XMCD setting sample program
ソリューションへジャンプ
4,083件の閲覧回数
takayuki_ishii
Contributor V
Hello community.
My customer try to build boot image.
In the process, we are investigating XMCD.
Is there a sample program that uses XMCD as described in 10.8 of the reference manual?
I look forward to hearing from you.
Ishii.
タグ(1)
4,074件の閲覧回数
kerryzhou
Hi @takayuki_ishii ,
   I have an example use the XMCD function to init SDRAM, please check the following code for IAR version.
Wish it helps you!
Kerry
3 返答(返信)
4,063件の閲覧回数
takayuki_ishii
Contributor V
Hello @kerryzhou
Sorry my miss reply.
I understand that I must change my dcd_data[] in dcd.c like this parameter.
I will try to modify and test it in my project.
Ishii.
4,075件の閲覧回数
kerryzhou
Wish it helps you!
Kerry
4,068件の閲覧回数
takayuki_ishii
Contributor V
Hello @kerryzhou
Thank you for your quick reply.
Is this sample in MCUXpresso SDK demo?
If so, please teach me a sample project name.
If no, please attach your project if it is ok to upload it.
Ishii.
