RT1064 | issues with second stage bootloader
shai_b
Senior Contributor II
Hello team,
My customer has the following issue. please see the details below:
The bug is when I’m trying to enable write to flash using flexspi_nor_write_enable() func from flexspi_nor_flash_ops.c provided by MCUxpresso SDK.
SPI timeout configuration .AHBWriteWaitUnit     = kFLEXSPI_AhbWriteWaitUnit512AhbCycle
Still getting error kStatus_FLEXSPI_DeviceTimeout = 7002.
Could you please advise back?, Thanks in advance
KR,
Shai
jeremyzhou
To provide the fastest possible support, I'd highly recommend you refer to the FOTA solution to implement the SD card OTA.
TIC
