I am attempting to manually create a USB descriptor for two devices behind a single USB Audio Class 2.0 connection. Does anyone know whether or not the Terminals, Clock and Unit should all be unique IDs when utilizing multiple Interface Association Descriptors (IAD)? I would assume so. Does anyone have a working example of this type of descriptor?
Below is my attempt however the linux host has complaints. Is there someone with experience in this area to review the descriptor below? Thank you.
Mark
Bus 001 Device 029: ID 1fc9:00a4 NXP Semiconductors
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x1fc9 NXP Semiconductors
idProduct 0x00a4
bcdDevice 1.01
iManufacturer 1
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x01f3
bNumInterfaces 6
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 0
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 32
iInterface 0
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 2.00
bCategory 4
wTotalLength 0x006f
bmControls 0x00
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 16
bmAttributes 3 Internal programmable clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 0
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bCSourceID 16
bNrChannels 2
bmChannelConfig 0x00000003
Front Left (FL)
Front Right (FR)
iChannelNames 0
bmControls 0x0000
iTerminal 0
bLength 18
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 2
bSourceID 1
bmaControls(0) 0x00000000
bmaControls(1) 0x00000000
bmaControls(2) 0x00000000
iFeature 0
bLength 12
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 2
bCSourceID 16
bmControls 0x0000
iTerminal 0
bLength 17
bDescriptorType 36
bTerminalID 4
bAssocTerminal 0
bCSourceID 16
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bmControls 0x0000
iTerminal 0
bLength 18
bDescriptorType 36
bUnitID 5
bSourceID 4
bmaControls(0) 0x0000000f
Mute Control (read/write)
Volume Control (read/write)
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 6
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 5
bCSourceID 16
bmControls 0x0000
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 16
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 3
bmControls 0x00
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bSubslotSize 2
bBitResolution 16
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 13
Transfer Type Isochronous
Synch Type Synchronous
Usage Type Data
wMaxPacketSize 0x00c4 1x 196 bytes
bInterval 4
AudioStreaming Endpoint Descriptor:
bLength 8
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 0 Undefined
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 4
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 5
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x001c 1x 28 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0000
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 17
Synch Type None
Usage Type Feedback
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 4
bLength 8
bDescriptorType 11
bFirstInterface 3
bInterfaceCount 3
bFunctionSubClass 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 4
wTotalLength 0x006f
bmControls 0x00
bLength 8
bDescriptorType 36
bClockID 17
bmControls 0x07
bAssocTerminal 0
iClockSource 0
bLength 17
bDescriptorType 36
bTerminalID 7
bAssocTerminal 0
bCSourceID 17
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bmControls 0x0000
iTerminal 0
bLength 18
bDescriptorType 36
bUnitID 8
bSourceID 7
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 9
bAssocTerminal 0
bSourceID 8
bCSourceID 17
bmControls 0x0000
iTerminal 0
bLength 17
bDescriptorType 36
bTerminalID 10
bAssocTerminal 0
bCSourceID 17
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bmControls 0x0000
iTerminal 0
bLength 18
bDescriptorType 36
bUnitID 11
bSourceID 10
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 12
bAssocTerminal 0
bSourceID 11
bCSourceID 17
bmControls 0x0000
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 9
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 13
Usage Type Data
wMaxPacketSize 0x00c0 1x 192 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 10
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0000
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 17
Synch Type None
Usage Type Feedback
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 16
