RTC in SLN-VIZN-IOT
RTC in SLN-VIZN-IOT
kevin_hector
I'm working on the SLN-VIZN-IOT and I need a calendar to program some functionalities, so the kit is it eqquiped of a RTC ( real time clock ) ?
Thank you for your futur response.
Sabina_Bruce
Hello Kevin,
Hope you are doing well.
You may refer to the RTC details from the RT1060 family datasheet and reference manual. If the RTC does not satisfy the requirements for your application you may also consider checking the external RTCs available.
https://www.nxp.com/products/peripherals-and-logic/signal-chain/real-time-clocks:MC_71246
Sabina
