Profinet demo
Profinet demo
wlfworld
I want to develop a profinet device based on RT1180. The PROFINET stack library, Industrial Communication Creator(ICC), ICE and PROFINET Eval Binaries have been downloaded.
There is a user guide for ICE for ICC, but I can't find a user guide for the Profinet stack guide. Is there a project demo in the stack library? Which project shall I put the file 'goal_appl.c‘ and ’goal_config.h‘ which are gererated by ICC?  How to modify the cyclic data of profinet device project?
wlfworld
The UG10361 is the user guide for how to building image with VS Code. The 10320 is the user guide for flashing binaries.
I need the user guide on the profinet stack library. For example, how to set the input data and output data.
ShellyZhang
Dear @wlfworld ,
The PROFINET guidance documents can be found in:
PROFINET-Stack-Library.zip\ProfiNet\Documents
Please pay special attention to the environment and software version requirements specified in the documentation, as the stack depends on specific toolchain and software versions for proper operation.
You can refer to the video tutorial (Building Image on RT1180-EVK using VS Code.mp4) for guidance on building the PROFINET project in VS Code.
Shelly
wlfworld
The UG10361 is the user guide for how to building image with VS Code. The UG_10320 is the user guide for flashing binaries.
I need the user guide on the profinet stack library. For example, how to set the input data and get the output data from Profinet stack.
ShellyZhang
Hi @wlfworld ,
A dedicated user guide for the PROFINET stack library has not been released yet and is currently under development.
If your focus is on the PROFINET API, please refer to the guidance available on the Port website:
Application Programming Interface - PROFINET - Confluence
In addition, ICC can be used to configure and modify application-specific input and output data. Relevant information can be found in the ICC Help pages.
Please let us know if you have any further questions.
Shelly
