Hi @ingdb
Thanks a lot for your patience, and again, for reporting this bug.
We further reproduced this issue internally with the SDK 2.14.0
Our MCUXpresso IDE and SDK team is now aware of this bug. Given the fact that we just released SDK 2.14 and IDE 11.8. We will need to wait a bit to get this error corrected in the SDK, I pressume a minor release.
To workarround this situation, currently, I have some suggestions:
A For development use the RT1172 SDK 2.13.1 that I shared to you by your salesforce ticket.
B to use SDK 2.14.0 : Create a project from the RT1172 SDK 2.13.1 drivers including the USB middleware. Create your SDK 2.14.0 project without the drivers. Unzip the SDK 2.14.0 somewhere else, and manually copy and paste drivers, files and adrresses.
We will check the manifest file from the SDK. Maybe this is the reason of the issue. Our Investigation is going on. As soon I get more news I will update you.
Thank you for your understanding.
Diego
