USB CDC ECM example code for the MIMXRT1170-EVK
1,857 次查看
sameer_imxrt
I am looking for the USB CDC ECM example for the MIMXRT1170-EVK. I check following link but it not contain example for MIMXRT1170-EVK. It have example for USB CDC only. So please suggest for same.
 https://github.com/nxp-mcuxpresso/mcuxsdk-examples//blob/release/24.12.00/_boards/evkbmimxrt1170/dri...
4 回复数
1,847 次查看
sameer_imxrt
Hi, any demo code for USB CDC ACM for IMXRT1170?? Actually, we are already using the USB RNDIS for communicating with a linux device. But now, linux community removing support for same so we are searching for alternative. If you can suggest any alternative, then it is very helpful.
1,798 次查看
Gavin_Jia
Hi @sameer_imxrt ,
The examples host_cdc in SDK support ACM but don't support ECM. The full SDK is available here:https://mcuxpresso.nxp.com/en/select
In addition, NXP provides a USB application note for RT series MCUs to enable customized classes: https://docs.nxp.com/bundle/AN14169/page/topics/introduction.html
Gavin
1,830 次查看
sameer_imxrt
Any alternative method which is similar to USB RNDIS and example code are available for  the MIMXRT1170-EVK
1,851 次查看
Gavin_Jia
Hi @sameer_imxrt ,
Thanks for your interest in NXP MIMXRT series!
MIMXRT1170-EVK has host CDC ACM demo and also has host RNDIS demo which is in SDKRoot\boards\evkmimxrt1170\lwip_examples\lwip_dhcp_usb\freertos. But we haven't ECM demo. BTW, this AN from the RT series may be helpful:  https://www.nxp.com/docs/en/application-note/AN13940.pdf
Gavin
