MCU-Link Debug Probe Issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
We are using imx rt1176 evk. Onboard debugger are working. But we have to use MCU-Link Debug Probe. Debugger Link
When I try to debugging with the MCU Link debug probe, I get an error like
in the pictures.
How can i solve this problem ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Im using RT1170 EVK and SWD interface. I removed J6 J7 but still same error.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello, I suggest use an adapter to use the JTAG port as a SWD flavor. I made a document related to this issue; I hope this explain more.
Pavel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @BTasdemir
you are using the wrong JTAG interface. This one is to debug the onboard Freelink Interface (the LPC4322 controller)
You need to use the 20-Pin JTAG interface.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for reply
How can i use 20 pin jtag with this cable ? am i need converter ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @BTasdemir
there adapter available. For example
https://www.segger.com/products/debug-probes/j-link/accessories/adapters/9-pin-cortex-m-adapter/
https://www.adafruit.com/product/2094
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you are using RT1170 EVK, please remove J6 and J7.
if you are using RT1170 EVKB, please add a jumper on JP5.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello, my name is Pavel, and I will be supporting your case, I do not if you are using your MCU Link in the right interface, could you please elaborate further about the connector you are using for communicating the external debugger? please review the document.
Pavel
