0.8mm pitch 100-pin board-to-board expansion connectors.
                        MYC-C8MMX CPU Module Top-view                                         MYC-C8MMX CPU Module Bottom-view
The MYD-C8MMX base board has mainly extended four parts:
1. Audio interface: added audio chip to extend Audio input and output interfaces
2. External power supply part: added one DC-DC power chip
3. Added one USB hub chip to extend 4 USB from the SoC USB interface, separately used for 4G LTE, two USB Host and one USB on expansion header.
4. Extend RTC module through I2C interface
Many other peripheral interfaces are brought out for user extension.
                                                   MYD-C8MMX Function Block Diagram
                                                           MYD-C8MMX Interface Diagram
Among so many interfaces, Backlight, LVDS LCD and MIPI interface are relative to display function. The Backlight interface has 6 pins including two power signals, two GND and two GPIO (one is enabled terminal to control the backlight power and another is PWM to control the brightness of backlight.)
The two GPIO control terminals are from the GPIO1_01 and 08 of the i.MX 8M Mini.
The LVDS LCD and MIPI interface, total 3 interfaces are for display. But actually i.MX 8M Mini only has one MIPI DSI interface. The other two LVDS interfaces are switched from DSI through one DS12LVDS bridge chip, one is single link LVDS and another is dual link LVDS. So, we can only select MIPI DSI display or LVDS display. Also, we can only select single link LVDS or dual link LVDS.
MYIR offers optional LVDS based 7-inch LCD Module MY-LVDS070C including capacitive touch screen to work with the MYD-C8MMX board. The display resolution is up to 1024 by 600 pixels.
                          MY-LVDS070C 7-inch LCD Module with Capacitive Touch Screen
The MYD-C8MMX has one 2.0mm pitch 2*15-pin male expansion header. PDM and SAI are audio relative interfaces which are brought out from the expansion header.
%3CLINGO-SUB%20id%3D%22lingo-sub-1109213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEvaluation%20of%20MYIR's%20i.MX%208M%20Mini%20based%20SOM%20and%20EVM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D617%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3EMYC-C8MMX%26nbsp%3BCPU%20Module%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3Eis%20designed%20by%3C%2FSTRONG%3E%20%3CSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3EMYIR%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3E%2C%20which%20is%20an%20ARM%20embedded%20System-on-Module%20(SoM)%20based%20on%3C%2FSTRONG%3E%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi-mx-applications-processors%2Fi-mx-8-processors%2Fi-mx-8m-mini-arm-cortex-a53-cortex-m4-audio-voice-video%3Ai.MX8MMINI%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3ENXP%E2%80%99%20i.MX%208M%20Mini%26nbsp%3BQuad%20Application%20Processor%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3E.%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D618%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3EMYD-C8MMX%20development%20board%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eis%20built%20around%20the%20MYC-C8MMX%20CPU%20Module%2C%20it%20is%20a%20complete%20evaluation%20module%20for%20your%20prototype%20and%20reference%20design.%20It%20is%20capable%20of%20running%20Linux%20and%20Android%20OS%20and%20provided%20with%20plenty%20of%20software%20resources.%20Typical%20applications%20are%20for%20Industry%20Control%2C%20Smart%20City%2C%20Smart%20Home%2C%20HMI%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%22%3EInternet%20of%20Things%20(IoT)%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eetc.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ELet%E2%80%99s%20see%20a%20video%20introduction%20of%20the%20MYD-C8MMX%20development%20board.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fyoutu.be%2FFL_CZiSMYsM%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fyoutu.be%2FFL_CZiSMYsM%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22myd-c8mmxchip.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22myd-c8mmxchip.jpg%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110671iB614F84B1A87133E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22myd-c8mmxchip.jpg%22%20alt%3D%22myd-c8mmxchip.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D617%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMYC-C8MMX%26nbsp%3BCPU%20Module%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3Eis%20using%20the%20MIMX8MM6CVTKZAA%20(MIMX8MM6DVTLZAA)%20processor%20chip%20which%20is%20among%20the%20NXP%20i.MX%208M%20Mini%20family%20and%20combines%20advanced%2014LPC%20FinFET%20process%20technology%20to%20provide%20more%20speed%20and%20improved%20power%20efficiency.%20It%20has%20a%20quad%20Cortex-A53%20core%20which%20operates%20at%20speeds%20of%20up%20to%201.6%20(1.8)%20GHz.%20It%20also%20has%20a%20general-purpose%20Cortex-M4%20400%20MHz%20core%20processor%20for%20low-power%20processing.%20Some%20parameters%20and%20target%20applications%20of%20the%20processor%20chip%20are%20listed%20below%20for%20reference.%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20style%3D%22width%3A%20839px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20%23e5eaed%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2010.0pt%3B%20%22%3EParameter%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20background%3A%20%23e5eaed%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2010.0pt%3B%20%22%3EValue%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ECore%3A%20Number%20of%20cores%20(SPEC)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ECore%20Type%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EArm%20Cortex-A53%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EOperating%20Frequency%20%5BMax%5D%20(MHz)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E1600%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EMIMX8MM6CVTKZAA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E)%2F1800%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EMIMX8MM6DVTLZAA)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EL2%20Cache%20(Max)%20(KB)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E512%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ECo-Processor%20Type%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EArm%20Cortex-M4F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ECo-Processor%20Frequency%20(MAX)%20(MHz)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E400%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EExternal%20Memory%20Supported%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EDDR3L%20SDRAM%2C%20DDR4%20SDRAM%2C%20ECC%2C%20LPDDR4%20DRAM%2C%20NAND%20FLASH%2C%20NOR%20FLASH%2C%20QSPI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EGPU%202D%20%2F%20GPU%203D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E1x%20shader%2C%20Vivante%20GC320%2C%20Vivante%20GCNanoUltra%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20%22%3EMIMX8MM6CVTKZAA%20(MIMX8MM6DVTLZAA)%26nbsp%3Bprocessor%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%20chip%20only%20has%20MIPI-DSI%20and%20MIPI-CSI%20interfaces%20and%20no%20HDMI%20or%20other%20display%20interfaces.%20It%20can%20support%20wide%20working%20temperature%20range%20from%20-40%20to%20105%20Celsius%20degree.%20MYIR%E2%80%99s%20MYC-C8MMX%20CPU%20Module%20can%20support%20working%20temperature%20from%20-40%20to%2085%20Celsius%20degree.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20style%3D%22width%3A%20823px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20%23e5eaed%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2010.0pt%3B%20%22%3EParameter%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20background%3A%20%23e5eaed%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2010.0pt%3B%20%22%3EValue%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EHW%20Video%20Encoder%20%2F%20Decoder%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EHD1080p60%20H.264%2C%20HD1080p60%20H.265%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EVideo%2FDisplay%20features%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EMIPI-CSI%2C%20MIPI-DSI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EPCIe%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EPCIe%202.0%20x%201%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EAudio%20Specific%20Modules%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E8-ch%20PDM%20input%2C%20SAI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EUSB%20Controllers%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ESerial%20Communication%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E1%20x%20PCIe%202.0%2C3%20x%20SPI%2C4%20x%20I%C2%B2C%2C4%20x%20UART%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EJunction%20Temperature%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E%E2%84%83%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E-40%20to%20105%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EMIMX8MM6CVTKZAA)%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3E0%20to%2095%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EMIMX8MM6DVTLZAA)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20%22%3EMIMX8MM6CVTKZAA%20(MIMX8MM6DVTLZAA)%26nbsp%3Bprocessor%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20width%3D%22640%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20colspan%3D%222%22%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22640%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2012.0pt%3B%20%22%3ETarget%20Applications%20of%20i.MX%208M%20Mini%20Processors%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3EAutomotive%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3ESmart%20City%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHeating%20Ventilation%2C%20and%20Air%20Conditioning%20(HVAC)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAutomatic%20Vehicle%20Identification%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMotorcycle%20Engine%20Control%20Unit%20(ECU)%20and%20Small%20Engine%20Control%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EFleet%20Management%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EInventory%20and%20Supply%20Chain%20Management%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3EIndustrial%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EPublic%20Address%20Systems%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAir%20Conditioning%20(AC)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETransport%20Ticketing%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EBuilding%20Safety%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EBuilding%20Security%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3ESmart%20Home%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EDigital%20Signage%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAudio%2FVideo%20(AV)%20Receivers%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EEnergy%20Gateway%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EGaming%20Console%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHeat%20Metering%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHome%20Control%20Panel%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHospital%20Admission%20Machine%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHome%20Security%20%26amp%3B%20Surveillance%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EImage%20Analytics%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHome%20Sensor%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EIndustrial%20Control%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EIn-Home%20Energy%20Display%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EIndustrial%20HMI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMajor%20Home%20Appliances%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMachine%20Visual%20Inspection%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ERobotic%20Appliance%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmart%20Lighting%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESet%20Top%20Boxes%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmart%20Power%20Socket%20and%20Light%20Switch%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmall%20and%20Medium%20Appliances%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETwo-way%20Video%20Conferencing%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmart%20Speaker%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EVision%2C%20Advanced%20Sensing%20and%20Processing%20Board%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESoundbar%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESurround%20Sound%20and%20Sound%20Bars%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3EMobile%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EWireless%20or%20Networked%20Speakers%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECable%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHearables%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3ETechnologies%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EInput%20Device%20(Mouse%2C%20Pen%2C%20Keyboard)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EVoice%20Assistants%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmart%20Watch%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EVoice%20Control%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EWireless%20Charging%20Pad%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EWristband%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D617%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3EMYC-C8MMX%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3ECPU%20Module%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eis%20a%20minimum%20system%20with%20PMIC%2C%20CPU%2C%20RAM%20(DDR4)%2C%20Flash%20(eMMC%2C%20SPI%20Flash)%20and%20clock%2C%20plus%20an%20Ethernet%20PHY%20chip.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EA%20number%20of%20peripheral%20and%20IO%20signals%20are%20access%20through%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3Etwo%200.8mm%20pitch%20100-pin%20board-to-board%20expansion%20connectors%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CIMG%20alt%3D%22%22%20src%3D%22http%3A%2F%2Fwww.myirtech.com%2Fattached%2Fimage%2F20190813%2Fmyc-c8mmx400tm.jpg%22%20style%3D%22border%3A%20none%3B%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CIMG%20alt%3D%22%22%20src%3D%22http%3A%2F%2Fwww.myirtech.com%2Fattached%2Fimage%2F20190813%2Fmyc-c8mmx260b.jpg%22%20style%3D%22border%3A%20none%3B%22%20%2F%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3CEM%3EMYC-C8MMX%20CPU%20Module%20Top-view%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BMYC-C8MMX%20CPU%20Module%20Bottom-view%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2012px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EThe%20MYD-C8MMX%20base%20board%20has%20mainly%20extended%20four%20parts%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E1.%20Audio%20interface%3A%20added%20audio%20chip%20to%20extend%20Audio%20input%20and%20output%20interfaces%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX01.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX01.png%22%20style%3D%22width%3A%20458px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110688iF78A4EA2BC40E204%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MYDC8MMX01.png%22%20alt%3D%22MYDC8MMX01.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E2.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3EExternal%20power%20supply%20part%3A%20added%20one%20DC-DC%20power%20chip%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX02.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX02.png%22%20style%3D%22width%3A%20519px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110745i9D65DF406287BF93%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MYDC8MMX02.png%22%20alt%3D%22MYDC8MMX02.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E3.%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAdded%20one%20USB%20hub%20chip%20to%20extend%204%20USB%20from%20the%20SoC%20USB%20interface%2C%20separately%20used%20for%204G%20LTE%2C%20two%20USB%20Host%20and%20one%20USB%20on%20expansion%20header.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX03.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX03.png%22%20style%3D%22width%3A%20661px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110791i87860229EF2CA9DE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MYDC8MMX03.png%22%20alt%3D%22MYDC8MMX03.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E4.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3EExtend%20RTC%20module%20through%20I2C%20interface%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX04.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX04.png%22%20style%3D%22width%3A%20675px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110806i05C4D7BE8BFB22CB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MYDC8MMX04.png%22%20alt%3D%22MYDC8MMX04.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EMany%20other%20peripheral%20interfaces%20are%20brought%20out%20for%20user%20extension.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22myd-c8mmx-fbd.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22myd-c8mmx-fbd.jpg%22%20style%3D%22width%3A%20650px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110870i271516B2047D4152%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22myd-c8mmx-fbd.jpg%22%20alt%3D%22myd-c8mmx-fbd.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BMYD-C8MMX%20Function%20Block%20Diagram%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22myd-c8mmx600.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22myd-c8mmx600.jpg%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110905i10BC35438D13BDCB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22myd-c8mmx600.jpg%22%20alt%3D%22myd-c8mmx600.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FEM%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BMYD-C8MMX%20Interface%26nbsp%3BDiagram%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3EAmong%20so%20many%20interfaces%2C%20Backlight%2C%20LVDS%20LCD%20and%20MIPI%20interface%20are%20relative%20to%20display%20function.%20The%20Backlight%20interface%20has%206%20pins%20including%20two%20power%20signals%2C%20two%20GND%20and%20two%20GPIO%20(one%20is%20enabled%20terminal%20to%20control%20the%20backlight%20power%20and%20another%20is%20PWM%20to%20control%20the%20brightness%20of%20backlight.)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX05.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX05.png%22%20style%3D%22width%3A%20664px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110941i0967A35F7BDDA70D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MYDC8MMX05.png%22%20alt%3D%22MYDC8MMX05.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EThe%20two%20GPIO%20control%20terminals%20are%20from%20the%20GPIO1_01%20and%2008%20of%20the%20i.MX%208M%20Mini.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX06.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX06.png%22%20style%3D%22width%3A%20532px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110809iAFAF0E61BF68C46C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MYDC8MMX06.png%22%20alt%3D%22MYDC8MMX06.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EThe%20LVDS%20LCD%20and%20MIPI%20interface%2C%20total%203%20interfaces%20are%20for%20display.%20But%20actually%20i.MX%208M%20Mini%20only%20has%20one%20MIPI%20DSI%20interface.%20The%20other%20two%20LVDS%20interfaces%20are%20switched%20from%20DSI%20through%20one%20DS12LVDS%20bridge%20chip%2C%20one%20is%20single%20link%20LVDS%20and%20another%20is%20dual%20link%20LVDS.%20So%2C%20we%20can%20only%20select%20MIPI%20DSI%20display%20or%20LVDS%20display.%20Also%2C%20we%20can%20only%20select%20single%20link%20LVDS%20or%20dual%20link%20LVDS.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX08.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX08.png%22%20style%3D%22width%3A%20650px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110810i528FE8318C2717DC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MYDC8MMX08.png%22%20alt%3D%22MYDC8MMX08.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EMYIR%20offers%20optional%20LVDS%20based%207-inch%20LCD%20Module%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D634%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMY-LVDS070C%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eincluding%20capacitive%20touch%20screen%20to%20work%20with%20the%20MYD-C8MMX%20board.%20The%20display%20resolution%20is%20up%20to%26nbsp%3B1024%20by%20600%20pixels.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LVDS070C.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LVDS070C.png%22%20style%3D%22width%3A%20633px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110811iF2FAA44B54DE0FFA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22LVDS070C.png%22%20alt%3D%22LVDS070C.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20MY-LVDS070C%207-inch%20LCD%20Module%20with%20Capacitive%20Touch%20Screen%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%20MYD-C8MMX%20has%20one%202.0mm%20pitch%202*15-pin%20male%20expansion%20header.%20PDM%20and%20SAI%20are%20audio%20relative%20interfaces%20which%20are%20brought%20out%20from%20the%20expansion%20header.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX09.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MYDC8MMX09.png%22%20style%3D%22width%3A%20620px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110906i59249C03C286EDD1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MYDC8MMX09.png%22%20alt%3D%22MYDC8MMX09.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1109213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D617%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3EMYC-C8MMX%26nbsp%3BCPU%20Module%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3Eis%20designed%20by%3C%2FSTRONG%3E%20%3CSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3EMYIR%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3E%2C%20which%20is%20an%20ARM%20embedded%20System-on-Module%20(SoM)%20based%20on%3C%2FSTRONG%3E%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi-mx-applications-processors%2Fi-mx-8-processors%2Fi-mx-8m-mini-arm-cortex-a53-cortex-m4-audio-voice-video%3Ai.MX8MMINI%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3ENXP%E2%80%99%20i.MX%208M%20Mini%26nbsp%3BQuad%20Application%20Processor%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3E.%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D618%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3EMYD-C8MMX%20development%20board%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eis%20built%20around%20the%20MYC-C8MMX%20CPU%20Module%2C%20it%20is%20a%20complete%20evaluation%20module%20for%20your%20prototype%20and%20reference%20design.%20It%20is%20capable%20of%20running%20Linux%20and%20Android%20OS%20and%20provided%20with%20plenty%20of%20software%20resources.%20Typical%20applications%20are%20for%20Industry%20Control%2C%20Smart%20City%2C%20Smart%20Home%2C%20HMI%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%22%3EInternet%20of%20Things%20(IoT)%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eetc.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ELet%E2%80%99s%20see%20a%20video%20introduction%20of%20the%20MYD-C8MMX%20development%20board.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fyoutu.be%2FFL_CZiSMYsM%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fyoutu.be%2FFL_CZiSMYsM%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D617%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMYC-C8MMX%26nbsp%3BCPU%20Module%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3Eis%20using%20the%20MIMX8MM6CVTKZAA%20(MIMX8MM6DVTLZAA)%20processor%20chip%20which%20is%20among%20the%20NXP%20i.MX%208M%20Mini%20family%20and%20combines%20advanced%2014LPC%20FinFET%20process%20technology%20to%20provide%20more%20speed%20and%20improved%20power%20efficiency.%20It%20has%20a%20quad%20Cortex-A53%20core%20which%20operates%20at%20speeds%20of%20up%20to%201.6%20(1.8)%20GHz.%20It%20also%20has%20a%20general-purpose%20Cortex-M4%20400%20MHz%20core%20processor%20for%20low-power%20processing.%20Some%20parameters%20and%20target%20applications%20of%20the%20processor%20chip%20are%20listed%20below%20for%20reference.%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20style%3D%22width%3A%20839px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20%23e5eaed%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2010.0pt%3B%20%22%3EParameter%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20background%3A%20%23e5eaed%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2010.0pt%3B%20%22%3EValue%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ECore%3A%20Number%20of%20cores%20(SPEC)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ECore%20Type%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EArm%20Cortex-A53%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EOperating%20Frequency%20%5BMax%5D%20(MHz)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E1600%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EMIMX8MM6CVTKZAA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E)%2F1800%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EMIMX8MM6DVTLZAA)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EL2%20Cache%20(Max)%20(KB)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E512%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ECo-Processor%20Type%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EArm%20Cortex-M4F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ECo-Processor%20Frequency%20(MAX)%20(MHz)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E400%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EExternal%20Memory%20Supported%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EDDR3L%20SDRAM%2C%20DDR4%20SDRAM%2C%20ECC%2C%20LPDDR4%20DRAM%2C%20NAND%20FLASH%2C%20NOR%20FLASH%2C%20QSPI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23bfbfbf%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-left%3A%201pt%20solid%20%23bfbfbf%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20239px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EGPU%202D%20%2F%20GPU%203D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23bfbfbf%3B%20border-right%3A%201pt%20solid%20%23bfbfbf%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20569px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E1x%20shader%2C%20Vivante%20GC320%2C%20Vivante%20GCNanoUltra%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20%22%3EMIMX8MM6CVTKZAA%20(MIMX8MM6DVTLZAA)%26nbsp%3Bprocessor%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%20chip%20only%20has%20MIPI-DSI%20and%20MIPI-CSI%20interfaces%20and%20no%20HDMI%20or%20other%20display%20interfaces.%20It%20can%20support%20wide%20working%20temperature%20range%20from%20-40%20to%20105%20Celsius%20degree.%20MYIR%E2%80%99s%20MYC-C8MMX%20CPU%20Module%20can%20support%20working%20temperature%20from%20-40%20to%2085%20Celsius%20degree.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20style%3D%22width%3A%20823px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20%23e5eaed%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2010.0pt%3B%20%22%3EParameter%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20background%3A%20%23e5eaed%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2010.0pt%3B%20%22%3EValue%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EHW%20Video%20Encoder%20%2F%20Decoder%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EHD1080p60%20H.264%2C%20HD1080p60%20H.265%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EVideo%2FDisplay%20features%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EMIPI-CSI%2C%20MIPI-DSI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EPCIe%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EPCIe%202.0%20x%201%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EAudio%20Specific%20Modules%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E8-ch%20PDM%20input%2C%20SAI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EUSB%20Controllers%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3ESerial%20Communication%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E1%20x%20PCIe%202.0%2C3%20x%20SPI%2C4%20x%20I%C2%B2C%2C4%20x%20UART%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-right%3A%201pt%20solid%20%23d9d9d9%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-left%3A%201pt%20solid%20%23d9d9d9%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20223px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3EJunction%20Temperature%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E%E2%84%83%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20%23d9d9d9%3B%20border-right%3A%201pt%20solid%20%23d9d9d9%3B%20background%3A%20white%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20568px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2320272d%3B%22%3E-40%20to%20105%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EMIMX8MM6CVTKZAA)%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3E0%20to%2095%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20%22%3EMIMX8MM6DVTLZAA)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20%22%3EMIMX8MM6CVTKZAA%20(MIMX8MM6DVTLZAA)%26nbsp%3Bprocessor%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20width%3D%22640%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20colspan%3D%222%22%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22640%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2012.0pt%3B%20%22%3ETarget%20Applications%20of%20i.MX%208M%20Mini%20Processors%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3EAutomotive%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3ESmart%20City%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHeating%20Ventilation%2C%20and%20Air%20Conditioning%20(HVAC)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAutomatic%20Vehicle%20Identification%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMotorcycle%20Engine%20Control%20Unit%20(ECU)%20and%20Small%20Engine%20Control%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EFleet%20Management%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EInventory%20and%20Supply%20Chain%20Management%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3EIndustrial%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EPublic%20Address%20Systems%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAir%20Conditioning%20(AC)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETransport%20Ticketing%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EBuilding%20Safety%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EBuilding%20Security%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3ESmart%20Home%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EDigital%20Signage%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAudio%2FVideo%20(AV)%20Receivers%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EEnergy%20Gateway%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EGaming%20Console%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHeat%20Metering%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHome%20Control%20Panel%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHospital%20Admission%20Machine%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHome%20Security%20%26amp%3B%20Surveillance%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EImage%20Analytics%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHome%20Sensor%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EIndustrial%20Control%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EIn-Home%20Energy%20Display%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EIndustrial%20HMI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMajor%20Home%20Appliances%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMachine%20Visual%20Inspection%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ERobotic%20Appliance%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmart%20Lighting%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESet%20Top%20Boxes%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmart%20Power%20Socket%20and%20Light%20Switch%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmall%20and%20Medium%20Appliances%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETwo-way%20Video%20Conferencing%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmart%20Speaker%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EVision%2C%20Advanced%20Sensing%20and%20Processing%20Board%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESoundbar%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESurround%20Sound%20and%20Sound%20Bars%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3EMobile%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EWireless%20or%20Networked%20Speakers%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECable%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EHearables%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.0pt%3B%20%22%3ETechnologies%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EInput%20Device%20(Mouse%2C%20Pen%2C%20Keyboard)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EVoice%20Assistants%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESmart%20Watch%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EVoice%20Control%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EWireless%20Charging%20Pad%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22383%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EWristband%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20%23D9D9D9%201.0pt%3B%20border-right%3A%20solid%20%23D9D9D9%201.0pt%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%20width%3D%22257%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%80%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D617%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20background%3A%20white%3B%22%3EMYC-C8MMX%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3ECPU%20Module%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eis%20a%20minimum%20system%20with%20PMIC%2C%20CPU%2C%20RAM%20(DDR4)%2C%20Flash%20(eMMC%2C%20SPI%20Flash)%20and%20clock%2C%20plus%20an%20Ethernet%20PHY%20chip.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EA%20number%20of%20peripheral%20and%20IO%20signals%20are%20access%20through%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3Etwo%200.8mm%20pitch%20100-pin%20board-to-board%20expansion%20connectors%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CIMG%20alt%3D%22%22%20src%3D%22http%3A%2F%2Fwww.myirtech.com%2Fattached%2Fimage%2F20190813%2Fmyc-c8mmx400tm.jpg%22%20style%3D%22border%3A%20none%3B%22%20%2F%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CIMG%20alt%3D%22%22%20src%3D%22http%3A%2F%2Fwww.myirtech.com%2Fattached%2Fimage%2F20190813%2Fmyc-c8mmx260b.jpg%22%20style%3D%22border%3A%20none%3B%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3CEM%3EMYC-C8MMX%20CPU%20Module%20Top-view%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BMYC-C8MMX%20CPU%20Module%20Bottom-view%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2012px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EThe%20MYD-C8MMX%20base%20board%20has%20mainly%20extended%20four%20parts%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E1.%20Audio%20interface%3A%20added%20audio%20chip%20to%20extend%20Audio%20input%20and%20output%20interfaces%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E2.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3EExternal%20power%20supply%20part%3A%20added%20one%20DC-DC%20power%20chip%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E3.%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAdded%20one%20USB%20hub%20chip%20to%20extend%204%20USB%20from%20the%20SoC%20USB%20interface%2C%20separately%20used%20for%204G%20LTE%2C%20two%20USB%20Host%20and%20one%20USB%20on%20expansion%20header.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E4.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3EExtend%20RTC%20module%20through%20I2C%20interface%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-indent%3A%20-18pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EMany%20other%20peripheral%20interfaces%20are%20brought%20out%20for%20user%20extension.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BMYD-C8MMX%20Function%20Block%20Diagram%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FEM%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BMYD-C8MMX%20Interface%26nbsp%3BDiagram%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3EAmong%20so%20many%20interfaces%2C%20Backlight%2C%20LVDS%20LCD%20and%20MIPI%20interface%20are%20relative%20to%20display%20function.%20The%20Backlight%20interface%20has%206%20pins%20including%20two%20power%20signals%2C%20two%20GND%20and%20two%20GPIO%20(one%20is%20enabled%20terminal%20to%20control%20the%20backlight%20power%20and%20another%20is%20PWM%20to%20control%20the%20brightness%20of%20backlight.)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EThe%20two%20GPIO%20control%20terminals%20are%20from%20the%20GPIO1_01%20and%2008%20of%20the%20i.MX%208M%20Mini.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EThe%20LVDS%20LCD%20and%20MIPI%20interface%2C%20total%203%20interfaces%20are%20for%20display.%20But%20actually%20i.MX%208M%20Mini%20only%20has%20one%20MIPI%20DSI%20interface.%20The%20other%20two%20LVDS%20interfaces%20are%20switched%20from%20DSI%20through%20one%20DS12LVDS%20bridge%20chip%2C%20one%20is%20single%20link%20LVDS%20and%20another%20is%20dual%20link%20LVDS.%20So%2C%20we%20can%20only%20select%20MIPI%20DSI%20display%20or%20LVDS%20display.%20Also%2C%20we%20can%20only%20select%20single%20link%20LVDS%20or%20dual%20link%20LVDS.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EMYIR%20offers%20optional%20LVDS%20based%207-inch%20LCD%20Module%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.myirtech.com%2Flist.asp%3Fid%3D634%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMY-LVDS070C%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eincluding%20capacitive%20touch%20screen%20to%20work%20with%20the%20MYD-C8MMX%20board.%20The%20display%20resolution%20is%20up%20to%26nbsp%3B1024%20by%20600%20pixels.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CEM%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20MY-LVDS070C%207-inch%20LCD%20Module%20with%20Capacitive%20Touch%20Screen%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EThe%20MYD-C8MMX%20has%20one%202.0mm%20pitch%202*15-pin%20male%20expansion%20header.%20PDM%20and%20SAI%20are%20audio%20relative%20interfaces%20which%20are%20brought%20out%20from%20the%20expansion%20header.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200cm%200cm%2016.8pt%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0CBF4B305FA47E4E51CF451005BF743F%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E
No ratings
Version history
Last update:
‎08-25-2020 11:27 PM
Updated by:
