Hi @stq001 ,
Thank you for your interest in the NXP MIMXRT product, I would like to provide serivce for you.
1. Before you introduce the 19MB data to the project, you need to make sure your used flash is enough to use.
The original evkmimxrt1170_lvgl_guider_cm7 project, default flash size is 16MB, do you modify it to larger size?
It's better to share your memory detials situation.
2. About the stuttering and freezing state
This is caused by the IDE is in the building status, to this situation, normally, when you click the build, don't click the IDE any button anymore, just let the IDE do the build by itself, it may need more time.
In fact, even you build original evkmimxrt1170_lvgl_guider_cm7 project, it also needs time, not quickly.
From my own experience, if during the large project building, click the IDE window, it may cuase the stuttering and freezing state, so I won't click the IDE window after I do the build.
If your flash size is large enough in your IDE settings, you can try my method again, just wait, after the build finished, the IDE will be normal again.
Wish it helps you!
Any updated information, please kindly let me know.
Kerry
