RT1170 EVKB Multicore project and LinkServer Flash programmer not working (mcuxpresso vs code)
2,051件の閲覧回数
cyberhelmer
I have a project based on the freeRTOS multicore message buffers example from nxp SDK.
There seem to be a problem with the LinkServer Flash Programmer in the mcuxpresso for vs code extension.
I am sometimes able to flash the m7 firmware which loads the M4 to the correct ocram adress. Very often the flash programmer fails and the board stops running it's code.
What is the cause of this and how can I fix it so that I'm always able to flash the m7 correctly?
Thanks!
Log when failing:
2025-09-18T00:58:40.377] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T00:58:40.379] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T00:58:40.380] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T00:58:41.772] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T00:58:41.773] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T00:58:41.773] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T00:58:44.950] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T00:58:48.405] [proc] [error] /Applications/LinkServer_25.7.33/LinkServer exited with code 255
[2025-09-18T00:58:48.405] [proc] [error] Firmware update `check`: not required - forced update can be performed using: `./LinkServer probe #1 update forced`
Ns: LinkServer RedlinkMulti Driver v25.7 (Jul 21 2025 20:37:00 - crt_emu_cm_redlink build 1038)
Pc: ( 0) Reading remote configuration
Wc(03). No cache support.
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmp3tmcfgxp/crt_directory.xml
Pc: ( 5) Remote configuration complete
Nc: Reconnected to existing LinkServer process.
Wc: ============= SCRIPT: RT1170_connect_M7_wake_M4.scp =============
Wc: RT1170 Connect M7 and Wake M4 Script
Wc: DpID = 6BA02477
Wc: APID = 0x84770001
Wc: Setting M4 spin code
Wc: Setting M4 clock
Wc: Resetting M4 core
Wc: View cores on the DAP AP
Wc: DpID = 6BA02477
Wc: TAP 0: 6BA02477 Core 0: M7 APID: 84770001 ROM Table: E00FD003*
Wc: TAP 0: 6BA02477 Core 1: M4 APID: 24770011 ROM Table: E00FF003
Wc: ============= END SCRIPT ========================================
Nc: Probe Firmware: MCU-LINK on-board (r0E2) CMSIS-DAP V3.160 (NXP Semiconductors)
Nc: Serial Number: H3RHID4AC30FD
Nc: VID:PID: 1FC9:0143
Nc: USB Path: 0014:0002:00
Nc: Using memory from core 0 after searching for a good core
Pc: ( 30) Emulator Connected
Pc: ( 40) Debug Halt
Pc: ( 50) CPU ID
Nc: debug interface type = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
Nc: processor type = Cortex-M7 (CPU ID 00000C27) on DAP AP 0
Nc: number of h/w breakpoints = 8
Nc: number of flash patches = 0
Nc: number of h/w watchpoints = 4
Nc: Probe(0 Connected&Reset. DpID: 6BA02477. CpuID: 00000C27. Info: <None>
Nc: Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Ns: Content of CoreSight Debug ROM(s):
Nc: RBASE E00FD000: CID B105100D PID 000008E88C ROM (type 0x1)
Nc: ROM 1 E00FE000: CID B105100D PID 04000BB4C8 ROM (type 0x1)
Nc: ROM 2 E00FF000: CID B105100D PID 04000BB4C7 ROM (type 0x1)
Nc: ROM 3 E000E000: CID B105E00D PID 04000BB00C Gen SCS (type 0x0)
Nc: ROM 3 E0001000: CID B105E00D PID 04000BB002 Gen DWT (type 0x0)
Nc: ROM 3 E0002000: CID B105E00D PID 04000BB00E Gen (type 0x0)
Nc: ROM 3 E0000000: CID B105E00D PID 04000BB001 Gen ITM (type 0x0)
Nc: ROM 2 E0041000: CID B105900D PID 04001BB975 CSt ARM ETMv4.0 type 0x13 Trace Source - Core
Nc: ROM 2 E0042000: CID B105900D PID 04004BB906 CSt type 0x14 Debug Control - Trigger, e.g. ECT
Nc: ROM 1 E0043000: CID B105900D PID 04001BB908 CSt CSTF type 0x12 Trace Link - Trace funnel/router
Nc: NXP: MIMXRT1176xxxxx
Nc: DAP stride is 1024 bytes (256 words)
Nc: Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MIMXRT1170_SFDP_QSPI.cfx
Nc: Image 'iMXRT1170_SFDP_FlexSPI1_A_QSPI Jul 21 2025 18:35:07'
Nc: Opening flash driver MIMXRT1170_SFDP_QSPI.cfx
Nc: Sending VECTRESET to run flash driver
Nc: Flash variant 'iMXRT1170_SFDP_FlexSPI1_A_QSPI Jul 21 2025 18:35:07' detected (64MB = 1024*64K at 0x30000000)
Nc: Closing flash driver MIMXRT1170_SFDP_QSPI.cfx
Pc: ( 65) Chip Setup Complete
Pc: ( 70) License Check Complete
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30000400 len 0x200
Nc: Opening flash driver MIMXRT1170_SFDP_QSPI.cfx (already resident)
Nc: Warning - failed to start flash driver (at 0x2000009D?) - rc Nn(05). Wire ACK Fault in DAP access
Nc: Flash Driver V.2 startup failed - rc Nn(05). Wire ACK Fault in DAP access
Pb: (100) Writing Flash ended with an error.
Ed:05: File 'freertos_message_buffers_primary_core.elf' load failure: Nn(05). Wire ACK Fault in DAP access
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30001000 len 0x30
Nc: request to clear DAP error failed - status 5
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30002000 len 0x12044
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x33FC0000 len 0x7144
Pc: (100) Target Operation Failed
Nc: error closing down debug session - Nn(05). Wire ACK Fault in DAP access
INFO: Exact match for MIMXRT1176xxxxx:MIMXRT1170-EVKB found
INFO: Selected device MIMXRT1176xxxxx:MIMXRT1170-EVKB
INFO: Getting available probes
INFO: Selecting probe by serial substring
INFO: Selected probe #1 H3RHID4AC30FD (MCU-LINK on-board (r0E2) CMSIS-DAP V3.160)
INFO: MCU-Link firmware update `check`: Probe ([H3RHID4AC30FD] [MCU-LINK on-board (r0E2) CMSIS-DAP V3.160]) is already running the same firmware version as the included firmware version [3.160]
CRITICAL: Critical error
ERRMSG: Exception: Flash operation exited with code 1
This is the log when the flashing actually succeeds:
[2025-09-18T01:03:12.927] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T01:03:12.928] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T01:03:12.928] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T01:03:14.329] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T01:03:14.338] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T01:03:14.346] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T01:03:17.511] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T01:03:23.784] [proc] [info] INFO: Exact match for MIMXRT1176xxxxx:MIMXRT1170-EVKB found
[2025-09-18T01:03:23.784] [LinkServer] [info] LinkServer flash operation completed successfully:
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmpci6yg1l_/crt_directory.xml
Wc: DpID = 6BA02477
Wc: Releasing M4
Wc: DpID = 6BA02477
Pc: ( 50) CPU ID
Pb: 1 of 1 ( 0) Writing sectors 0-0 at 0x30000400 with 512 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/1536
Ps: (100) at 30000000: 16384 bytes - 16384/1536
Nc: 30004000 done 100% (16384 out of 1536)
Nc: Sectors written: 1, unchanged: 0, total: 1
Pb: (100) Finished writing Flash successfully.
Nt: Loaded 0x200 bytes in 295ms (about 1kB/s)
Pb: 1 of 1 ( 0) Writing sectors 0-0 at 0x30001000 with 48 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/4144
Ps: (100) at 30000000: 16384 bytes - 16384/4144
Nc: 30004000 done 100% (16384 out of 4144)
Nt: Loaded 0x30 bytes in 310ms (about 0kB/s)
Pb: 1 of 1 ( 0) Writing sectors 0-1 at 0x30002000 with 73796 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/81988
Ps: ( 19) at 30000000: 16384 bytes - 16384/81988
Nc: 30004000 done 19% (16384 out of 81988)
Ps: ( 39) at 30004000: 16384 bytes - 32768/81988
Nc: 30008000 done 39% (32768 out of 81988)
Ps: ( 59) at 30008000: 16384 bytes - 49152/81988
Nc: 3000C000 done 59% (49152 out of 81988)
Ps: ( 79) at 3000C000: 16384 bytes - 65536/81988
Nc: 30010000 done 79% (65536 out of 81988)
Ps: (100) at 30010000: 65536 bytes - 131072/81988
Nc: Sectors written: 1, unchanged: 1, total: 2
Nt: Loaded 0x12044 bytes in 499ms (about 147kB/s)
Pb: 1 of 1 ( 0) Writing sectors 1020-1020 at 0x33FC0000 with 28996 bytes
Ps: ( 0) at 33FC0000: 0 bytes - 0/28996
Ps: ( 56) at 33FC0000: 16384 bytes - 16384/28996
Nc: 33FC4000 done 56% (16384 out of 28996)
Ps: (100) at 33FC4000: 16384 bytes - 32768/28996
Nc: 33FC8000 done 100% (32768 out of 28996)
Nt: Loaded 0x7144 bytes in 550ms (about 52kB/s)
Nt: Reset target (system)
Wc: ============= SCRIPT: RT1170_reset.scp =============
Wc: This probe = 1
Wc: This TAP = 0
Wc: This core = 0
Wc: SYSTEM Reset
Wc: Wirespeed = 10000000 Hz
Wc: DpID = 6BA02477
Wc: TAP 0: 6BA02477 AP 1: APID: 24770011 ROM Table: E00FF003
Wc: TAP 0: 6BA02477 AP 2: APID: 54770002 ROM Table: 00000002
Wc: Releasing M4
Wc: DpID = 6BA02477
Wc: R15 = 0x00223104
Wc: Vector table SP/PC is the reset context.
Wc: PC = 0x3000247D
Wc: SP = 0x20040000
Wc: XPSR = 0x01000000
Wc: VTOR = 0x30002000
Wc: Set DEMCR = 0x010007F1
Ns: Stopped: Halt
Ns: restart on reset
3 返答(返信)
2,045件の閲覧回数
cyberhelmer
Also, sometimes when I make changes to both cores and do a clean and rebuild of both projects only the m7 is updated with the correct code, m4 still runs an older version.
2,018件の閲覧回数
Gavin_Jia
Hi @cyberhelmer ,
Thanks for  your interest in NXP MIMXRT series!
During the failed operation, I noticed it was missing from the logs:
Releasing M4
This led to subsequent failures. We recommend updating the MCU-Link firmware and performing the following operation when debugging or programming again:
On the other hand, based on my personal experience, using JLink firmware provides better stability. If possible, try replacing the MCU-Link firmware with JLink firmware.
Gavin
2,004件の閲覧回数
cyberhelmer
I do have have latest firmware for the MCU-Link.
Resetting the probe before a flash as you suggested does not make a difference unfortunately. Still get this error most of the time:
[2025-09-18T09:09:34.034] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:09:34.035] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:09:34.035] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:09:35.433] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.436] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.458] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.470] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.481] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.482] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:10:30.963] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:10:30.965] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:10:30.966] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:10:32.425] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:10:32.426] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:10:32.427] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:10:35.933] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T09:10:39.480] [proc] [error] /Applications/LinkServer_25.7.33/LinkServer exited with code 255
[2025-09-18T09:10:39.480] [proc] [error] Firmware update `check`: not required - forced update can be performed using: `./LinkServer probe #1 update forced`
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmps1gdrldt/crt_directory.xml
Wc: DpID = 6BA02477
Wc: DpID = 6BA02477
Nc: USB Path: 0014:0003:00
Pc: ( 50) CPU ID
Nc: After error Nn(05). Wire ACK Fault in DAP access -
Nc: Failed to read address register in DAP - Nn(05). Wire ACK Fault in DAP access
Nc: flash driver polled mailbox (8 bytes at 0x2000A840) read failed (on poll 1/301) - retrying after 1ms - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Wc: flash driver polled mailbox (8 bytes at 0x2000A840) read failed (on poll 1/301) - halting for postmortem - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Wc: failed to halt target for postmortem - rc Nn(05). Wire ACK Fault in DAP access
Nc: failed to read registers - Nn(05). Wire ACK Fault in DAP access
Nc: Flash Driver V.2 startup failed - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Ed:05: File 'freertos_message_buffers_primary_core.elf' load failure: Em(17). Debug port inaccessible after access at location 0x2000A840
Also I've noticed that when when the flashing actually succeeds the M4 core is most of the time one or more versions behind even though I do a clean and rebuild of both projects before flashing. However sometimes, seemingly randomly both cores does get the correct version.
This is the build log:
Executing task: CMake: build M4
Workspace is /Users/melker/CodeProjects/AudioBox/code/code_secondary_core
build task started....
/Users/melker/.mcuxpressotools/cmake-3.30.0-macos10.10-universal/CMake.app/Contents/bin/cmake --build /Users/melker/CodeProjects/AudioBox/code/code_secondary_core/armgcc/debug --clean-first --target all --
[1/2] Cleaning additional files...
[2/2] Cleaning all built files...
Cleaning... 39 files.
[1/39] Building ASM object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/gcc/startup_MIMXRT1176_cm4.S.obj
[2/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/system_MIMXRT1176_cm4.c.obj
[3/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_common_arm.c.obj
[4/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_gpio.c.obj
[5/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_common.c.obj
[6/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/hardware_init.c.obj
[7/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/pin_mux.c.obj
[8/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_anatop_ai.c.obj
[9/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/board.c.obj
[10/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_mu.c.obj
[11/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/components/uart/fsl_adapter_lpuart.c.obj
[12/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_gpc.c.obj
[13/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/main.c.obj
[14/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/croutine.c.obj
[15/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/clock_config.c.obj
[16/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/list.c.obj
[17/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_pgmc.c.obj
[18/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/cm4/fsl_cache.c.obj
[19/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/timers.c.obj
[20/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/event_groups.c.obj
[21/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/portable/GCC/ARM_CM4F/port.c.obj
[22/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_dcdc.c.obj
[23/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr.c.obj
[24/39] Building ASM object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_memcpy.S.obj
[25/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_sbrk.c.obj
[26/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_syscall_stub.c.obj
[27/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/stream_buffer.c.obj
[28/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/queue.c.obj
[29/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_lpuart.c.obj
[30/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_clock.c.obj
[31/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_soc_src.c.obj
[32/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/tasks.c.obj
[33/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr_mu_internal.c.obj
[34/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_pmu.c.obj
[35/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr_internal_core_api_imxrt1170.c.obj
[36/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/debug_console_lite/fsl_assert.c.obj
[37/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/debug_console_lite/fsl_debug_console.c.obj
[38/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/str/fsl_str.c.obj
[39/39] Linking C executable freertos_message_buffers_secondary_core.elf
Memory region Used Size Region Size %age Used
m_interrupts: 1 KB 1 KB 100.00%
m_text: 27876 B 127 KB 21.44%
m_data: 3280 B 127 KB 2.52%
m_ncache: 0 GB 256 KB 0.00%
m_data2: 0 GB 256 KB 0.00%
m_heap: 1 KB 1 KB 100.00%
rpmsg_sh_mem: 6 KB 8 KB 75.00%
build finished successfully.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: CMake: build
Workspace is /Users/melker/CodeProjects/AudioBox/code/code_primary_core
/Users/melker/.mcuxpressotools/cmake-3.30.0-macos10.10-universal/CMake.app/Contents/bin/cmake --build /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug --target all --
[1/2] Building C object CMakeFiles/freertos_message_buffers_primary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_primary_core/main.c.obj
[2/2] Linking C executable freertos_message_buffers_primary_core.elf
m_flash_config: 512 B 3 KB 16.67%
m_ivt: 48 B 4 KB 1.17%
m_text: 72188 B 65271 KB 0.11%
m_qacode: 0 GB 256 KB 0.00%
m_data: 22968 B 256 KB 8.76%
m_data2: 0 GB 504 KB 0.00%
m_core1_image: 28996 B 256 KB 11.06%
What could be causing this?
I will try J-link firmware and see if that helps.
%3CLINGO-SUB%20id%3D%22lingo-sub-2171441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1170%20EVKB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A8LinkServer%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%EF%BC%88mcuxpresso%20vs%20code%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E7%A7%81%E3%81%AF%E3%80%81nxp%20SDK%20%E3%81%AE%20freeRTOS%20%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E4%BE%8B%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20MCUXpresso%20for%20VS%20Code%20%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%E3%81%AE%20LinkServer%20Flash%20Programmer%20%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%99%82%E3%80%85%E3%80%81M4%E3%82%92%E6%AD%A3%E3%81%97%E3%81%84OCRAM%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8BM7%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%81%8C%E6%95%85%E9%9A%9C%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%20%E3%81%BE%E3%81%9F%E3%80%81m7%20%E3%82%92%E5%B8%B8%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%A4%B1%E6%95%97%E6%99%82%E3%81%AE%E3%83%AD%E3%82%B0%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T00%3A58%3A40.377%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A40.379%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T00%3A58%3A40.380%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.772%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.773%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.773%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A44.950%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20flash%20--probe%20H3RHID4AC30FD%20--no-boot%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20load%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%2Ffreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A48.405%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%3CSPAN%3E%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E255%3C%2FSPAN%3E%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A48.405%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E6%9B%B4%E6%96%B0%20%60check%60%3A%20%E4%B8%8D%E8%A6%81%20-%20%E5%BC%B7%E5%88%B6%E6%9B%B4%E6%96%B0%E3%81%AF%20%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20update%20forced%60%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20LinkServer%20RedlinkMulti%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3Ev25.7%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E2025%E5%B9%B4%3C%2FSPAN%3E7%E6%9C%88%3CSPAN%3E21%E6%97%A5%3C%2FSPAN%3E%3CSPAN%3E20%3A37%3A00%3C%2FSPAN%3E%20%3CSPAN%3E-%20crt_emu_cm_redlink%20%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E1038%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%20%3CSPAN%3E03%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmp3tmcfgxp%2Fcrt_directory.xml%20%E3%81%AB%E6%B1%8E%E7%94%A8%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20XML%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E5%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E6%97%A2%E5%AD%98%E3%81%AE%20LinkServer%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3A%3C%2FSPAN%3E%20%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20R%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3EM7%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81M4%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%82%A4%E3%83%AC%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWC%3A%20APID%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%B9%E3%83%94%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%B3%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DAP%20AP%20%E4%B8%8A%E3%81%AE%E3%82%B3%E3%82%A2%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%82%A4%E3%83%AC%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M7%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E84770001%3C%2FSPAN%3E%20%3CSPAN%3EROM%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M4%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E24770011%3C%2FSPAN%3E%20%3CSPAN%3EROM%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E7%B5%82%E4%BA%86%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20MCU-LINK%20%E6%90%AD%E8%BC%89%20(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%3C%2FSPAN%3E%3CSPAN%3E%20(NXP%20Semiconductors)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20VID%3APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20USB%E3%83%91%E3%82%B9%3A%3C%2FSPAN%3E%20%3CSPAN%3E0014%3A0002%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%3CSPAN%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%82%B3%E3%82%A2%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%3C%2FSPAN%3E%E3%82%B3%E3%82%A2%3CSPAN%3E0%3C%2FSPAN%3E%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E40%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E50%3C%2FSPAN%3E%20%3CSPAN%3E)%20CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3ENc%3A%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20DAP%20AP%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%8A%E3%81%AE%20Cortex-M7%20(CPU%20ID%2000000C27)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82DpID%3A%206BA02477%E3%80%82CPUID%3A%2000000C27%E3%80%82%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3A%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3A%20SWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3ENs%3A%20CoreSight%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3EROM%3CSPAN%3E%E3%81%AE%E5%86%85%E5%AE%B9%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20RBASE%20E00FD000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E000008E88C%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EE00FE000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE00FF000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE000E000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%20%3CSPAN%3EGen%20SCS%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0001000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB002%3C%2FSPAN%3E%20%3CSPAN%3EGen%20DWT%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0002000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%20%3CSPAN%3EGen%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0000000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB001%3C%2FSPAN%3E%20%3CSPAN%3EGen%20ITM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE0041000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04001BB975%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20ARM%3C%2FSPAN%3E%20%3CSPAN%3EETMv4.0%3C%2FSPAN%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x13%3C%2FSPAN%3E%3CSPAN%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%BC%E3%82%B9%20-%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE0042000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04004BB906%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x14%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E4%BE%8B%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9AECT%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EE0043000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04001BB908%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20CSTF%20%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%20-%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%83%B3%E3%83%8D%E3%83%AB%2F%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20NXP%3A%20MIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E256%3C%2FSPAN%3E%3CSPAN%3E%E3%83%AF%E3%83%BC%E3%83%89%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%20SFDP%20JEDEC%20ID%20%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%3CSPAN%3Ev.2%3C%2FSPAN%3E%3CSPAN%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%E3%82%92%E6%A4%9C%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E7%94%BB%E5%83%8F%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%202025%E5%B9%B47%E6%9C%8821%E6%97%A5%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(64MB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E*64K%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0x30000000%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E65%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E70%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30000400%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x200%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%20%3CSPAN%3E(%E6%97%A2%E3%81%AB%E5%B8%B8%E9%A7%90)%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E8%AD%A6%E5%91%8A%20-%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(%3C%2FSPAN%3E%3CSPAN%3E0x2000009D%3C%2FSPAN%3E%3CSPAN%3E%3F)%20-%20rc%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7Wire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EV.2%E3%81%AE%3C%2FSPAN%3E%3CSPAN%3E%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%99%82%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%3A%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30001000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x30%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%3A%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30002000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x12044%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%3A%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x7144%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%3A%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%93%8D%E4%BD%9C%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%A8%E3%83%A9%E3%83%BC%20-%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3E-EVKB%20%E3%81%AB%E5%AE%8C%E5%85%A8%E4%B8%80%E8%87%B4%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3E-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E9%83%A8%E5%88%86%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E3%82%88%E3%82%8B%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E9%81%B8%E6%8A%9E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20%23%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EH3RHID4AC30FD%20(MCU-LINK%20%E6%90%AD%E8%BC%89%20(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%20%3CSPAN%3EV3.160%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20MCU-Link%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%20%60%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%60%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20(%5BH3RHID4AC30FD%5D%20%5BMCU-LINK%E6%90%AD%E8%BC%89(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%20%3CSPAN%3EV3.160%3C%2FSPAN%3E%20%5D)%20%E3%81%AF%E3%80%81%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20%5B%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3E160%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%A8%E5%90%8C%E3%81%98%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%97%A2%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECRITICAL%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E9%87%8D%E5%A4%A7%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EERRMSG%3A%3C%2FSPAN%3E%3CSPAN%3E%E4%BE%8B%E5%A4%96%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E1%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.927%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.928%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.928%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T01%3A03%3A14.329%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T01%3A03%3A14.338%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A14.346%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A17.511%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20flash%20--probe%20H3RHID4AC30FD%20--no-boot%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20load%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%2Ffreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T01%3A03%3A23.784%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%20%3CSPAN%3EINFO%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3E-EVKB%20%E3%81%AB%E5%AE%8C%E5%85%A8%E4%B8%80%E8%87%B4%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3E-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E9%83%A8%E5%88%86%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E3%82%88%E3%82%8B%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E9%81%B8%E6%8A%9E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20%23%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EH3RHID4AC30FD%20(MCU-LINK%20%E6%90%AD%E8%BC%89%20(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%20%3CSPAN%3EV3.160%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20MCU-Link%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%20%60%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%60%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20(%5BH3RHID4AC30FD%5D%20%5BMCU-LINK%E6%90%AD%E8%BC%89(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%20%3CSPAN%3EV3.160%3C%2FSPAN%3E%20%5D)%20%E3%81%AF%E3%80%81%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20%5B%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3E160%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%A8%E5%90%8C%E3%81%98%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%97%A2%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T01%3A03%3A23.784%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5BLinkServer%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%20%3CSPAN%3ELinkServer%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%93%8D%E4%BD%9C%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E6%9B%B4%E6%96%B0%E3%81%AE%20%60check%60%3A%20%E4%B8%8D%E8%A6%81%20-%20%E5%BC%B7%E5%88%B6%E6%9B%B4%E6%96%B0%E3%81%AF%20%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20update%20forced%60%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20LinkServer%20RedlinkMulti%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3Ev25.7%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E2025%E5%B9%B4%3C%2FSPAN%3E7%E6%9C%88%3CSPAN%3E21%E6%97%A5%3C%2FSPAN%3E%3CSPAN%3E20%3A37%3A00%3C%2FSPAN%3E%20%3CSPAN%3E-%20crt_emu_cm_redlink%20%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E1038%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%20%3CSPAN%3E03%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmpci6yg1l_%2Fcrt_directory.xml%20%E3%81%AB%E6%B1%8E%E7%94%A8%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20XML%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E5%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E6%97%A2%E5%AD%98%E3%81%AE%20LinkServer%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3A%3C%2FSPAN%3E%20%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20R%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3EM7%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81M4%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%82%A4%E3%83%AC%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWC%3A%20APID%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%B9%E3%83%94%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%B3%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DAP%20AP%20%E4%B8%8A%E3%81%AE%E3%82%B3%E3%82%A2%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%82%A4%E3%83%AC%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M7%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E84770001%3C%2FSPAN%3E%20%3CSPAN%3EROM%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M4%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E24770011%3C%2FSPAN%3E%20%3CSPAN%3EROM%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E7%B5%82%E4%BA%86%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20MCU-LINK%20%E6%90%AD%E8%BC%89%20(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%3C%2FSPAN%3E%3CSPAN%3E%20(NXP%20Semiconductors)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20VID%3APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20USB%E3%83%91%E3%82%B9%3A%3C%2FSPAN%3E%20%3CSPAN%3E0014%3A0002%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%3CSPAN%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%82%B3%E3%82%A2%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%3C%2FSPAN%3E%E3%82%B3%E3%82%A2%3CSPAN%3E0%3C%2FSPAN%3E%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E40%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E50%3C%2FSPAN%3E%20%3CSPAN%3E)%20CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3ENc%3A%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20DAP%20AP%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%8A%E3%81%AE%20Cortex-M7%20(CPU%20ID%2000000C27)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82DpID%3A%206BA02477%E3%80%82CPUID%3A%2000000C27%E3%80%82%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3A%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3A%20SWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3ENs%3A%20CoreSight%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3EROM%3CSPAN%3E%E3%81%AE%E5%86%85%E5%AE%B9%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20RBASE%20E00FD000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E000008E88C%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EE00FE000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE00FF000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE000E000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%20%3CSPAN%3EGen%20SCS%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0001000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB002%3C%2FSPAN%3E%20%3CSPAN%3EGen%20DWT%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0002000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%20%3CSPAN%3EGen%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0000000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB001%3C%2FSPAN%3E%20%3CSPAN%3EGen%20ITM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE0041000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04001BB975%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20ARM%3C%2FSPAN%3E%20%3CSPAN%3EETMv4.0%3C%2FSPAN%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x13%3C%2FSPAN%3E%3CSPAN%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%BC%E3%82%B9%20-%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE0042000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04004BB906%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x14%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E4%BE%8B%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9AECT%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EE0043000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04001BB908%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20CSTF%20%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%20-%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%83%B3%E3%83%8D%E3%83%AB%2F%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20NXP%3A%20MIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E256%3C%2FSPAN%3E%3CSPAN%3E%E3%83%AF%E3%83%BC%E3%83%89%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%20SFDP%20JEDEC%20ID%20%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%3CSPAN%3Ev.2%3C%2FSPAN%3E%3CSPAN%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%E3%82%92%E6%A4%9C%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E7%94%BB%E5%83%8F%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%202025%E5%B9%B47%E6%9C%8821%E6%97%A5%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(64MB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E*64K%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0x30000000%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E65%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E70%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30000400%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x200%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%20%3CSPAN%3E(%E6%97%A2%E3%81%AB%E5%B8%B8%E9%A7%90)%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(64MB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E*64K%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0x30000000%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20)%20%3CSPAN%3E0x30000400%3C%2FSPAN%3E%E3%81%AE%3CSPAN%3E%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AB%3C%2FSPAN%3E%3CSPAN%3E512%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%3C%2FSPAN%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30000000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E1536%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30000000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E1536%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%20%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E%25%20(%3C%2FSPAN%3E%20%3CSPAN%3E1536%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E16384%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%3A%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%E5%90%88%E8%A8%88%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E0x200%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%E3%82%92295ms%E3%81%A7%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%B4%841kB%2Fs%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30001000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x30%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%20%3CSPAN%3E(%E6%97%A2%E3%81%AB%E5%B8%B8%E9%A7%90)%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(64MB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E*64K%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0x30000000%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20)%20%3CSPAN%3E0x30001000%3C%2FSPAN%3E%E3%81%AE%3CSPAN%3E%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AB%3C%2FSPAN%3E%3CSPAN%3E48%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%3C%2FSPAN%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30000000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E4144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30000000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E4144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%20%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E%25%20(%3C%2FSPAN%3E%20%3CSPAN%3E4144%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E16384%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%3A%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%E5%90%88%E8%A8%88%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E310ms%E3%81%A7%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%B4%840kB%2F%E7%A7%92%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30002000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x12044%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%20%3CSPAN%3E(%E6%97%A2%E3%81%AB%E5%B8%B8%E9%A7%90)%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(64MB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E*64K%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0x30000000%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20)%20%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AB%3C%2FSPAN%3E%3CSPAN%3E73796%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%3C%2FSPAN%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30000000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E19%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30000000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%20%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E19%3C%2FSPAN%3E%20%3CSPAN%3E%25%20(%3C%2FSPAN%3E%20%3CSPAN%3E81988%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E16384%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E39%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30004000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E32768%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%20%3CSPAN%3E30008000%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E39%3C%2FSPAN%3E%20%3CSPAN%3E%25%20(%3C%2FSPAN%3E%20%3CSPAN%3E81988%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E32768%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E59%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30008000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E49152%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%203000C000%20%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E59%3C%2FSPAN%3E%20%3CSPAN%3E%25%20(%3C%2FSPAN%3E%20%3CSPAN%3E81988%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E49152%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E79%3C%2FSPAN%3E%20%3CSPAN%3E)%203000C000%3A%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E65536%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%20%3CSPAN%3E30010000%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E79%3C%2FSPAN%3E%20%3CSPAN%3E%25%20(%3C%2FSPAN%3E%20%3CSPAN%3E81988%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E65536%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E30010000%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E65536%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E131072%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%E5%90%88%E8%A8%88%3A%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E0x12044%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%E3%82%92499ms%E3%81%A7%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%B4%84147kB%2Fs%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x7144%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%20%3CSPAN%3E(%E6%97%A2%E3%81%AB%E5%B8%B8%E9%A7%90)%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(64MB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E*64K%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0x30000000%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3CSPAN%3E1020-1020%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AB%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%3C%2FSPAN%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E)%2033FC0000%3A%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E28996%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E56%3C%2FSPAN%3E%20%3CSPAN%3E)%2033FC0000%3A%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E28996%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%2033FC4000%20%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E56%3C%2FSPAN%3E%20%3CSPAN%3E%25%20(%3C%2FSPAN%3E%20%3CSPAN%3E28996%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E16384%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%2033FC4000%3A%3C%2FSPAN%3E%20%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%20-%3C%2FSPAN%3E%20%3CSPAN%3E32768%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E28996%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%2033FC8000%20%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E%25%20(%3C%2FSPAN%3E%20%3CSPAN%3E28996%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E32768%20%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%3A%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%E5%90%88%E8%A8%88%3A%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E0x7144%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%E3%82%92550ms%E3%81%A7%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%B4%8452kB%2Fs%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%EF%BC%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3A%3C%2FSPAN%3E%20%3CSPAN%3ERT1170_reset.scp%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%E3%81%93%E3%81%AETAP%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%E3%81%93%E3%81%AE%E3%82%B3%E3%82%A2%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E10000000%3C%2FSPAN%3E%20%3CSPAN%3EHz%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%82%A4%E3%83%AC%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M7%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E84770001%3C%2FSPAN%3E%20%3CSPAN%3EROM%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20AP%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E24770011%3C%2FSPAN%3E%20%3CSPAN%3EROM%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20AP%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E54770002%3C%2FSPAN%3E%20%3CSPAN%3EROM%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%3C%2FSPAN%3E%20%3CSPAN%3E00000002%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWC%3A%20APID%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%B9%E3%83%94%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%B3%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DAP%20AP%20%E4%B8%8A%E3%81%AE%E3%82%B3%E3%82%A2%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%82%A4%E3%83%AC%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M7%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E84770001%3C%2FSPAN%3E%20%3CSPAN%3EROM%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M4%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E24770011%3C%2FSPAN%3E%20%3CSPAN%3EROM%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWC%3A%20R15%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x00223104%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20SP%2FPC%20%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWC%3A%20PC%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x3000247D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWC%3A%20SP%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x20040000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWC%3A%20XPSR%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x01000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20VTOR%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DEMCR%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x010007F1%3C%2FSPAN%3E%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E7%B5%82%E4%BA%86%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20%E5%81%9C%E6%AD%A2%3A%20%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%99%82%E3%81%AB%E5%86%8D%E8%B5%B7%E5%8B%95%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMCU-Link%20%E7%94%A8%E3%81%AE%E6%9C%80%E6%96%B0%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%89%8D%E3%81%AB%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%82%82%E9%81%95%E3%81%84%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A34.034%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T09%3A09%3A34.035%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A34.035%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.433%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FMCUXpressoIDE_24.%3C%2FSPAN%3E%3CSPAN%3E12%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E148%3C%2FSPAN%3E%3CSPAN%3E%2Fide%2Ftools%2Fbin%2FArm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.436%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2FArm-%3C%2FSPAN%3E%3CSPAN%3Egnu-toolchain-13.2.Rel1-darwin-x86_64-Arm-none%3C%2FSPAN%3E%3CSPAN%3E-eabi%2Fbin%2FArm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.458%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FMCUXpressoIDEs_24.%3C%2FSPAN%3E%3CSPAN%3E12%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E148%3C%2FSPAN%3E%3CSPAN%3E%2Fide%2Ftools%2Fbin%2FArm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.470%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2FArm-%3C%2FSPAN%3E%3CSPAN%3Egnu-toolchain-13.2.Rel1-darwin-x86_64-Arm-none%3C%2FSPAN%3E%3CSPAN%3E-eabi%2Fbin%2FArm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.481%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2FArm-%3C%2FSPAN%3E%3CSPAN%3Egnu-toolchain-13.2.Rel1-darwin-x86_64-Arm-none%3C%2FSPAN%3E%3CSPAN%3E-eabi%2Fbin%2FArm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.482%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FMCUXpressoIDE_24.%3C%2FSPAN%3E%3CSPAN%3E12%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E148%3C%2FSPAN%3E%3CSPAN%3E%2FIDE%2Ftools%2Fbin%2FArm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.963%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.965%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.966%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T09%3A10%3A32.425%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-09-18T09%3A10%3A32.426%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A32.427%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A35.933%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20flash%20--probe%20H3RHID4AC30FD%20--no-boot%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20load%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%2Ffreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A39.480%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%3CSPAN%3E%20%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E255%3C%2FSPAN%3E%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A39.480%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E6%9B%B4%E6%96%B0%20%60check%60%3A%20%E4%B8%8D%E8%A6%81%20-%20%E5%BC%B7%E5%88%B6%E6%9B%B4%E6%96%B0%E3%81%AF%20%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20update%20forced%60%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20LinkServer%20RedlinkMulti%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3Ev25.7%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E2025%E5%B9%B4%3C%2FSPAN%3E7%E6%9C%88%3CSPAN%3E21%E6%97%A5%3C%2FSPAN%3E%3CSPAN%3E20%3A37%3A00%3C%2FSPAN%3E%20%3CSPAN%3E-%20crt_emu_cm_redlink%20%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E1038%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%20%3CSPAN%3E03%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmps1gdrldt%2Fcrt_directory.xml%20%E3%81%AB%E6%B1%8E%E7%94%A8%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20XML%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E5%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E6%97%A2%E5%AD%98%E3%81%AE%20LinkServer%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3A%3C%2FSPAN%3E%20%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20R%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3EM7%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81M4%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%82%A4%E3%83%AC%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWC%3A%20APID%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%B9%E3%83%94%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20M4%E3%82%B3%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DAP%20AP%20%E4%B8%8A%E3%81%AE%E3%82%B3%E3%82%A2%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%82%A4%E3%83%AC%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M7%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E84770001%3C%2FSPAN%3E%20%3CSPAN%3EROM%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%206BA02477%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20M4%20APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E24770011%3C%2FSPAN%3E%20%3CSPAN%3EROM%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E7%B5%82%E4%BA%86%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20MCU-LINK%20%E6%90%AD%E8%BC%89%20(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%3C%2FSPAN%3E%3CSPAN%3E%20(NXP%20Semiconductors)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20VID%3APID%3A%3C%2FSPAN%3E%20%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20USB%E3%83%91%E3%82%B9%3A%3C%2FSPAN%3E%20%3CSPAN%3E0014%3A0003%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%3CSPAN%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%82%B3%E3%82%A2%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%3C%2FSPAN%3E%E3%82%B3%E3%82%A2%3CSPAN%3E0%3C%2FSPAN%3E%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E40%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E50%3C%2FSPAN%3E%20%3CSPAN%3E)%20CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3ENc%3A%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20DAP%20AP%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%8A%E3%81%AE%20Cortex-M7%20(CPU%20ID%2000000C27)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82DpID%3A%206BA02477%E3%80%82CPUID%3A%2000000C27%E3%80%82%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3A%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3A%20SWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3ENs%3A%20CoreSight%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3EROM%3CSPAN%3E%E3%81%AE%E5%86%85%E5%AE%B9%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20RBASE%20E00FD000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E000008E88C%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EE00FE000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE00FF000%3A%20CID%20B105100D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%20%3CSPAN%3EROM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE000E000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%20%3CSPAN%3EGen%20SCS%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0001000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB002%3C%2FSPAN%3E%20%3CSPAN%3EGen%20DWT%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0002000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%20%3CSPAN%3EGen%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3EE0000000%3A%20CID%20B105E00D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04000BB001%3C%2FSPAN%3E%20%3CSPAN%3EGen%20ITM%20(%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE0041000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04001BB975%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20ARM%3C%2FSPAN%3E%20%3CSPAN%3EETMv4.0%3C%2FSPAN%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x13%3C%2FSPAN%3E%3CSPAN%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%BC%E3%82%B9%20-%20%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3EE0042000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04004BB906%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x14%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E4%BE%8B%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9AECT%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EE0043000%3A%20CID%20B105900D%20PID%3C%2FSPAN%3E%20%3CSPAN%3E04001BB908%3C%2FSPAN%3E%20%3CSPAN%3ECSt%20CSTF%20%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%20-%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%83%B3%E3%83%8D%E3%83%AB%2F%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20NXP%3A%20MIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E256%3C%2FSPAN%3E%3CSPAN%3E%E3%83%AF%E3%83%BC%E3%83%89%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%3C%2FSPAN%3E%20SFDP%20JEDEC%20ID%20%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%3CSPAN%3Ev.2%3C%2FSPAN%3E%3CSPAN%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%E3%82%92%E6%A4%9C%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E7%94%BB%E5%83%8F%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%202025%E5%B9%B47%E6%9C%8821%E6%97%A5%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(64MB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E*64K%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0x30000000%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E65%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E70%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30000400%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x200%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%20%3CSPAN%3E(%E6%97%A2%E3%81%AB%E5%B8%B8%E9%A7%90)%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABVECTRESET%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%82%A8%E3%83%A9%E3%83%BCNn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E5%BE%8C%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%AF%E3%82%A4%E3%83%A4ACK%E9%9A%9C%E5%AE%B3%20-%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%AF%E3%82%A4%E3%83%A4ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%E3%82%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E1%2F301%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89-%201ms%E5%BE%8C%E3%81%AB%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%20-%20rc%20Em(%3C%2FSPAN%3E%20%3CSPAN%3E17%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%820x2000A840%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AB%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%82%A8%E3%83%A9%E3%83%BCNn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E5%BE%8C%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%AF%E3%82%A4%E3%83%A4ACK%E9%9A%9C%E5%AE%B3%20-%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%AF%E3%82%A4%E3%83%A4ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%E3%82%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E1%2F301%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89-%20%E4%BA%8B%E5%BE%8C%E5%88%86%E6%9E%90%E3%81%AE%E3%81%9F%E3%82%81%E5%81%9C%E6%AD%A2%E4%B8%AD%20-%20rc%20Em(%3C%2FSPAN%3E%20%3CSPAN%3E17%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%820x2000A840%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AB%3C%2FSPAN%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%E4%BA%8B%E5%BE%8C%E5%88%86%E6%9E%90%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20-%20rc%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7Wire%20ACK%E9%9A%9C%E5%AE%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%AF%E3%82%A4%E3%83%A4ACK%E9%9A%9C%E5%AE%B3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EV.2%20%E3%81%AE%3C%2FSPAN%3E%3CSPAN%3E%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Em(%3C%2FSPAN%3E%20%3CSPAN%3E17%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%820x2000A840%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AB%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%3A%20Em(%3C%2FSPAN%3E%20%3CSPAN%3E17%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%820x2000A840%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E5%BE%8C%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30001000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x30%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%3A%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x30002000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x12044%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%3A%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%3C%2FSPAN%3E%20%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%20%3CSPAN%3EELF%3C%2FSPAN%3E%20%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%20%3CSPAN%3Elen%3C%2FSPAN%3E%20%3CSPAN%3E0x7144%3C%2FSPAN%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENC%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%A4%B1%E6%95%97%3A%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%3C%2FSPAN%3E%20%3CSPAN%3E100%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%93%8D%E4%BD%9C%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%A8%E3%83%A9%E3%83%BC%20-%20Nn(%3C%2FSPAN%3E%20%3CSPAN%3E05%3C%2FSPAN%3E%20%3CSPAN%3E)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BWire%20ACK%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3E-EVKB%20%E3%81%AB%E5%AE%8C%E5%85%A8%E4%B8%80%E8%87%B4%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%20%3CSPAN%3ET1170%3C%2FSPAN%3E%20%3CSPAN%3E-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E9%83%A8%E5%88%86%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E3%82%88%E3%82%8B%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E9%81%B8%E6%8A%9E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20%23%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3EH3RHID4AC30FD%20(MCU-LINK%20%E6%90%AD%E8%BC%89%20(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%20%3CSPAN%3EV3.160%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%3E%3A%20MCU-Link%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%20%60%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%60%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20(%5BH3RHID4AC30FD%5D%20%5BMCU-LINK%E6%90%AD%E8%BC%89(r0E2)%20CMSIS-DAP%3C%2FSPAN%3E%20%3CSPAN%3EV3.160%3C%2FSPAN%3E%20%5D)%20%E3%81%AF%E3%80%81%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20%5B%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3E160%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%A8%E5%90%8C%E3%81%98%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%97%A2%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECRITICAL%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%E9%87%8D%E5%A4%A7%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EERRMSG%3A%3C%2FSPAN%3E%3CSPAN%3E%E4%BE%8B%E5%A4%96%3C%2FSPAN%3E%3CSPAN%3E%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E1%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%89%8D%E3%81%AB%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81M4%E3%82%B3%E3%82%A2%E3%81%8C%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%881%E3%81%A4%E4%BB%A5%E4%B8%8A%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E9%81%85%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%99%82%E3%80%85%E3%80%81%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AE%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%B3%E3%82%A2%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%3E%E5%AE%9F%E8%A1%8C%E3%82%BF%E3%82%B9%E3%82%AF%3A%20CMake%3A%20M4%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%3C%2FP%3E%3CP%3E%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AF%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fmelker%2F.mcuxpressotools%2Fcmake-3.30.0-macos10.10-universal%2FCMake.app%2FContents%2Fbin%2Fcmake%20--build%20%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Farmgcc%2Fdebug%20--clean-first%20--target%20all%20--%3CBR%20%2F%3E%20%5B1%2F2%5D%20%E8%BF%BD%E5%8A%A0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B2%2F2%5D%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E4%B8%AD...39%20%E5%80%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3CBR%20%2F%3E%5B1%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20ASM%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fgcc%2Fstartup_MIMXRT1176_cm4.S.obj%3CBR%20%2F%3E%5B2%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fsystem_MIMXRT1176_cm4.c.obj%3CBR%20%2F%3E%5B3%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_common_arm.c.obj%3CBR%20%2F%3E%5B4%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_gpio.c.obj%3CBR%20%2F%3E%5B5%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_common.c.obj%3CBR%20%2F%3E%5B6%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fhardware_init.c.obj%3CBR%20%2F%3E%5B7%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fpin_mux.c.obj%3CBR%20%2F%3E%5B8%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_anatop_ai.c.obj%3CBR%20%2F%3E%5B9%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fboard.c.obj%3CBR%20%2F%3E%5B10%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_mu.c.obj%3CBR%20%2F%3E%5B11%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fcomponents%2Fuart%2Ffsl_adapter_lpuart.c.obj%3CBR%20%2F%3E%5B12%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_gpc.c.obj%3CBR%20%2F%3E%5B13%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fmain.c.obj%3CBR%20%2F%3E%5B14%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fcroutine.c.obj%3CBR%20%2F%3E%5B15%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fclock_config.c.obj%3CBR%20%2F%3E%5B16%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Flist.c.obj%3CBR%20%2F%3E%5B17%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_pgmc.c.obj%3CBR%20%2F%3E%5B18%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Fcm4%2Ffsl_cache.c.obj%3CBR%20%2F%3E%5B19%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Ftimers.c.obj%3CBR%20%2F%3E%5B20%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fevent_groups.c.obj%3CBR%20%2F%3E%5B21%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fportable%2FGCC%2FARM_CM4F%2Fport.c.obj%3CBR%20%2F%3E%5B22%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_dcdc.c.obj%3CBR%20%2F%3E%5B23%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr.c.obj%3CBR%20%2F%3E%5B24%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20ASM%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_memcpy.S.obj%3CBR%20%2F%3E%5B25%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_sbrk.c.obj%3CBR%20%2F%3E%5B26%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_syscall_stub.c.obj%3CBR%20%2F%3E%5B27%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fstream_buffer.c.obj%3CBR%20%2F%3E%5B28%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fqueue.c.obj%3CBR%20%2F%3E%5B29%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_lpuart.c.obj%3CBR%20%2F%3E%5B30%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_clock.c.obj%3CBR%20%2F%3E%5B31%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_soc_src.c.obj%3CBR%20%2F%3E%5B32%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Ftasks.c.obj%3CBR%20%2F%3E%5B33%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr_mu_internal.c.obj%3CBR%20%2F%3E%5B34%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_pmu.c.obj%3CBR%20%2F%3E%5B35%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr_internal_core_api_imxrt1170.c.obj%3CBR%20%2F%3E%5B36%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fdebug_console_lite%2Ffsl_assert.c.obj%3CBR%20%2F%3E%5B37%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fdebug_console_lite%2Ffsl_debug_console.c.obj%3CBR%20%2F%3E%5B38%2F39%5D%20%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fstr%2Ffsl_str.c.obj%3CBR%20%2F%3E%5B39%2F39%5D%20C%E5%AE%9F%E8%A1%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20freertos_message_buffers_secondary_core.elf%20%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E4%BD%BF%E7%94%A8%E3%82%B5%E3%82%A4%E3%82%BA%E9%A0%98%E5%9F%9F%E3%82%B5%E3%82%A4%E3%82%BA%E4%BD%BF%E7%94%A8%E7%8E%87%3CBR%20%2F%3Em_interrupts%3A%201%20KB%201%20KB%20100.00%25%3CBR%20%2F%3E%20m_text%3A%2027876%20B%20127%20KB%2021.44%25%3CBR%20%2F%3E%20m_data%3A%203280%20B%20127%20KB%202.52%25%3CBR%20%2F%3E%20m_ncache%3A%200%20GB%20256%20KB%200.00%25%3CBR%20%2F%3E%20m_data2%3A%200%20GB%20256%20KB%200.00%25%3CBR%20%2F%3E%20m_heap%3A%201%20KB%201%20KB%20100.00%25%3CBR%20%2F%3E%20rpmsg_sh_mem%3A%206%20KB%208%20KB%2075.00%25%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E*%20%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%AF%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E9%96%89%E3%81%98%E3%82%8B%E3%81%AB%E3%81%AF%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E*%20%E5%AE%9F%E8%A1%8C%E3%82%BF%E3%82%B9%E3%82%AF%3A%20CMake%3A%20%E3%83%93%E3%83%AB%E3%83%89%3C%2FP%3E%3CP%3E%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AF%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fcmake-3.30.0-macos10.10-universal%2FCMake.app%2FContents%2Fbin%2Fcmake%20--build%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%20--target%20all%20--%3CBR%20%2F%3E%20%5B1%2F2%5D%20C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20CMakeFiles%2Ffreertos_message_buffers_primary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Fmain.c.obj%3CBR%20%2F%3E%20%5B2%2F2%5D%20C%E5%AE%9F%E8%A1%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20freertos_message_buffers_primary_core.elf%20%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E4%BD%BF%E7%94%A8%E3%82%B5%E3%82%A4%E3%82%BA%E9%A0%98%E5%9F%9F%E3%82%B5%E3%82%A4%E3%82%BA%E4%BD%BF%E7%94%A8%E7%8E%87%3CBR%20%2F%3Em_flash_config%3A%20512%20B%203%20KB%2016.67%25%3CBR%20%2F%3E%20m_ivt%3A%2048%20B%204%20KB%201.17%25%3CBR%20%2F%3E%20m_interrupts%3A%201%20KB%201%20KB%20100.00%25%3CBR%20%2F%3E%20m_text%3A%2072188%20B%2065271%20KB%200.11%25%3CBR%20%2F%3E%20m_qacode%3A%200%20GB%20256%20KB%200.00%25%3CBR%20%2F%3E%20m_data%3A%2022968%20B%20256%20KB%208.76%25%3CBR%20%2F%3E%20m_data2%3A%200%20GB%20504%20KB%200.00%25%3CBR%20%2F%3E%20rpmsg_sh_mem%3A%206%20KB%208%20KB%2075.00%25%3CBR%20%2F%3E%20m_core1_image%3A%2028996%20B%20256%20KB%2011.06%25%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E*%20%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%AF%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E9%96%89%E3%81%98%E3%82%8B%E3%81%AB%E3%81%AF%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%95%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3EJ-link%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251274%22%20target%3D%22_blank%22%3E%40cyberhelmer%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ENXP%20MIMXRT%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AB%E3%81%94%E8%88%88%E5%91%B3%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E6%93%8D%E4%BD%9C%E4%B8%AD%E3%81%AB%E3%80%81%E3%83%AD%E3%82%B0%E3%81%AB%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A8%98%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EReleasing%20M4%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E5%BA%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%86%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81MCU-Link%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Gavin_Jia_0-1758167694150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Gavin_Jia_0-1758167694150.png%22%20style%3D%22width%3A%20254px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357422iD4D5B078A4526AD1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Gavin_Jia_0-1758167694150.png%22%20alt%3D%22Gavin_Jia_0-1758167694150.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B8%80%E6%96%B9%E3%80%81%E7%A7%81%E3%81%AE%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AA%E7%B5%8C%E9%A8%93%E3%81%A7%E3%81%AF%E3%80%81JLink%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%8C%E5%90%91%E4%B8%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81MCU-Link%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%20JLink%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%AE%E3%83%A3%E3%83%93%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%B3%E3%82%A2%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81m7%20%E3%81%AE%E3%81%BF%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%80%81m4%20%E3%81%AF%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
