MODEL_RunInference in evkmimxrt1060_tensorflow_lite_kws example
1,986件の閲覧回数
nahan_trogn
I run the evkmimxrt1060_tensorflow_lite_kws example.
After preprocessing audio, I see two function called after that to inference the output: MODEL_RunInference(); and MODEL_ProcessOutput(outputData, &outputDims, outputType, endTime - startTime);
But the example model use the Softmax Regression :
And my model use Logistic Regression:
The question is can I re-use 2 function above for my model? If not, could you suggest me somthing to run inference for my model?
3 返答(返信)
1,969件の閲覧回数
nahan_trogn
I can use those 2 function to predict the output, thanks for your reply.
1,967件の閲覧回数
kerryzhou
Hi nahan_trogn,
   Glad to hear you can reuse it on your side.
  If you still have questions about this case, just kindly let me know.
 Any new issues, welcome to create the new case.
Kerry
1,978件の閲覧回数
kerryzhou
Hi nahan_trogn,
  Do you use the DeepView tool for your related picture?
  About your Logistic Regression. I think you can try to call that 2 function after your model and test it on your side.
  If you meet any issues, just kindly let me know.
Kerry
