Hi bilge kara,
Please check your MIMXRT1020-EVK board back side, find the SW8, power off the board, then change it to:
SW8_1 OFF
SW8_2 OFF
SW8_3 OFF
SW8_4 ON
Then use the USB cable connect j23, connect the debug button on the MDK, I am using the SDK code:SDK_2.5.0_EVK-MIMXRT1020\boards\evkmimxrt1020\demo_apps\led_blinky\mdk
This is the test result:
You can try it on your side.
If you want to download to the external qspi flash, choose this item:
Then press the LOAD button, after the download is finished, then power off the board, change the SW8 to :
SW8_1 OFF
SW8_2 OFF
SW8_3 ON
SW8_4 OFF
Power on the board again, you will find the on board D5 is blinking, it means it works OK.
Please try it again on your side.
Kerry
