What is the purpose of verification index and target index in Install Key section
1,508 次查看
jomonthomas
I am trying to analyze the boot image authentication .bd file (using i.MXRT1172), and i have some doubts regarding the InstallSRK_SourceIndex, InstallKey_VerificationIndex and InstallKey_TargetIndex.
In my understanding Source Index is the index of the key table file. But still I didn't understand the concept of the Verification Index and Target Index. Where from can i get the details of this.
currently i am using certificate CSF1_1_sha256_2048_65537_v3_usr_crt.pem and IMG1_1_sha256_2048_65537_v3_usr_crt.pem and using  InstallSRK_SourceIndex=0, InstallKey_VerificationIndex=0, InstallKey_TargetIndex=2.
And what will be the value of SourceIndex, VerificationIndex, TargetIndex if i use the certificates  CSF2_1_sha256_2048_65537_v3_usr_crt.pem and IMG2_1_sha256_2048_65537_v3_usr_crt.pem
1,502 次查看
jeremyzhou
Hi @jomonthomas ,
I was wondering if you can share the .bd file, further, can you introduce where you get it?
TIC
1,495 次查看
jomonthomas
Can we get your email id, to sent it directly
1,488 次查看
jeremyzhou
Thanks for your reply.
I find a case for your question, I think the case was created by you, and you can send the .bd file by giving the reply to the case.
TIC
