The usb_msc_cdc example cannot recognize the virtual serial port.
189 次查看
zhangyuanhe
When I used the 1052 SDK version 2.15, mcuPresso IDE, and the usb_msc_cdc example, I found that the computer could only correctly recognize the USB drive but could not correctly recognize the virtual serial port.
标记 (2)
170 次查看
Gavin_Jia
Hi @zhangyuanhe ,
Thanks for your interest in NXP MIMXRT series!
I tested on my side and it worked fine.
It is also recommended that you try installing the driver mentioned in the "Installing the CDC driver for virtual_com and msd_cdc composite example" section of the readme. Or find it in the device manager and uninstall and reinstall it.
Gavin
155 次查看
zhangyuanhe
Hi,@Gavin_Jia,
Thank you for your answer. After I installed its driver, it is now working properly.
Can it install the driver automatically? If I switch to another computer, will I have to reinstall the driver.
zhangyuanhe
