POR Reset Trigger Pin
1,465 次查看
fsantiagop
Are there any PIN triggered(as an output) by the POR or COLD Reset process, on the ROM before any firwmare configuration?
Considering the POR_B pin stable in high.
1,417 次查看
Omar_Anguiano
Hello
I hope you are well
Generally PMIC_ON_REQ/STBT_REQ are labeled as output during a reset or during the boot process.
When POR is triggered it returns the pins to the default state, most of them are input.
Omar
