RT1170 EVKB Multicore project and LinkServer Flash programmer not working (mcuxpresso vs code)
2,110 次查看
cyberhelmer
I have a project based on the freeRTOS multicore message buffers example from nxp SDK.
There seem to be a problem with the LinkServer Flash Programmer in the mcuxpresso for vs code extension.
I am sometimes able to flash the m7 firmware which loads the M4 to the correct ocram adress. Very often the flash programmer fails and the board stops running it's code.
What is the cause of this and how can I fix it so that I'm always able to flash the m7 correctly?
Thanks!
Log when failing:
2025-09-18T00:58:40.377] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T00:58:40.379] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T00:58:40.380] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T00:58:41.772] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T00:58:41.773] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T00:58:41.773] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T00:58:44.950] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T00:58:48.405] [proc] [error] /Applications/LinkServer_25.7.33/LinkServer exited with code 255
[2025-09-18T00:58:48.405] [proc] [error] Firmware update `check`: not required - forced update can be performed using: `./LinkServer probe #1 update forced`
Ns: LinkServer RedlinkMulti Driver v25.7 (Jul 21 2025 20:37:00 - crt_emu_cm_redlink build 1038)
Pc: ( 0) Reading remote configuration
Wc(03). No cache support.
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmp3tmcfgxp/crt_directory.xml
Pc: ( 5) Remote configuration complete
Nc: Reconnected to existing LinkServer process.
Wc: ============= SCRIPT: RT1170_connect_M7_wake_M4.scp =============
Wc: RT1170 Connect M7 and Wake M4 Script
Wc: DpID = 6BA02477
Wc: APID = 0x84770001
Wc: Setting M4 spin code
Wc: Setting M4 clock
Wc: Resetting M4 core
Wc: View cores on the DAP AP
Wc: DpID = 6BA02477
Wc: TAP 0: 6BA02477 Core 0: M7 APID: 84770001 ROM Table: E00FD003*
Wc: TAP 0: 6BA02477 Core 1: M4 APID: 24770011 ROM Table: E00FF003
Wc: ============= END SCRIPT ========================================
Nc: Probe Firmware: MCU-LINK on-board (r0E2) CMSIS-DAP V3.160 (NXP Semiconductors)
Nc: Serial Number: H3RHID4AC30FD
Nc: VID:PID: 1FC9:0143
Nc: USB Path: 0014:0002:00
Nc: Using memory from core 0 after searching for a good core
Pc: ( 30) Emulator Connected
Pc: ( 40) Debug Halt
Pc: ( 50) CPU ID
Nc: debug interface type = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
Nc: processor type = Cortex-M7 (CPU ID 00000C27) on DAP AP 0
Nc: number of h/w breakpoints = 8
Nc: number of flash patches = 0
Nc: number of h/w watchpoints = 4
Nc: Probe(0 Connected&Reset. DpID: 6BA02477. CpuID: 00000C27. Info: <None>
Nc: Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Ns: Content of CoreSight Debug ROM(s):
Nc: RBASE E00FD000: CID B105100D PID 000008E88C ROM (type 0x1)
Nc: ROM 1 E00FE000: CID B105100D PID 04000BB4C8 ROM (type 0x1)
Nc: ROM 2 E00FF000: CID B105100D PID 04000BB4C7 ROM (type 0x1)
Nc: ROM 3 E000E000: CID B105E00D PID 04000BB00C Gen SCS (type 0x0)
Nc: ROM 3 E0001000: CID B105E00D PID 04000BB002 Gen DWT (type 0x0)
Nc: ROM 3 E0002000: CID B105E00D PID 04000BB00E Gen (type 0x0)
Nc: ROM 3 E0000000: CID B105E00D PID 04000BB001 Gen ITM (type 0x0)
Nc: ROM 2 E0041000: CID B105900D PID 04001BB975 CSt ARM ETMv4.0 type 0x13 Trace Source - Core
Nc: ROM 2 E0042000: CID B105900D PID 04004BB906 CSt type 0x14 Debug Control - Trigger, e.g. ECT
Nc: ROM 1 E0043000: CID B105900D PID 04001BB908 CSt CSTF type 0x12 Trace Link - Trace funnel/router
Nc: NXP: MIMXRT1176xxxxx
Nc: DAP stride is 1024 bytes (256 words)
Nc: Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MIMXRT1170_SFDP_QSPI.cfx
Nc: Image 'iMXRT1170_SFDP_FlexSPI1_A_QSPI Jul 21 2025 18:35:07'
Nc: Opening flash driver MIMXRT1170_SFDP_QSPI.cfx
Nc: Sending VECTRESET to run flash driver
Nc: Flash variant 'iMXRT1170_SFDP_FlexSPI1_A_QSPI Jul 21 2025 18:35:07' detected (64MB = 1024*64K at 0x30000000)
Nc: Closing flash driver MIMXRT1170_SFDP_QSPI.cfx
Pc: ( 65) Chip Setup Complete
Pc: ( 70) License Check Complete
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30000400 len 0x200
Nc: Opening flash driver MIMXRT1170_SFDP_QSPI.cfx (already resident)
Nc: Warning - failed to start flash driver (at 0x2000009D?) - rc Nn(05). Wire ACK Fault in DAP access
Nc: Flash Driver V.2 startup failed - rc Nn(05). Wire ACK Fault in DAP access
Pb: (100) Writing Flash ended with an error.
Ed:05: File 'freertos_message_buffers_primary_core.elf' load failure: Nn(05). Wire ACK Fault in DAP access
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30001000 len 0x30
Nc: request to clear DAP error failed - status 5
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30002000 len 0x12044
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x33FC0000 len 0x7144
Pc: (100) Target Operation Failed
Nc: error closing down debug session - Nn(05). Wire ACK Fault in DAP access
INFO: Exact match for MIMXRT1176xxxxx:MIMXRT1170-EVKB found
INFO: Selected device MIMXRT1176xxxxx:MIMXRT1170-EVKB
INFO: Getting available probes
INFO: Selecting probe by serial substring
INFO: Selected probe #1 H3RHID4AC30FD (MCU-LINK on-board (r0E2) CMSIS-DAP V3.160)
INFO: MCU-Link firmware update `check`: Probe ([H3RHID4AC30FD] [MCU-LINK on-board (r0E2) CMSIS-DAP V3.160]) is already running the same firmware version as the included firmware version [3.160]
CRITICAL: Critical error
ERRMSG: Exception: Flash operation exited with code 1
This is the log when the flashing actually succeeds:
[2025-09-18T01:03:12.927] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T01:03:12.928] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T01:03:12.928] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T01:03:14.329] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T01:03:14.338] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T01:03:14.346] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T01:03:17.511] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T01:03:23.784] [proc] [info] INFO: Exact match for MIMXRT1176xxxxx:MIMXRT1170-EVKB found
[2025-09-18T01:03:23.784] [LinkServer] [info] LinkServer flash operation completed successfully:
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmpci6yg1l_/crt_directory.xml
Wc: DpID = 6BA02477
Wc: Releasing M4
Wc: DpID = 6BA02477
Pc: ( 50) CPU ID
Pb: 1 of 1 ( 0) Writing sectors 0-0 at 0x30000400 with 512 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/1536
Ps: (100) at 30000000: 16384 bytes - 16384/1536
Nc: 30004000 done 100% (16384 out of 1536)
Nc: Sectors written: 1, unchanged: 0, total: 1
Pb: (100) Finished writing Flash successfully.
Nt: Loaded 0x200 bytes in 295ms (about 1kB/s)
Pb: 1 of 1 ( 0) Writing sectors 0-0 at 0x30001000 with 48 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/4144
Ps: (100) at 30000000: 16384 bytes - 16384/4144
Nc: 30004000 done 100% (16384 out of 4144)
Nt: Loaded 0x30 bytes in 310ms (about 0kB/s)
Pb: 1 of 1 ( 0) Writing sectors 0-1 at 0x30002000 with 73796 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/81988
Ps: ( 19) at 30000000: 16384 bytes - 16384/81988
Nc: 30004000 done 19% (16384 out of 81988)
Ps: ( 39) at 30004000: 16384 bytes - 32768/81988
Nc: 30008000 done 39% (32768 out of 81988)
Ps: ( 59) at 30008000: 16384 bytes - 49152/81988
Nc: 3000C000 done 59% (49152 out of 81988)
Ps: ( 79) at 3000C000: 16384 bytes - 65536/81988
Nc: 30010000 done 79% (65536 out of 81988)
Ps: (100) at 30010000: 65536 bytes - 131072/81988
Nc: Sectors written: 1, unchanged: 1, total: 2
Nt: Loaded 0x12044 bytes in 499ms (about 147kB/s)
Pb: 1 of 1 ( 0) Writing sectors 1020-1020 at 0x33FC0000 with 28996 bytes
Ps: ( 0) at 33FC0000: 0 bytes - 0/28996
Ps: ( 56) at 33FC0000: 16384 bytes - 16384/28996
Nc: 33FC4000 done 56% (16384 out of 28996)
Ps: (100) at 33FC4000: 16384 bytes - 32768/28996
Nc: 33FC8000 done 100% (32768 out of 28996)
Nt: Loaded 0x7144 bytes in 550ms (about 52kB/s)
Nt: Reset target (system)
Wc: ============= SCRIPT: RT1170_reset.scp =============
Wc: This probe = 1
Wc: This TAP = 0
Wc: This core = 0
Wc: SYSTEM Reset
Wc: Wirespeed = 10000000 Hz
Wc: DpID = 6BA02477
Wc: TAP 0: 6BA02477 AP 1: APID: 24770011 ROM Table: E00FF003
Wc: TAP 0: 6BA02477 AP 2: APID: 54770002 ROM Table: 00000002
Wc: Releasing M4
Wc: DpID = 6BA02477
Wc: R15 = 0x00223104
Wc: Vector table SP/PC is the reset context.
Wc: PC = 0x3000247D
Wc: SP = 0x20040000
Wc: XPSR = 0x01000000
Wc: VTOR = 0x30002000
Wc: Set DEMCR = 0x010007F1
Ns: Stopped: Halt
Ns: restart on reset
2,104 次查看
cyberhelmer
Also, sometimes when I make changes to both cores and do a clean and rebuild of both projects only the m7 is updated with the correct code, m4 still runs an older version.
2,077 次查看
Gavin_Jia
Hi @cyberhelmer ,
Thanks for  your interest in NXP MIMXRT series!
During the failed operation, I noticed it was missing from the logs:
Releasing M4
This led to subsequent failures. We recommend updating the MCU-Link firmware and performing the following operation when debugging or programming again:
On the other hand, based on my personal experience, using JLink firmware provides better stability. If possible, try replacing the MCU-Link firmware with JLink firmware.
Gavin
2,063 次查看
cyberhelmer
I do have have latest firmware for the MCU-Link.
Resetting the probe before a flash as you suggested does not make a difference unfortunately. Still get this error most of the time:
[2025-09-18T09:09:34.034] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:09:34.035] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:09:34.035] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:09:35.433] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.436] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.458] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.470] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.481] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.482] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:10:30.963] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:10:30.965] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:10:30.966] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:10:32.425] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:10:32.426] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:10:32.427] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:10:35.933] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T09:10:39.480] [proc] [error] /Applications/LinkServer_25.7.33/LinkServer exited with code 255
[2025-09-18T09:10:39.480] [proc] [error] Firmware update `check`: not required - forced update can be performed using: `./LinkServer probe #1 update forced`
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmps1gdrldt/crt_directory.xml
Wc: DpID = 6BA02477
Wc: DpID = 6BA02477
Nc: USB Path: 0014:0003:00
Pc: ( 50) CPU ID
Nc: After error Nn(05). Wire ACK Fault in DAP access -
Nc: Failed to read address register in DAP - Nn(05). Wire ACK Fault in DAP access
Nc: flash driver polled mailbox (8 bytes at 0x2000A840) read failed (on poll 1/301) - retrying after 1ms - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Wc: flash driver polled mailbox (8 bytes at 0x2000A840) read failed (on poll 1/301) - halting for postmortem - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Wc: failed to halt target for postmortem - rc Nn(05). Wire ACK Fault in DAP access
Nc: failed to read registers - Nn(05). Wire ACK Fault in DAP access
Nc: Flash Driver V.2 startup failed - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Ed:05: File 'freertos_message_buffers_primary_core.elf' load failure: Em(17). Debug port inaccessible after access at location 0x2000A840
Also I've noticed that when when the flashing actually succeeds the M4 core is most of the time one or more versions behind even though I do a clean and rebuild of both projects before flashing. However sometimes, seemingly randomly both cores does get the correct version.
This is the build log:
Executing task: CMake: build M4
Workspace is /Users/melker/CodeProjects/AudioBox/code/code_secondary_core
build task started....
/Users/melker/.mcuxpressotools/cmake-3.30.0-macos10.10-universal/CMake.app/Contents/bin/cmake --build /Users/melker/CodeProjects/AudioBox/code/code_secondary_core/armgcc/debug --clean-first --target all --
[1/2] Cleaning additional files...
[2/2] Cleaning all built files...
Cleaning... 39 files.
[1/39] Building ASM object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/gcc/startup_MIMXRT1176_cm4.S.obj
[2/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/system_MIMXRT1176_cm4.c.obj
[3/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_common_arm.c.obj
[4/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_gpio.c.obj
[5/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_common.c.obj
[6/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/hardware_init.c.obj
[7/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/pin_mux.c.obj
[8/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_anatop_ai.c.obj
[9/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/board.c.obj
[10/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_mu.c.obj
[11/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/components/uart/fsl_adapter_lpuart.c.obj
[12/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_gpc.c.obj
[13/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/main.c.obj
[14/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/croutine.c.obj
[15/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/clock_config.c.obj
[16/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/list.c.obj
[17/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_pgmc.c.obj
[18/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/cm4/fsl_cache.c.obj
[19/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/timers.c.obj
[20/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/event_groups.c.obj
[21/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/portable/GCC/ARM_CM4F/port.c.obj
[22/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_dcdc.c.obj
[23/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr.c.obj
[24/39] Building ASM object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_memcpy.S.obj
[25/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_sbrk.c.obj
[26/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_syscall_stub.c.obj
[27/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/stream_buffer.c.obj
[28/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/queue.c.obj
[29/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_lpuart.c.obj
[30/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_clock.c.obj
[31/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_soc_src.c.obj
[32/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/tasks.c.obj
[33/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr_mu_internal.c.obj
[34/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_pmu.c.obj
[35/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr_internal_core_api_imxrt1170.c.obj
[36/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/debug_console_lite/fsl_assert.c.obj
[37/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/debug_console_lite/fsl_debug_console.c.obj
[38/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/str/fsl_str.c.obj
[39/39] Linking C executable freertos_message_buffers_secondary_core.elf
Memory region Used Size Region Size %age Used
m_interrupts: 1 KB 1 KB 100.00%
m_text: 27876 B 127 KB 21.44%
m_data: 3280 B 127 KB 2.52%
m_ncache: 0 GB 256 KB 0.00%
m_data2: 0 GB 256 KB 0.00%
m_heap: 1 KB 1 KB 100.00%
rpmsg_sh_mem: 6 KB 8 KB 75.00%
build finished successfully.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: CMake: build
Workspace is /Users/melker/CodeProjects/AudioBox/code/code_primary_core
/Users/melker/.mcuxpressotools/cmake-3.30.0-macos10.10-universal/CMake.app/Contents/bin/cmake --build /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug --target all --
[1/2] Building C object CMakeFiles/freertos_message_buffers_primary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_primary_core/main.c.obj
[2/2] Linking C executable freertos_message_buffers_primary_core.elf
m_flash_config: 512 B 3 KB 16.67%
m_ivt: 48 B 4 KB 1.17%
m_text: 72188 B 65271 KB 0.11%
m_qacode: 0 GB 256 KB 0.00%
m_data: 22968 B 256 KB 8.76%
m_data2: 0 GB 504 KB 0.00%
m_core1_image: 28996 B 256 KB 11.06%
What could be causing this?
I will try J-link firmware and see if that helps.
%3CLINGO-SUB%20id%3D%22lingo-sub-2171441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1170%20EVKB%20%E5%A4%9A%E6%A0%B8%E9%A1%B9%E7%9B%AE%E5%92%8C%20LinkServer%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%99%A8%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%EF%BC%88mcuxpresso%20%E4%B8%8E%E4%BB%A3%E7%A0%81%EF%BC%89%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%9F%BA%E4%BA%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E7%9A%84FreeRTOS%E5%A4%9A%E6%A0%B8%E6%B6%88%E6%81%AF%E7%BC%93%E5%86%B2%E5%8C%BA%E7%A4%BA%E4%BE%8B%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%20%E7%94%A8%E4%BA%8E%20vs%20code%20%E6%89%A9%E5%B1%95%E7%9A%84%20mcuxpresso%20%E4%B8%AD%E7%9A%84%20LinkServer%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%99%A8%E4%BC%BC%E4%B9%8E%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E6%9C%89%E6%97%B6%E5%80%99%E6%88%91%E8%83%BD%E5%88%B7%E6%96%B0%20m7%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E5%AE%83%E5%B0%86%20M4%20%E5%8A%A0%E8%BD%BD%E5%88%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%20ocram%20%E5%9C%B0%E5%9D%80%E3%80%82%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%99%A8%E7%BB%8F%E5%B8%B8%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%EF%BC%8C%E6%9D%BF%E4%BC%9A%E5%81%9C%E6%AD%A2%E8%BF%90%E8%A1%8C%E5%85%B6%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E8%BF%99%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E9%80%A0%E6%88%90%E7%9A%84%EF%BC%9F%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E4%BF%AE%E5%A4%8D%E5%AE%83%E4%BB%A5%E4%BE%BF%E6%88%91%E5%A7%8B%E7%BB%88%E8%83%BD%E5%A4%9F%E6%AD%A3%E7%A1%AE%E5%88%B7%E6%96%B0%20m7%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%20%E5%A4%B1%E8%B4%A5%E6%97%B6%E7%99%BB%E5%BD%95%EF%BC%9A%5B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T%2000%3A58%3A40.377%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2Fusers%2FMelker%2F.mcuxpressoToo%20ls%2FpemicrogdbServer%2FpegdbServer_console-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A40.379%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A40.380%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.772%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.773%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.773%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%3C%2FSPAN%3E%3CSPAN%3E%2000%3A58%3A44.950%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplication%20s%2FLinkServer_25%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%207%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%2033%3C%2FSPAN%3E%3CSPAN%3E%20%2FlinkServer%20flash--probe%20H3RHID4AC30FD--%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%20mimxrt1176xxxx%3A%20mimxR%3C%2FSPAN%3E%3CSPAN%3E%20T1170-EVKB%3C%2FSPAN%3E%3CSPAN%3E%20%E5%8A%A0%E8%BD%BD%2F%E7%94%A8%E6%88%B7%2FMelker%2FCodeProjects%2Faudiobox%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode_core%2Farmgcc%2Fflexspi_nor_d%20ebug%2Ffre%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A48.405%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%EF%BC%BD%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E9%94%99%E8%AF%AF%5D%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E4%BB%A5%E4%BB%A3%E7%A0%81%20%3C%2FSPAN%3E%3CSPAN%3E255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A48.405%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%EF%BC%BD%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E9%94%99%E8%AF%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3E%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%20%60check%60%EF%BC%9A%E4%B8%8D%E9%9C%80%E8%A6%81%20-%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%BC%BA%E5%88%B6%E6%9B%B4%E6%96%B0%EF%BC%9A%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%E5%BC%BA%E5%88%B6%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%EF%BC%9ALinkServer%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3CSPAN%3E%20v25.7%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%202025%3C%2FSPAN%3E%3CSPAN%3E%20%E5%B9%B4%207%20%E6%9C%88%3C%2FSPAN%3E%3CSPAN%3E%2021%3C%2FSPAN%3E%3CSPAN%3E%20%E6%97%A5%2020%3C%2FSPAN%3E%3CSPAN%3E%20%3A37%3A00-crt_emu_cm_redl%3C%2FSPAN%3E%3CSPAN%3E%20ink%3C%2FSPAN%3E%3CSPAN%3E%20%E7%89%88%E6%9C%AC%201038%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%E8%AF%BB%E5%8F%96%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%3CSPAN%3E03%3C%2FSPAN%3E%3CSPAN%3E).%E4%B8%8D%E6%94%AF%E6%8C%81%E9%AB%98%E9%80%9F%E7%BC%93%E5%AD%98%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%9C%A8%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmp3tmcfgxp%2Fcrt_directory.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E9%80%9A%E7%94%A8%E7%9B%AE%E5%BD%95%20XML%20%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%94%B5%E8%84%91%EF%BC%9A%20(%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3CSPAN%3E)%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%9E%E6%8E%A5%20M7%20%E5%92%8C%E5%94%A4%E9%86%92%20M4%20%E8%84%9A%E6%9C%AC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AAPID%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20M4%20%E6%97%8B%E8%BD%AC%E7%BC%96%E7%A0%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20M4%20%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20RESET%20M4%20%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E6%9F%A5%E7%9C%8B%20DAP%20AP%20%E4%B8%8A%E7%9A%84%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E0%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%20M7%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%208477%200001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AM4%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20247700%2011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%9B%BA%E4%BB%B6%EF%BC%9A%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AVID%3APID%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AUSB%20%E8%B7%AF%E5%BE%84%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E0014%3A0002%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E4%B8%80%E4%B8%AA%E5%A5%BD%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%B7%B2%E8%BF%9E%E6%8E%A5%E7%9A%84%E6%A8%A1%E6%8B%9F%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E40%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E50%3C%2FSPAN%3E%3CSPAN%3E)CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSIGHT%20DP%EF%BC%88DAP%20DP%20ID%206BA02477%EF%BC%89over%20SW%3C%2FSPAN%3E%20%3CSPAN%3ED%20TAP%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ADAP%20AP%20%E4%B8%8A%E7%9A%84%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M7%20(CPU%20ID%2000000C27)%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9Ah%2Fw%20%E6%96%AD%E7%82%B9%E6%95%B0%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9Ah%2Fw%20%E7%9B%91%E8%A7%86%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%8E%A2%E5%A4%B4(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%E5%B7%B2%E8%BF%9E%E6%8E%A5%26amp%3B%E9%87%8D%E7%BD%AE%E3%80%82DpID%3A%206BA02477.CpuID%3A%2000000C27.%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3A%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%20%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E6%8D%89%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%EF%BC%9ACoreSight%20%E7%9A%84%E5%86%85%E5%AE%B9%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3EROM(s)%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ARBASE%20E00fd000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E000008E88C%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3Ee00fe000%3A%20cid%20b105100d%20pid%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3EE00FF000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE000E000%EF%BC%9A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%3CSPAN%3EGen%20SCS%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0001000%EF%BC%9ACID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB002%3C%2FSPAN%3E%3CSPAN%3EGen%20DWT%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0002000%3ACID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%3CSPAN%3E%E5%9F%BA%E5%9B%A0%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0000000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB001%3C%2FSPAN%3E%3CSPAN%3EGen%20ITM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%3C%2FSPAN%3E%3CSPAN%3E%202%3C%2FSPAN%3E%3CSPAN%3E%20E0041000%EF%BC%9ACID%20B105900D%20PID%3C%2FSPAN%3E%3CSPAN%3E%2004001BB975%3C%2FSPAN%3E%3CSPAN%3E%20cS%20t%20ARM%3C%2FSPAN%3E%3CSPAN%3E%20etmv4.0%3C%2FSPAN%3E%3CSPAN%3E%20%E7%B1%BB%E5%9E%8B%3C%2FSPAN%3E%3CSPAN%3E%200%20x13%3C%2FSPAN%3E%3CSPAN%3E%20%E8%BF%BD%E8%B8%AA%E6%BA%90%E2%80%94%E2%80%94%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%3C%2FSPAN%3E%3CSPAN%3E%202%3C%2FSPAN%3E%3CSPAN%3E%20E0042000%EF%BC%9ACID%20B105900D%20PID%3C%2FSPAN%3E%3CSPAN%3E%2004004BB906%3C%2FSPAN%3E%3CSPAN%3E%20cS%20T%20%E7%B1%BB%E5%9E%8B%3C%2FSPAN%3E%3CSPAN%3E%200x14%3C%2FSPAN%3E%3CSPAN%3E%20%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%20%E6%8E%A7%E5%88%B6%E2%80%94%E2%80%94%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%E7%AD%89%E7%AD%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3EE0043000%EF%BC%9ACID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB908%3C%2FSPAN%3E%3CSPAN%3ECSt%20CSTF%20%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%E8%B7%9F%E8%B8%AA%E9%93%BE%E6%8E%A5%20-%20%E8%B7%9F%E8%B8%AA%E6%BC%8F%E6%96%97%2F%E8%B7%AF%E7%94%B1%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ANXP%EF%BC%9AMIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ADAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%82%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E256%20%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%3C%2FSPAN%3E%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%B7%B2%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20%E5%9C%A8%20SPI%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%8A%E6%A3%80%E6%9F%A5%20%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E%20v.2%3C%2FSPAN%3E%3CSPAN%3E%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%20mimxrt1170_sfdp_qspi.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%9B%BE%E5%83%8F%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E5%8F%98%E4%BD%93%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3CSPAN%3E%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%8864MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E65%3C%2FSPAN%3E%3CSPAN%3E)%E8%8A%AF%E7%89%87%E8%AE%BE%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%94%B5%E8%84%91%EF%BC%9A%20(%20%3C%2FSPAN%3E%3CSPAN%3E70%3C%2FSPAN%3E%3CSPAN%3E)%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%A3%80%E6%9F%A5%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30000400%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E(%E5%B7%B2%E9%A9%BB%E7%95%99%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AD%A6%E5%91%8A%20-%20%E5%90%AF%E5%8A%A8%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%A4%B1%E8%B4%A5%EF%BC%88%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E0x2000009D%3C%2FSPAN%3E%3CSPAN%3E%3F)%20-%20rc%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EV.2%3C%2FSPAN%3E%3CSPAN%3E%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20RC%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%86%99%E5%85%A5%20Flash%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%9ANn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30001000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%86%99%E5%85%A5%20Flash%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%9ANn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x12044%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%86%99%E5%85%A5%20Flash%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%9ANn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x7144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%86%99%E5%85%A5%20Flash%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%9ANn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%B6%EF%BC%9A(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E7%9B%AE%E6%A0%87%E6%93%8D%E4%BD%9C%E5%A4%B1%E8%B4%A5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E9%94%99%E8%AF%AF%E5%85%B3%E9%97%AD%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E7%BA%BF%E8%B7%AF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%E4%B8%8E%20MIMXRT1176xxxxx%3AMIMXR%20%E5%AE%8C%E5%85%A8%E5%8C%B9%E9%85%8D%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-%E6%89%BE%E5%88%B0EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%E6%89%80%E9%80%89%E8%AE%BE%E5%A4%87%20mimxrt1176xxxxx%3A%20mimxR%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3ET1170-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%E8%8E%B7%E5%8F%96%E5%8F%AF%E7%94%A8%E6%8E%A2%E9%92%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%E9%80%9A%E8%BF%87%E5%BA%8F%E5%88%97%E5%AD%90%E4%B8%B2%E9%80%89%E6%8B%A9%E6%B5%8B%E5%A4%B4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%E6%89%80%E9%80%89%E6%8E%A2%E6%B5%8B%E5%99%A8%20%23%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20H3RHID4AC30FD%EF%BC%88%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-%20DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%EF%BC%89%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AMCU-Link%20%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%20%60check%60%EF%BC%9AProbe%EF%BC%88%5BH3RHID4AC30FD%5D%20%5B%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%5D%EF%BC%89%3C%2FSPAN%3E%3CSPAN%3E%20%E5%B7%B2%E7%BB%8F%E8%BF%90%E8%A1%8C%E4%B8%8E%E9%9A%8F%E9%99%84%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E7%9B%B8%E5%90%8C%E7%9A%84%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%5B3.%3C%2FSPAN%3E%3CSPAN%3E%20160%5D%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%85%B3%E9%94%AE%3C%2FSPAN%3E%3CSPAN%3E%3A%E4%B8%A5%E9%87%8D%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EERRMSG%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E%E5%BC%82%E5%B8%B8%3C%2FSPAN%3E%3CSPAN%3E%3A%E9%97%AA%E5%AD%98%E6%93%8D%E4%BD%9C%E9%80%80%E5%87%BA%EF%BC%8C%E4%BB%A3%E7%A0%81%E4%B8%BA%20%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E1%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E8%BF%99%E6%98%AF%E9%97%AA%E5%AD%98%E5%AE%9E%E9%99%85%E6%88%90%E5%8A%9F%E6%97%B6%E7%9A%84%E6%97%A5%E5%BF%97%20%3C%2FSTRONG%3E%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.927%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.928%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.928%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A14.329%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A14.338%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A14.346%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%3C%2FSPAN%3E%3CSPAN%3E%2001%3A03%3A17.511%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%207%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%2033%3C%2FSPAN%3E%3CSPAN%3E%20%2FlinkServer%20flash--probe%20H3RHID4AC30FD--%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%20mimxrt1176xxxx%3A%20mimxR%3C%2FSPAN%3E%3CSPAN%3E%20T1170-EVKB%3C%2FSPAN%3E%3CSPAN%3E%20%E5%8A%A0%E8%BD%BD%2F%E7%94%A8%E6%88%B7%2FMelker%2FCodeProjects%2Faudiobox%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode_core%2Farmgcc%2Fflexspi_nor_d%20ebug%2Ffre%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A23.784%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%20%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%E5%AE%8C%E5%85%A8%E5%8C%B9%E9%85%8D%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E%E5%8F%91%E7%8E%B0%20-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%E6%89%80%E9%80%89%E8%AE%BE%E5%A4%87%20mimxrt1176xxxxx%3A%20mimxR%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3ET1170-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%E8%8E%B7%E5%8F%96%E5%8F%AF%E7%94%A8%E6%8E%A2%E9%92%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%E9%80%9A%E8%BF%87%E5%BA%8F%E5%88%97%E5%AD%90%E4%B8%B2%E9%80%89%E6%8B%A9%E6%B5%8B%E5%A4%B4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%E6%89%80%E9%80%89%E6%8E%A2%E6%B5%8B%E5%99%A8%20%23%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20H3RHID4AC30FD%EF%BC%88%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-%20DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%EF%BC%89%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AMCU-Link%20%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%20%60check%60%EF%BC%9AProbe%EF%BC%88%5BH3RHID4AC30FD%5D%20%5B%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%5D%EF%BC%89%3C%2FSPAN%3E%3CSPAN%3E%20%E5%B7%B2%E7%BB%8F%E8%BF%90%E8%A1%8C%E4%B8%8E%E9%9A%8F%E9%99%84%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E7%9B%B8%E5%90%8C%E7%9A%84%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%5B3.%3C%2FSPAN%3E%3CSPAN%3E%20160%5D%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A23.784%3C%2FSPAN%3E%3CSPAN%3E%5D%5B%E9%93%BE%E6%8E%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%5D%3C%2FSPAN%3E%3CSPAN%3E%E9%93%BE%E6%8E%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E9%97%AA%E5%AD%98%E6%93%8D%E4%BD%9C%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%20%22%E6%A3%80%E6%9F%A5%22%EF%BC%9A%E4%B8%8D%E9%9C%80%E8%A6%81%20-%20%E5%8F%AF%E4%BD%BF%E7%94%A8%22.%2FLinkServer%20probe%20%23%22%E5%BC%BA%E5%88%B6%E6%9B%B4%E6%96%B0%EF%BC%9A%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%E5%BC%BA%E5%88%B6%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%EF%BC%9ALinkServer%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3CSPAN%3E%20v25.7%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%202025%3C%2FSPAN%3E%3CSPAN%3E%20%E5%B9%B4%207%20%E6%9C%88%3C%2FSPAN%3E%3CSPAN%3E%2021%3C%2FSPAN%3E%3CSPAN%3E%20%E6%97%A5%2020%3C%2FSPAN%3E%3CSPAN%3E%20%3A37%3A00-crt_emu_cm_redl%3C%2FSPAN%3E%3CSPAN%3E%20ink%3C%2FSPAN%3E%3CSPAN%3E%20%E7%89%88%E6%9C%AC%201038%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%E8%AF%BB%E5%8F%96%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%3CSPAN%3E03%3C%2FSPAN%3E%3CSPAN%3E).%E4%B8%8D%E6%94%AF%E6%8C%81%E9%AB%98%E9%80%9F%E7%BC%93%E5%AD%98%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%9C%A8%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmpci6yg1l_%2Fcrt_directory.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E9%80%9A%E7%94%A8%E7%9B%AE%E5%BD%95%20XML%20%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%94%B5%E8%84%91%EF%BC%9A%20(%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3CSPAN%3E)%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%9E%E6%8E%A5%20M7%20%E5%92%8C%E5%94%A4%E9%86%92%20M4%20%E8%84%9A%E6%9C%AC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AAPID%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20M4%20%E6%97%8B%E8%BD%AC%E7%BC%96%E7%A0%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20M4%20%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20RESET%20M4%20%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E5%8F%91%E5%B8%83%20M4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E6%9F%A5%E7%9C%8B%20DAP%20AP%20%E4%B8%8A%E7%9A%84%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E0%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%20M7%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%208477%200001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AM4%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20247700%2011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%9B%BA%E4%BB%B6%EF%BC%9A%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AVID%3APID%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AUSB%20%E8%B7%AF%E5%BE%84%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E0014%3A0002%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E4%B8%80%E4%B8%AA%E5%A5%BD%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%B7%B2%E8%BF%9E%E6%8E%A5%E7%9A%84%E6%A8%A1%E6%8B%9F%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E40%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E50%3C%2FSPAN%3E%3CSPAN%3E)CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSIGHT%20DP%EF%BC%88DAP%20DP%20ID%206BA02477%EF%BC%89over%20SW%3C%2FSPAN%3E%20%3CSPAN%3ED%20TAP%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ADAP%20AP%20%E4%B8%8A%E7%9A%84%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M7%20(CPU%20ID%2000000C27)%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9Ah%2Fw%20%E6%96%AD%E7%82%B9%E6%95%B0%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9Ah%2Fw%20%E7%9B%91%E8%A7%86%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%8E%A2%E5%A4%B4(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%E5%B7%B2%E8%BF%9E%E6%8E%A5%26amp%3B%E9%87%8D%E7%BD%AE%E3%80%82DpID%3A%206BA02477.CpuID%3A%2000000C27.%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3A%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%20%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E6%8D%89%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%EF%BC%9ACoreSight%20%E7%9A%84%E5%86%85%E5%AE%B9%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3EROM(s)%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ARBASE%20E00fd000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E000008E88C%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3Ee00fe000%3A%20cid%20b105100d%20pid%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3EE00FF000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE000E000%EF%BC%9A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%3CSPAN%3EGen%20SCS%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0001000%EF%BC%9ACID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB002%3C%2FSPAN%3E%3CSPAN%3EGen%20DWT%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0002000%3ACID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%3CSPAN%3E%E5%9F%BA%E5%9B%A0%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0000000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB001%3C%2FSPAN%3E%3CSPAN%3EGen%20ITM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%3C%2FSPAN%3E%3CSPAN%3E%202%3C%2FSPAN%3E%3CSPAN%3E%20E0041000%EF%BC%9ACID%20B105900D%20PID%3C%2FSPAN%3E%3CSPAN%3E%2004001BB975%3C%2FSPAN%3E%3CSPAN%3E%20cS%20t%20ARM%3C%2FSPAN%3E%3CSPAN%3E%20etmv4.0%3C%2FSPAN%3E%3CSPAN%3E%20%E7%B1%BB%E5%9E%8B%3C%2FSPAN%3E%3CSPAN%3E%200%20x13%3C%2FSPAN%3E%3CSPAN%3E%20%E8%BF%BD%E8%B8%AA%E6%BA%90%E2%80%94%E2%80%94%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%3C%2FSPAN%3E%3CSPAN%3E%202%3C%2FSPAN%3E%3CSPAN%3E%20E0042000%EF%BC%9ACID%20B105900D%20PID%3C%2FSPAN%3E%3CSPAN%3E%2004004BB906%3C%2FSPAN%3E%3CSPAN%3E%20cS%20T%20%E7%B1%BB%E5%9E%8B%3C%2FSPAN%3E%3CSPAN%3E%200x14%3C%2FSPAN%3E%3CSPAN%3E%20%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%20%E6%8E%A7%E5%88%B6%E2%80%94%E2%80%94%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%E7%AD%89%E7%AD%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3EE0043000%EF%BC%9ACID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB908%3C%2FSPAN%3E%3CSPAN%3ECSt%20CSTF%20%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%E8%B7%9F%E8%B8%AA%E9%93%BE%E6%8E%A5%20-%20%E8%B7%9F%E8%B8%AA%E6%BC%8F%E6%96%97%2F%E8%B7%AF%E7%94%B1%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ANXP%EF%BC%9AMIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ADAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%82%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E256%20%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%3C%2FSPAN%3E%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%B7%B2%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20%E5%9C%A8%20SPI%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%8A%E6%A3%80%E6%9F%A5%20%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E%20v.2%3C%2FSPAN%3E%3CSPAN%3E%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%20mimxrt1170_sfdp_qspi.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%9B%BE%E5%83%8F%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E5%8F%98%E4%BD%93%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3CSPAN%3E%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%8864MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E65%3C%2FSPAN%3E%3CSPAN%3E)%E8%8A%AF%E7%89%87%E8%AE%BE%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%94%B5%E8%84%91%EF%BC%9A%20(%20%3C%2FSPAN%3E%3CSPAN%3E70%3C%2FSPAN%3E%3CSPAN%3E)%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%A3%80%E6%9F%A5%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30000400%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E(%E5%B7%B2%E9%A9%BB%E7%95%99%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E5%8F%98%E4%BD%93%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3CSPAN%3E%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%8864MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%200x30000%2040%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%E5%A4%84%3C%2FSPAN%3E%3CSPAN%3E%20%E5%86%99%E5%85%A5%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20-%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%AA%20%E6%89%87%E5%8C%BA%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%8C%E5%85%B6%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%8C512%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A(%3C%2FSPAN%3E%3CSPAN%3E%200)%3C%2FSPAN%3E%3CSPAN%3E%20%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030000000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82-0%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%2F15%3C%2FSPAN%3E%3CSPAN%3E%2036%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%20100%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030000000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2016384%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E-16384%2F%3C%2FSPAN%3E%3CSPAN%3E%201536%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%E5%B7%B2%E5%AE%8C%E6%88%90%20%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%20%3C%2FSPAN%3E%3CSPAN%3E1536%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%80%E5%86%99%E9%83%A8%E9%97%A8%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20%E4%B8%8D%E5%8F%98%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%E6%80%BB%E8%AE%A1%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%E6%88%90%E5%8A%9F%E5%86%99%E5%85%A5%20Flash%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E5%9C%A8%20295%3C%2FSPAN%3E%3CSPAN%3E%20%E6%AF%AB%E7%A7%92%E5%86%85%E5%8A%A0%E8%BD%BD%200x200%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%EF%BC%88%E5%A4%A7%E7%BA%A6%201KB%2Fs%20%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30001000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E(%E5%B7%B2%E9%A9%BB%E7%95%99%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E5%8F%98%E4%BD%93%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3CSPAN%3E%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%8864MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%200x3%20000%20100%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%E5%A4%84%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%E5%86%99%E5%85%A5%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20-%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E0%20%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%20%E6%89%87%E5%8C%BA%20%EF%BC%8C%E5%85%B6%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%AA%20%EF%BC%8C48%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A(%3C%2FSPAN%3E%3CSPAN%3E%200)%3C%2FSPAN%3E%3CSPAN%3E%20%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030000000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82-%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%2F%3C%2FSPAN%3E%3CSPAN%3E%204144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%20100%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030000000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2016384%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E-16384%2F4144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%E5%B7%B2%E5%AE%8C%E6%88%90%20%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%20%3C%2FSPAN%3E%3CSPAN%3E4144%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%80%E5%86%99%E9%83%A8%E9%97%A8%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20%E4%B8%8D%E5%8F%98%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%E6%80%BB%E8%AE%A1%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%E6%88%90%E5%8A%9F%E5%86%99%E5%85%A5%20Flash%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E5%9C%A8%20310%3C%2FSPAN%3E%3CSPAN%3E%20%E6%AF%AB%E7%A7%92%E5%86%85%E5%8A%A0%E8%BD%BD%200x30%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%EF%BC%88%E5%A4%A7%E7%BA%A6%200KB%2Fs%20%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x12044%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E(%E5%B7%B2%E9%A9%BB%E7%95%99%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E5%8F%98%E4%BD%93%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3CSPAN%3E%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%8864MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%200%20x3%20000%202000%3C%2FSPAN%3E%3CSPAN%3E%20%E5%A4%84%20%E5%86%99%E5%85%A5%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20-%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%AA%E6%89%87%E5%8C%BA%EF%BC%8C%E5%85%B6%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%200%20%EF%BC%89%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%AA%E6%89%87%E5%8C%BA%EF%BC%8C737%2096%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A(%3C%2FSPAN%3E%3CSPAN%3E%200)%3C%2FSPAN%3E%3CSPAN%3E%20%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030000000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82-%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%2F%3C%2FSPAN%3E%3CSPAN%3E%2081988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%2019%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030000000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2016384%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E-16384%2F81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%E5%B7%B2%E5%AE%8C%E6%88%90%20%3C%2FSPAN%3E%3CSPAN%3E19%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E5%87%BA%20%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A(%3C%2FSPAN%3E%3CSPAN%3E%2039)%3C%2FSPAN%3E%3CSPAN%3E%20%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030004000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2016384%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E-32768%2F81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E30008000%3C%2FSPAN%3E%3CSPAN%3E%E5%B7%B2%E5%AE%8C%E6%88%90%20%3C%2FSPAN%3E%3CSPAN%3E39%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E32768%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%20%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%2059%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030008000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2016384%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%E8%8A%82-49152%2F81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A3000C000%20%E5%B7%B2%E5%AE%8C%E6%88%90%20%3C%2FSPAN%3E%3CSPAN%3E59%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E49152%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%20%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A(%3C%2FSPAN%3E%3CSPAN%3E%2079)%3C%2FSPAN%3E%3CSPAN%3E%20%E5%9C%A8%203000C000%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2016384%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82-%206%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E5536%2F81988%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E30010000%3C%2FSPAN%3E%3CSPAN%3E%E5%B7%B2%E5%AE%8C%E6%88%90%20%3C%2FSPAN%3E%3CSPAN%3E79%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E65536%3C%2FSPAN%3E%3CSPAN%3E%E5%87%BA%20%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%20100%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%3E%2030010000%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2065536%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%20-1310%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E72%2F81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%80%E5%86%99%E9%83%A8%E9%97%A8%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20%E4%B8%8D%E5%8F%98%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20%E6%80%BB%E8%AE%A1%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%E6%88%90%E5%8A%9F%E5%86%99%E5%85%A5%20Flash%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E5%9C%A8%20499ms%3C%2FSPAN%3E%3CSPAN%3E%20%E5%86%85%E5%8A%A0%E8%BD%BD%200x12044%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%EF%BC%88%20%E5%A4%A7%E7%BA%A6%20147KB%2Fs%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x7144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E(%E5%B7%B2%E9%A9%BB%E7%95%99%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E5%8F%98%E4%BD%93%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3CSPAN%3E%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%8864MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%201(%3C%2FSPAN%3E%3CSPAN%3E%200)%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%20%E5%86%99%E5%85%A5%E6%89%87%E5%8C%BA%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%AD%E7%9A%84%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%201020-1020%3C%2FSPAN%3E%3CSPAN%3E%20%E4%BD%8D%E4%BA%8E%3C%2FSPAN%3E%3CSPAN%3E%200x33FC0000%EF%BC%8C28996%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%9C%A8%2033FC0000%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%82-%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2F2899%3C%2FSPAN%3E%20%3CSPAN%3E6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%2056%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E5%9C%A8%2033FC0000%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2016384%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82-%2016%20384%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E%2028996%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A33FC4000%20%E5%B7%B2%E5%AE%8C%E6%88%90%20%3C%2FSPAN%3E%3CSPAN%3E56%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%20%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E8%A8%80%EF%BC%9A%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%20100%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E5%9C%A8%2033FC4000%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2016384%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82-%203%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E2768%2F28996%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A33FC8000%20%E5%B7%B2%E5%AE%8C%E6%88%90%20%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E32768%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%20%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%80%E5%86%99%E9%83%A8%E9%97%A8%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20%E4%B8%8D%E5%8F%98%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%E6%80%BB%E8%AE%A1%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%E6%88%90%E5%8A%9F%E5%86%99%E5%85%A5%20Flash%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E5%9C%A8%20550%3C%2FSPAN%3E%3CSPAN%3E%20%E6%AF%AB%E7%A7%92%E5%86%85%E5%8A%A0%E8%BD%BD%200x7144%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%EF%BC%88%E5%A4%A7%E7%BA%A6%205%202KB%2Fs%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9ARESET%20%E7%9B%AE%E6%A0%87%EF%BC%88%E7%B3%BB%E7%BB%9F%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3ERT1170_reset.scp%3C%2FSPAN%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AF%A5%E6%8E%A2%E5%A4%B4%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%BF%99%E4%B8%AA%20TAP%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AF%A5%E6%A0%B8%E5%BF%83%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E7%B3%BB%E7%BB%9FRESET%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E7%BA%BF%E9%80%9F%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E10000000%3C%2FSPAN%3E%3CSPAN%3E%E8%B5%AB%E5%85%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E0%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%20M7%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%208477%200001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A6BA02477%20AP%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AAPID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%2024770011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9AE00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A6BA02477%20AP%3C%2FSPAN%3E%3CSPAN%3E%202%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20APID%EF%BC%9A54770002%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%200000000%202%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AAPID%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20M4%20%E6%97%8B%E8%BD%AC%E7%BC%96%E7%A0%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20M4%20%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20RESET%20M4%20%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E5%8F%91%E5%B8%83%20M4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E6%9F%A5%E7%9C%8B%20DAP%20AP%20%E4%B8%8A%E7%9A%84%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E0%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%20M7%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%208477%200001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AM4%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20247700%2011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AR15%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x00223104%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E7%9F%A2%E9%87%8F%E8%A1%A8%20SP%2FPC%20%E6%98%AF%20RESET%20%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9APC%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x3000247D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ASP%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x20040000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AXPSR%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x01000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AVTOR%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20DEMCR%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x010007F1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%EF%BC%9A%E5%81%9C%E6%AD%A2%EF%BC%9A%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ens%EF%BC%9ARESET%E6%97%B6%E9%87%8D%E5%90%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%9C%89%20MCU-Link%20%E7%9A%84%E6%9C%80%E6%96%B0%E5%9B%BA%E4%BB%B6%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%8C%89%E7%85%A7%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%E5%9C%A8%E9%97%AA%E5%85%89%E7%81%AF%E4%B9%8B%E5%89%8D%20RESET%20%E6%8E%A2%E5%A4%B4%E5%B9%B6%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E5%8C%BA%E5%88%AB%E3%80%82%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%97%B6%E5%80%99%E8%BF%98%E6%98%AF%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A34.034%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A34.035%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A34.035%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%2009%3A09%3A35.4%3C%2FSPAN%3E%3CSPAN%3E%2033%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5B%E4%BF%A1%E6%81%AF%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2Fmcuxpressoide_24%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%2012%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20148%3C%2FSPAN%3E%3CSPAN%3E%20%2Fide%2Ftools%2Fbin%2Farm%20-none-eab%20i-gcc--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A09%3A35.436%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%3C%2FSPAN%3E%3CSPAN%3E%20%2Fusers%2Fmelker%2F.mcuxpressoTools%2FArm-GNU-Toolchain-13.2.rel1-darwin-x86_64-ar%3C%2FSPAN%3E%3CSPAN%3E%20m-none-eabi-gcc--v%20ersion%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%2009%3A09%3A35.45%3C%2FSPAN%3E%3CSPAN%3E%208%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5B%E4%BF%A1%E6%81%AF%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2Fmcuxpressoide_24%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%2012%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20148%3C%2FSPAN%3E%3CSPAN%3E%20%2Fide%2Ftools%2Fbin%2Farm%20-none-eab%20i-gcc--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A09%3A35.470%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%3C%2FSPAN%3E%3CSPAN%3E%20%2Fusers%2Fmelker%2F.mcuxpressoTools%2FArm-GNU-Toolchain-13.2.rel1-darwin-x86_64-ar%3C%2FSPAN%3E%3CSPAN%3E%20m-none-eabi-gcc--v%20ersion%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A09%3A35.481%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2Fusers%2Fmelker%2F.mcuxpressoTools%2FArm-GNU-Toolchain-13.2.rel1-%3C%2FSPAN%3E%3CSPAN%3E%20darwin-x86_64-arm-none-eabi-gcc--v%3C%2FSPAN%3E%3CSPAN%3E%20ersion%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A09%3A35.482%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2Fmc%20uxpressoide_24%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%2012%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20148%3C%2FSPAN%3E%3CSPAN%3E%20%2Fide%2Ftools%2Fbin%2Farm%20-none-eab%20i-gcc--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.963%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.965%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.966%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A32.425%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3E%E5%91%BD%E4%BB%A4%EF%BC%9A%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A32.426%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A32.427%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-09-18T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A10%3A35.933%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%207%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%2033%3C%2FSPAN%3E%3CSPAN%3E%20%2FlinkServer%20flash--probe%20H3RHID4AC30FD--%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%20mimxrt1176xxxx%3A%20mimxR%3C%2FSPAN%3E%3CSPAN%3E%20T1170-EVKB%3C%2FSPAN%3E%3CSPAN%3E%20%E5%8A%A0%E8%BD%BD%2F%E7%94%A8%E6%88%B7%2FMelker%2FCodeProjects%2Faudiobox%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode%2Fcode_core%2Farmgcc%2Fflexspi_nor_d%20ebug%2Ffre%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A39.480%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%EF%BC%BD%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E9%94%99%E8%AF%AF%5D%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20%E4%BB%A5%E4%BB%A3%E7%A0%81%20%3C%2FSPAN%3E%3CSPAN%3E255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A39.480%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%EF%BC%BD%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E9%94%99%E8%AF%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3E%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%20%60check%60%EF%BC%9A%E4%B8%8D%E9%9C%80%E8%A6%81%20-%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%BC%BA%E5%88%B6%E6%9B%B4%E6%96%B0%EF%BC%9A%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%E5%BC%BA%E5%88%B6%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%EF%BC%9ALinkServer%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3CSPAN%3E%20v25.7%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%202025%3C%2FSPAN%3E%3CSPAN%3E%20%E5%B9%B4%207%20%E6%9C%88%3C%2FSPAN%3E%3CSPAN%3E%2021%3C%2FSPAN%3E%3CSPAN%3E%20%E6%97%A5%2020%3C%2FSPAN%3E%3CSPAN%3E%20%3A37%3A00-crt_emu_cm_redl%3C%2FSPAN%3E%3CSPAN%3E%20ink%3C%2FSPAN%3E%3CSPAN%3E%20%E7%89%88%E6%9C%AC%201038%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%E8%AF%BB%E5%8F%96%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%3CSPAN%3E03%3C%2FSPAN%3E%3CSPAN%3E).%E4%B8%8D%E6%94%AF%E6%8C%81%E9%AB%98%E9%80%9F%E7%BC%93%E5%AD%98%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%9C%A8%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmps1gdrldt%2Fcrt_directory.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E9%80%9A%E7%94%A8%E7%9B%AE%E5%BD%95%20XML%20%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%94%B5%E8%84%91%EF%BC%9A%20(%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3CSPAN%3E)%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%9E%E6%8E%A5%20M7%20%E5%92%8C%E5%94%A4%E9%86%92%20M4%20%E8%84%9A%E6%9C%AC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9AAPID%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20M4%20%E6%97%8B%E8%BD%AC%E7%BC%96%E7%A0%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E8%AE%BE%E7%BD%AE%20M4%20%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20RESET%20M4%20%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E6%9F%A5%E7%9C%8B%20DAP%20AP%20%E4%B8%8A%E7%9A%84%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ADpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E0%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%20M7%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%208477%200001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9ATAP%3C%2FSPAN%3E%3CSPAN%3E%200%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A6BA02477%20%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AM4%20APID%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20247700%2011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20%E8%A1%A8%EF%BC%9A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%9B%BA%E4%BB%B6%EF%BC%9A%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AVID%3APID%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AUSB%20%E8%B7%AF%E5%BE%84%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E0014%3A0003%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E4%B8%80%E4%B8%AA%E5%A5%BD%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%B7%B2%E8%BF%9E%E6%8E%A5%E7%9A%84%E6%A8%A1%E6%8B%9F%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E40%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E50%3C%2FSPAN%3E%3CSPAN%3E)CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSIGHT%20DP%EF%BC%88DAP%20DP%20ID%206BA02477%EF%BC%89over%20SW%3C%2FSPAN%3E%20%3CSPAN%3ED%20TAP%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ADAP%20AP%20%E4%B8%8A%E7%9A%84%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M7%20(CPU%20ID%2000000C27)%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9Ah%2Fw%20%E6%96%AD%E7%82%B9%E6%95%B0%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9Ah%2Fw%20%E7%9B%91%E8%A7%86%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%8E%A2%E5%A4%B4(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%E5%B7%B2%E8%BF%9E%E6%8E%A5%26amp%3B%E9%87%8D%E7%BD%AE%E3%80%82DpID%3A%206BA02477.CpuID%3A%2000000C27.%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3A%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%20%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E6%8D%89%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%EF%BC%9ACoreSight%20%E7%9A%84%E5%86%85%E5%AE%B9%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3EROM(s)%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ARBASE%20E00fd000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E000008E88C%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3Ee00fe000%3A%20cid%20b105100d%20pid%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3EE00FF000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%3CSPAN%3EROM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE000E000%EF%BC%9A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%3CSPAN%3EGen%20SCS%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0001000%EF%BC%9ACID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB002%3C%2FSPAN%3E%3CSPAN%3EGen%20DWT%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0002000%3ACID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%3CSPAN%3E%E5%9F%BA%E5%9B%A0%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3EE0000000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB001%3C%2FSPAN%3E%3CSPAN%3EGen%20ITM%EF%BC%88%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%3C%2FSPAN%3E%3CSPAN%3E%202%3C%2FSPAN%3E%3CSPAN%3E%20E0041000%EF%BC%9ACID%20B105900D%20PID%3C%2FSPAN%3E%3CSPAN%3E%2004001BB975%3C%2FSPAN%3E%3CSPAN%3E%20cS%20t%20ARM%3C%2FSPAN%3E%3CSPAN%3E%20etmv4.0%3C%2FSPAN%3E%3CSPAN%3E%20%E7%B1%BB%E5%9E%8B%3C%2FSPAN%3E%3CSPAN%3E%200%20x13%3C%2FSPAN%3E%3CSPAN%3E%20%E8%BF%BD%E8%B8%AA%E6%BA%90%E2%80%94%E2%80%94%E9%85%B7%E7%9D%BF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%3C%2FSPAN%3E%3CSPAN%3E%202%3C%2FSPAN%3E%3CSPAN%3E%20E0042000%EF%BC%9ACID%20B105900D%20PID%3C%2FSPAN%3E%3CSPAN%3E%2004004BB906%3C%2FSPAN%3E%3CSPAN%3E%20cS%20T%20%E7%B1%BB%E5%9E%8B%3C%2FSPAN%3E%3CSPAN%3E%200x14%3C%2FSPAN%3E%3CSPAN%3E%20%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%20%E6%8E%A7%E5%88%B6%E2%80%94%E2%80%94%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%E7%AD%89%E7%AD%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9AROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3EE0043000%EF%BC%9ACID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB908%3C%2FSPAN%3E%3CSPAN%3ECSt%20CSTF%20%E7%B1%BB%E5%9E%8B%20%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%E8%B7%9F%E8%B8%AA%E9%93%BE%E6%8E%A5%20-%20%E8%B7%9F%E8%B8%AA%E6%BC%8F%E6%96%97%2F%E8%B7%AF%E7%94%B1%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ANXP%EF%BC%9AMIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9ADAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%3C%2FSPAN%3E%20%3CSPAN%3E1024%3C%2FSPAN%3E%20%3CSPAN%3E%E5%AD%97%E8%8A%82%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E256%20%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%3C%2FSPAN%3E%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%B7%B2%E4%BD%BF%E7%94%A8%20SFDP%20JEDEC%20ID%20%E5%9C%A8%20SPI%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%8A%E6%A3%80%E6%9F%A5%20%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E%20v.2%3C%2FSPAN%3E%3CSPAN%3E%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%20mimxrt1170_sfdp_qspi.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%9B%BE%E5%83%8F%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E5%8F%98%E4%BD%93%20%3C%2FSPAN%3E%3CSPAN%3EiMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07%3C%2FSPAN%3E%3CSPAN%3E%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%8864MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPC%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E65%3C%2FSPAN%3E%3CSPAN%3E)%E8%8A%AF%E7%89%87%E8%AE%BE%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%94%B5%E8%84%91%EF%BC%9A%20(%20%3C%2FSPAN%3E%3CSPAN%3E70%3C%2FSPAN%3E%3CSPAN%3E)%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%A3%80%E6%9F%A5%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30000400%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E(%E5%B7%B2%E9%A9%BB%E7%95%99%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%8F%91%E9%80%81%20VECTRESET%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%87%BA%E9%94%99%E5%90%8E%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%20-%20Nn(%2005%20)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%BB%E5%8F%96%20DAP%20%E4%B8%AD%E7%9A%84%E5%9C%B0%E5%9D%80%E5%AF%84%E5%AD%98%E5%99%A8%E5%A4%B1%E8%B4%A5%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%BD%AE%E8%AF%A2%E7%9A%84%E9%82%AE%E7%AE%B1%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%200x2000a840%3C%2FSPAN%3E%3CSPAN%3E%20%E5%A4%84%E4%B8%BA%208%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E8%AF%BB%E5%8F%96%E5%A4%B1%E8%B4%A5%EF%BC%88%E8%BD%AE%E8%AF%A2%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%2F%3C%2FSPAN%3E%3CSPAN%3E%2030%3C%2FSPAN%3E%3CSPAN%3E%201%20%E6%97%B6%EF%BC%89-1%20%E6%AF%AB%E7%A7%92%20%E5%90%8E%E9%87%8D%E8%AF%95-rc%20Em%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E(17)%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20%E8%AE%BF%E9%97%AE%3C%2FSPAN%3E%3CSPAN%3E%20%E4%BD%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%3E%200x2000a840%20%E5%90%8E%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%40%40%20%E8%B0%83%E8%AF%95%20%E7%AB%AF%E5%8F%A3%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E5%87%BA%E9%94%99%E5%90%8E%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%20-%20Nn(%2005%20)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%BB%E5%8F%96%20DAP%20%E4%B8%AD%E7%9A%84%E5%9C%B0%E5%9D%80%E5%AF%84%E5%AD%98%E5%99%A8%E5%A4%B1%E8%B4%A5%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%EF%BC%9A%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%BD%AE%E8%AF%A2%E7%9A%84%E9%82%AE%E7%AE%B1%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%200x2000a840%3C%2FSPAN%3E%3CSPAN%3E%20%E5%A4%84%E4%B8%BA%208%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%89%E8%AF%BB%E5%8F%96%E5%A4%B1%E8%B4%A5%EF%BC%88%E5%9C%A8%E6%8A%95%E7%A5%A8%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20%2F%3C%2FSPAN%3E%3CSPAN%3E%2030%3C%2FSPAN%3E%3CSPAN%3E%201%20%E4%B8%8A%20%EF%BC%89-%E6%9A%82%E5%81%9C%E8%BF%9B%E8%A1%8C%E4%BA%8B%E5%90%8E%E5%88%86%E6%9E%90-rc%20Em%20(17)%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20%E8%AE%BF%E9%97%AE%3C%2FSPAN%3E%3CSPAN%3E%20%E4%BD%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%3E%200x2000a840%20%E5%90%8E%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%40%40%20%E8%B0%83%E8%AF%95%20%E7%AB%AF%E5%8F%A3%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EWC%EF%BC%9A%E6%9C%AA%E8%83%BD%E5%81%9C%E6%AD%A2%E7%9B%AE%E6%A0%87%E7%9A%84%E6%AD%BB%E5%90%8E%E6%A3%80%E6%9F%A5%20-%20RC%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E5%A4%B1%E8%B4%A5%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EV.2%3C%2FSPAN%3E%3CSPAN%3E%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%20-%20RC%20Em(%3C%2FSPAN%3E%3CSPAN%3E17%3C%2FSPAN%3E%3CSPAN%3E).%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%E7%AB%AF%E5%8F%A3%E5%9C%A8%E8%AE%BF%E9%97%AE%E4%BD%8D%E7%BD%AE%20%3C%2FSPAN%3E%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%86%99%E5%85%A5%20Flash%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%9AEm(%3C%2FSPAN%3E%3CSPAN%3E17%3C%2FSPAN%3E%3CSPAN%3E).%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CSPAN%3E%E7%AB%AF%E5%8F%A3%E5%9C%A8%E8%AE%BF%E9%97%AE%E4%BD%8D%E7%BD%AE%20%3C%2FSPAN%3E%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30001000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%86%99%E5%85%A5%20Flash%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%9ANn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x12044%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%86%99%E5%85%A5%20Flash%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%9ANn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3EELF%20%3C%2FSPAN%3E%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%3CSPAN%3Elen%20%3C%2FSPAN%3E%3CSPAN%3E0x7144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%93%85%EF%BC%9A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E5%86%99%E5%85%A5%20Flash%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3CSPAN%3Efreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%9ANn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%B6%EF%BC%9A(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20%E7%9B%AE%E6%A0%87%E6%93%8D%E4%BD%9C%E5%A4%B1%E8%B4%A5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%EF%BC%9A%E8%AF%B7%E6%B1%82%E6%B8%85%E9%99%A4%20DAP%20%E9%94%99%E8%AF%AF%E5%A4%B1%E8%B4%A5%20-%20%E7%8A%B6%E6%80%81%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%E9%94%99%E8%AF%AF%E5%85%B3%E9%97%AD%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E7%BA%BF%E8%B7%AF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%E4%B8%8E%20MIMXRT1176xxxxx%3AMIMXR%20%E5%AE%8C%E5%85%A8%E5%8C%B9%E9%85%8D%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-%E6%89%BE%E5%88%B0EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%E6%89%80%E9%80%89%E8%AE%BE%E5%A4%87%20mimxrt1176xxxxx%3A%20mimxR%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3ET1170-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%E8%8E%B7%E5%8F%96%E5%8F%AF%E7%94%A8%E6%8E%A2%E9%92%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%E9%80%9A%E8%BF%87%E5%BA%8F%E5%88%97%E5%AD%90%E4%B8%B2%E9%80%89%E6%8B%A9%E6%B5%8B%E5%A4%B4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9A%E6%89%80%E9%80%89%E6%8E%A2%E6%B5%8B%E5%99%A8%20%23%3C%2FSPAN%3E%3CSPAN%3E%201%3C%2FSPAN%3E%3CSPAN%3E%20H3RHID4AC30FD%EF%BC%88%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-%20DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%EF%BC%89%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AMCU-Link%20%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%20%60check%60%EF%BC%9AProbe%EF%BC%88%5BH3RHID4AC30FD%5D%20%5B%E6%9D%BF%E8%BD%BD%20MCU-LINK%20(R0e2)%20CMSIS-DAP%3C%2FSPAN%3E%3CSPAN%3E%20V3.160%5D%EF%BC%89%3C%2FSPAN%3E%3CSPAN%3E%20%E5%B7%B2%E7%BB%8F%E8%BF%90%E8%A1%8C%E4%B8%8E%E9%9A%8F%E9%99%84%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E7%9B%B8%E5%90%8C%E7%9A%84%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%5B3.%3C%2FSPAN%3E%3CSPAN%3E%20160%5D%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%85%B3%E9%94%AE%3C%2FSPAN%3E%3CSPAN%3E%3A%E4%B8%A5%E9%87%8D%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EERRMSG%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%3E%20%E5%BC%82%E5%B8%B8%3C%2FSPAN%3E%3CSPAN%3E%20%EF%BC%9AFlash%20%E6%93%8D%E4%BD%9C%E4%BB%A5%E4%BB%A3%E7%A0%81%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%201%20%E9%80%80%E5%87%BA%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E6%88%91%20%E8%BF%98%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%BD%93%E9%97%AA%E5%AD%98%E7%9C%9F%E6%AD%A3%E6%88%90%E5%8A%9F%E6%97%B6%EF%BC%8CM4%20%E5%86%85%E6%A0%B8%E5%9C%A8%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%83%85%E5%86%B5%E4%B8%8B%E4%BC%9A%E8%90%BD%E5%90%8E%E4%B8%80%E4%B8%AA%E6%88%96%E5%A4%9A%E4%B8%AA%E7%89%88%E6%9C%AC%EF%BC%8C%E5%B0%BD%E7%AE%A1%E6%88%91%E5%9C%A8%E5%88%B7%E6%96%B0%E4%B9%8B%E5%89%8D%E5%AF%B9%E4%B8%A4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B8%85%E7%90%86%E5%92%8C%E9%87%8D%E5%BB%BA%E3%80%82%E4%BD%86%E6%98%AF%E6%9C%89%E6%97%B6%E5%80%99%EF%BC%8C%E4%B8%A4%E4%B8%AA%E5%86%85%E6%A0%B8%E4%BC%BC%E4%B9%8E%E6%98%AF%E9%9A%8F%E6%9C%BA%E8%8E%B7%E5%BE%97%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E8%BF%99%E6%98%AF%E6%9E%84%E5%BB%BA%E6%97%A5%E5%BF%97%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E6%89%A7%E8%A1%8C%E4%BB%BB%E5%8A%A1%EF%BC%9ACMake%EF%BC%9A%E7%89%88%E6%9C%AC%20M4%3C%2FP%3E%3CP%3E%E5%B7%A5%E4%BD%9C%E7%A9%BA%E9%97%B4%E6%98%AF%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%3CBR%20%2F%3E%E7%89%88%E6%9C%AC%E4%BB%BB%E5%8A%A1%E5%B7%B2%E5%90%AF%E5%8A%A8....%3CBR%20%2F%3E%2FUsers%2Fmelker%2F.mcuxpressotools%2Fcmake-3.30.0-macos10.10-universal%2FCMake.app%2FContents%2Fbin%2Fcmake%20--%E7%89%88%E6%9C%AC%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Farmgcc%2Fdebug%20--clean-first%20--target%20all%20--%3CBR%20%2F%3E%5B1%2F2%5D%20%E6%B8%85%E7%90%86%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6...%3CBR%20%2F%3E%5B2%2F2%5D%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E7%90%86%E6%89%80%E6%9C%89%E5%B7%B2%E7%89%88%E6%9C%AC%E7%9A%84%E6%96%87%E4%BB%B6...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%B8%85%E7%90%86...%2039%20%E4%B8%AA%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%5B1%2F39%5D%20%E6%9E%84%E5%BB%BA%20ASM%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fgcc%2Fstartup_MIMXRT1176_cm4%E3%80%82S.obj%3CBR%20%2F%3E%5B2%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fsystem_MIMXRT1176_cm4.c.obj%3CBR%20%2F%3E%5B3%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_common_arm.c.obj%3CBR%20%2F%3E%5B4%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_gpio.c.obj%3CBR%20%2F%3E%5B5%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_common.c.obj%3CBR%20%2F%3E%5B6%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fhardware_init.c.obj%3CBR%20%2F%3E%5B7%2F39%5D%20%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%20C%20%E8%AF%AD%E8%A8%80%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fpin_mux.c.obj%3CBR%20%2F%3E%5B8%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_anatop_ai.c.obj%3CBR%20%2F%3E%5B9%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_anatop_ai.c.obj.melker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fboard.c.obj%3CBR%20%2F%3E%5B10%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_mu.c.obj%3CBR%20%2F%3E%5B11%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fcomponents%2Fuart%2Ffsl_adapter_lpuart.c.obj%3CBR%20%2F%3E%5B12%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_gpc.c.obj%3CBR%20%2F%3E%5B13%2F39%5D%20%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%20C%20%E8%AF%AD%E8%A8%80%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core%E3%80%82elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fmain.c.obj%3CBR%20%2F%3E%5B14%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fcroutine.c.obj%3CBR%20%2F%3E%5B15%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fclock_config.c.obj%3CBR%20%2F%3E%5B16%2F39%5D%20%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%20C%20%E8%AF%AD%E8%A8%80%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core%E3%80%82elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Flist.c.obj%3CBR%20%2F%3E%5B17%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_pgmc.c%E3%80%82obj%3CBR%20%2F%3E%5B18%2F39%5D%20%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Fcm4%2Ffsl_cache.c%E3%80%82obj%3CBR%20%2F%3E%5B19%2F39%5D%20%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Ftimers.c%E3%80%82obj%3CBR%20%2F%3E%5B20%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fevent_groups.c.obj%3CBR%20%2F%3E%5B21%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fportable%2FGCC%2FARM_CM4F%2Fport.c.obj%3CBR%20%2F%3E%5B22%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_dcdc.c.obj%3CBR%20%2F%3E%5B23%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr.c.obj%3CBR%20%2F%3E%5B24%2F39%5D%20%E6%9E%84%E5%BB%BA%20ASM%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_memcpy.S.obj%3CBR%20%2F%3E%5B25%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_sbrk.c.obj%3CBR%20%2F%3E%5B26%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_syscall_stub.c.obj%3CBR%20%2F%3E%5B27%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fstream_buffer.c.obj%3CBR%20%2F%3E%5B28%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fqueue.c.obj%3CBR%20%2F%3E%5B29%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_lpuart.c.obj%3CBR%20%2F%3E%5B30%2F39%5D%20%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%20C%20%E8%AF%AD%E8%A8%80%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core%E3%80%82elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_clock.c.obj%3CBR%20%2F%3E%5B31%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_soc_src.c%E3%80%82obj%3CBR%20%2F%3E%5B32%2F39%5D%20%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Ftasks.c%E3%80%82obj%3CBR%20%2F%3E%5B33%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr_mu_internal.c.obj%3CBR%20%2F%3E%5B34%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_pmu.c.obj%3CBR%20%2F%3E%5B35%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr_internal_core_api_imxrt1170.c.obj%3CBR%20%2F%3E%5B36%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fdebug_console_lite%2Ffsl_assert.c.obj.obj%3CBR%20%2F%3E%5B37%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fdebug_console_lite%2Ffsl_debug_console.c.obj%3CBR%20%2F%3E%5B38%2F39%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf%E3%80%82dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fstr%2Ffsl_str.c.obj%3CBR%20%2F%3E%5B39%2F39%5D%20%E9%93%BE%E6%8E%A5%20C%20%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%20freertos_message_buffers_secondary_core.elf%3CBR%20%2F%3E%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%E5%B7%B2%E7%94%A8%E5%86%85%E5%AD%98%E5%A4%A7%E5%B0%8F%E5%8C%BA%E5%9F%9F%E5%A4%A7%E5%B0%8F%20%25age%20%E5%B7%B2%E4%BD%BF%E7%94%A8%20%3CBR%20%2F%3E%20m_interrupts%EF%BC%9A1%20KB%201%20KB%20100.00%25%20m_t%20%3CBR%20%2F%3E%20ext%EF%BC%9A27876%20B%20127%20KB%2021.44%25%20m_d%20%3CBR%20%2F%3E%20ata%EF%BC%9A3280%20B%20127%20KB%202.5%20%3CBR%20%2F%3E%202%25%20m_%20%3CBR%20%2F%3E%20ncache%EF%BC%9A0%20GB%20256%20KB%200.00%25%20m_heap%EF%BC%9A1%20KB%201%20KB%20100.00%25%20rpmsg_sh_mem%EF%BC%9A6%20KB%208%20KB%2075.00%25%20m_heap%EF%BC%9A1%20KB%201%20KB%20100.00%25%20rpmsg_sh_mem%EF%BC%9A6%20KB%208%20KB%2075.00%25%25%20%E6%9E%84%E5%BB%BA%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E*%20%E7%BB%88%E7%AB%AF%E5%B0%86%E8%A2%AB%E4%BB%BB%E5%8A%A1%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%EF%BC%8C%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%B0%86%E5%85%B6%E5%85%B3%E9%97%AD%E3%80%82%3C%2FP%3E%3CP%3E*%20%E6%AD%A3%E5%9C%A8%E6%89%A7%E8%A1%8C%E4%BB%BB%E5%8A%A1%EF%BC%9ACMake%3A%20%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3E%E5%B7%A5%E4%BD%9C%E7%A9%BA%E9%97%B4%E6%98%AF%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%3CBR%20%2F%3E%E7%89%88%E6%9C%AC%E4%BB%BB%E5%8A%A1%E5%B7%B2%E5%90%AF%E5%8A%A8....%3CBR%20%2F%3E%2FUsers%2Fmelker%2F.mcuxpressotools%2Fcmake-3.30.0-macos10.10-universal%2FCMake.app%2FContents%2Fbin%2Fcmake%20--build%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%20--target%20all%20--%3CBR%20%2F%3E%5B1%2F2%5D%20%E6%9E%84%E5%BB%BA%20C%20%E5%AF%B9%E8%B1%A1%20CMakeFiles%2Ffreertos_message_buffers_primary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Fmain.c.obj%3CBR%20%2F%3E%5B2%2F2%5D%20%E9%93%BE%E6%8E%A5%20C%20%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%20freertos_message_buffers_primary_core.elf%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%E5%A4%A7%E5%B0%8F%E5%8C%BA%E5%9F%9F%E5%A4%A7%E5%B0%8F%20%25age%20%E4%BD%BF%E7%94%A8%E5%B9%B4%E9%99%90%20%3CBR%20%2F%3E%20m_flash_config%EF%BC%9A512%20B%203%20KB%2016.67%25%20m_%20%3CBR%20%2F%3E%20ivt%EF%BC%9A48%20B%204%20KB%201.17%25%20m_interr%20%3CBR%20%2F%3E%20upts%EF%BC%9A1%20KB%201%20KB%20100.00%25%20m_t%20%3CBR%20%2F%3E%20ext%EF%BC%9A72188%20B%2065271%20KB%200.11%25%20m_%20%3CBR%20%2F%3E%20qacode%EF%BC%9A0%20GB%20256%20KB%200.00%25%20m_data%EF%BC%9A0%20GB%20504%20KB%208.76%25%20m_d%20%3CBR%20%2F%3E%20ata2%EF%BC%9A0%20GB%20504%20KB%200.00%25%20rpmsg_sh_mem%EF%BC%9A6%20KB%208%20KB%2075.00%25%20m_core1_image%EF%BC%9A28996%20B%20256%20KB%2011.06%25%20%E7%89%88%E6%9C%AC%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E*%20%E7%BB%88%E7%AB%AF%E5%B0%86%E8%A2%AB%E4%BB%BB%E5%8A%A1%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%EF%BC%8C%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%B0%86%E5%85%B6%E5%85%B3%E9%97%AD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%AF%BC%E8%87%B4%E4%BA%86%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20J-link%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E7%9C%8B%E7%9C%8B%E6%98%AF%E5%90%A6%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251274%22%20target%3D%22_blank%22%3E%40cyberhelmer%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%85%B3%E6%B3%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20MIMXRT%20%E7%B3%BB%E5%88%97%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%93%8D%E4%BD%9C%E5%A4%B1%E8%B4%A5%E7%9A%84%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E6%97%A5%E5%BF%97%E4%B8%AD%E7%BC%BA%E5%B0%91%E4%BA%86%E8%BF%99%E4%B8%80%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EReleasing%20M4%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E8%BF%99%E5%AF%BC%E8%87%B4%E4%BA%86%E5%90%8E%E6%9D%A5%E7%9A%84%E5%A4%B1%E8%B4%A5%E3%80%82%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E6%9B%B4%E6%96%B0%20MCU-Link%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E5%B9%B6%E5%9C%A8%E5%86%8D%E6%AC%A1%E8%B0%83%E8%AF%95%E6%88%96%E7%BC%96%E7%A8%8B%E6%97%B6%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Gavin_Jia_0-1758167694150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Gavin_Jia_0-1758167694150.png%22%20style%3D%22width%3A%20254px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357422iD4D5B078A4526AD1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Gavin_Jia_0-1758167694150.png%22%20alt%3D%22Gavin_Jia_0-1758167694150.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%8F%A6%E4%B8%80%E6%96%B9%E9%9D%A2%EF%BC%8C%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E4%B8%AA%E4%BA%BA%E7%BB%8F%E9%AA%8C%EF%BC%8C%E4%BD%BF%E7%94%A8%20JLink%20%E5%9B%BA%E4%BB%B6%E8%83%BD%E6%8F%90%E4%BE%9B%E6%9B%B4%E5%A5%BD%E7%9A%84%E7%A8%B3%E5%AE%9A%E6%80%A7%E3%80%82%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%EF%BC%8C%E5%B0%9D%E8%AF%95%E7%94%A8%20JLink%20%E5%9B%BA%E4%BB%B6%E6%9B%BF%E6%8D%A2%20MCU-Link%20%E5%9B%BA%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%9C%89%E6%97%B6%E6%88%91%E5%AF%B9%E4%B8%A4%E4%B8%AA%E5%86%85%E6%A0%B8%E9%83%BD%E5%81%9A%E4%BA%86%E6%9B%B4%E6%94%B9%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AF%B9%E4%B8%A4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E8%BF%9B%E8%A1%8C%E6%B8%85%E7%90%86%E5%92%8C%E9%87%8D%E5%BB%BA%E6%97%B6%EF%BC%8C%E5%8F%AA%E6%9C%89%20m7%20%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E4%BB%A3%E7%A0%81%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%9B%B4%E6%96%B0%EF%BC%8Cm4%20%E4%BB%8D%E7%84%B6%E8%BF%90%E8%A1%8C%E6%97%A7%E7%89%88%E6%9C%AC%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
