iMXRT1050 board configuration to enable ARM trace
656 次查看
Guillermo_Gonzalez
Hi all,
I'm planning to use tracing pins for the board IMXRT1050-EVKB (with MCU MIMXRT1052 DVL6B). I found a NXP file that explains how to enable the ETM in the iMXRT10xx Serie by welding some resistors. The problem is that for some pins it mentions some resistors numbers that are not in the board (R592, R583, R547 and R688) (page 8).
I tried to search them in the schematic and the layout from the design files, however the ones that were available from the NXP websites were from REV B1 and my board is REV A1 (SCH-30168 REV A1).
So I wanted to ask for the design files for REV A1 and also an explanation of the resistors numbers that I couldn't find in the board.
标签 (1)
0 回复数
