I am having a problem bringing up my RT1171 processor design with the 24 MHz oscillator not running. I found in the datasheet that the oscillator is part of the LPSR_ANA domain. The oscillator section does not seem to have power as the pins on the crystal are both low when power is applied to the board.
See the attached document with a description and blocks of my schematic.
Thanks for your help!
Solved! Go to Solution.
