RT600 - SWD interface
1,910 次查看
nrajagopal
Hi All,
Had a question about SWD interface on RT600. Do we need specific RST signal for SWD interface to be asserted by the debugger tool?
As I know on other MCUs, we have used PON system/Reset controlled over GPIO/Reset over SW commands on SWD.    Please clarify if this holds good for RT600 or not.
Thanks!
Lakshmi
1,839 次查看
victorjimenez
Hello Lakshmi,
We would strongly recommend also including RESET in addition to SWDIO, CLK, and GND. For debugging, the tools may try to pull this in certain circumstances (depending upon debug probe, debug configuration settings, and tools).
You might find the following community document useful: Design Considerations for Debug
Victor
- If this post answers your question, please click the "Mark Correct"button. Thank you!
