I'm using rt1050 usb_device_cdc_vcom demo and trying to modify HS_CDC_VCOM_BULK_OUT_PACKET_SIZE from
64 to 2048 or larger.
It work's fine when the value is set to 1024.
After change it to 2048 , it sucked while transmit data out.
Is there any limitation ?
