RT1176 – Enabling XIP beyond 16MB using 4-byte addressing
2,000件の閲覧回数
Anni
I am using i.MX RT1176 with a 64MB QSPI NOR flash (IS25LP512MJ). XIP works perfectly when the FlexSPI LUT uses 3-byte address read instructions but fails when the LUT is changed to use 4-byte addressing mode for accessing memory beyond 16MB.
My question is: what additional configuration is required on RT1176 to enable XIP beyond 16MB when using 4-byte addressing? Any reference or known-good configuration for 64MB XIP on RT1176 would be helpful.
1,966件の閲覧回数
Gavin_Jia
Hi @Anni ,
Thanks for your interest in NXP MIMXRT series!
This post is a good reference for the issue: https://community.nxp.com/t5/i-MX-RT-Crossover-MCUs/Add-4-byte-addressing-to-FLEXSPI-flash-driver/m-...
And you can refer RT1170 EVKB's SDK. On RT1170 EVKB, the on-board flash is a 512Mb QSPI flash and the SDK enabled the 4 bytes mode by default. Modify the corresponding 3-byte address command to a 4-byte address command.
Gavin
2 返答(返信)
1,967件の閲覧回数
Gavin_Jia
Hi @Anni ,
Gavin
1,954件の閲覧回数
Anni
Thank you for the reference and guidance. The information you shared was helpful, and the issue is now resolved.
%3CLINGO-SUB%20id%3D%22lingo-sub-2267807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1176%20%E2%80%93%204%E3%83%90%E3%82%A4%E3%83%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A616MB%E3%82%92%E8%B6%85%E3%81%88%E3%82%8BXIP%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E64MB%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20(IS25LP512MJ)%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%20i.MX%20RT1176%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82XIP%20%E3%81%AF%E3%80%81FlexSPI%20LUT%20%E3%81%8C%203%20%E3%83%90%E3%82%A4%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%91%BD%E4%BB%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%8116%20MB%20%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20LUT%20%E3%81%8C%204%20%E3%83%90%E3%82%A4%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%814%20%E3%83%90%E3%82%A4%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%2016%20MB%20%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%20XIP%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81RT1176%20%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%BF%BD%E5%8A%A0%E6%A7%8B%E6%88%90%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82RT1176%20%E4%B8%8A%E3%81%AE%2064MB%20XIP%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%82%84%E6%97%A2%E7%9F%A5%E3%81%AE%E8%89%AF%E5%A5%BD%E3%81%AA%E6%A7%8B%E6%88%90%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1176%20%E2%80%93%20Enabling%20XIP%20beyond%2016MB%20using%204-byte%20addressing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%A8%E3%81%94%E6%8C%87%E5%B0%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E6%83%85%E5%A0%B1%E3%81%AF%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1176%20%E2%80%93%20Enabling%20XIP%20beyond%2016MB%20using%204-byte%20addressing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252300%22%20target%3D%22_blank%22%3E%40Anni%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3ENXP%20MIMXRT%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AB%E3%81%94%E8%88%88%E5%91%B3%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FAdd-4-byte-addressing-to-FLEXSPI-flash-driver%2Fm-p%2F1579246%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FAdd-4-byte-addressing-to-FLEXSPI-flash-driver%2Fmp%2F1579246%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81RT1170%20EVKB%20%E3%81%AE%20SDK%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82RT1170%20EVKB%20%E3%81%A7%E3%81%AF%E3%80%81%E6%90%AD%E8%BC%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%20512Mb%20QSPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81SDK%20%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%204%20%E3%83%90%E3%82%A4%E3%83%88%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%203%20%E3%83%90%E3%82%A4%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%204%20%E3%83%90%E3%82%A4%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%AE%E3%83%A3%E3%83%93%E3%83%B3%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
