Hi NXP team
I want to move some high frequency functions from flash to the sram, in order to running in the sram which can reduce the cpu loading.
But I found it only can modify it in the settings, if I choose the "Link application to RAM", it will push all the flash code to the ram.
If I use the "Extra linker script input sections", I don't know how to specify a cpp file and then compile .o file move it to the sram.
I also found the .ld file was generated, and couldn't edit.
Could you tell me how to modify the code?
Thanks!
