MIMXRT1170-EVKB: Continuous Reset in Non-Debug Mode When Using ROMAPI
passman
I am working with the MIMXRT1170-EVKB development board. I cloned a hello_world_cm7 project and integrated the ROM API demo code into it. While debugging, the output shows successful execution, but when running in non-debug mode, the board continuously resets and fails to operate normally. Are any additional modifications required?
Configuration Tool: MCUXpresso Config Tools 25.09
SDK: SDK_25_09_00_MIMXRT1170-EVKB
Keil MDK: 5.43.1.0
Keil MDK Project: flexspi_nor_debug
Habib_MS
Hello @passman,
If you debug an SDK example, such as hello_world_cm7 without modifications, does the same issue occur?
Also, the SDK (version 26.09) provides an example in Keil for using the ROM_API called "fsl_romapi_cm7", which could be helpful.
Additionally, Chapter 10.13, called "ROM APIs", offers detailed information and code examples for its usage.
Habib
%3CLINGO-SUB%20id%3D%22lingo-sub-2264984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMXRT1170-EVKB%3A%20Continuous%20Reset%20in%20Non-Debug%20Mode%20When%20Using%20ROMAPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EHello%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EI%20am%20working%20with%20the%20MIMXRT1170-EVKB%20development%20board.%20I%20cloned%20a%20%3C%2FSPAN%3Ehello_world_cm7%3CSPAN%3E%20project%20and%20integrated%20the%20ROM%20API%20demo%20code%20into%20it.%20While%20debugging%2C%20the%20output%20shows%20successful%20execution%2C%20but%20when%20running%20in%20non-debug%20mode%2C%20the%20board%20continuously%20resets%20and%20fails%20to%20operate%20normally.%20Are%20any%20additional%20modifications%20required%3F%3C%2FSPAN%3E%3C%2FP%3E%3CHR%20%2F%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EConfiguration%20Tool%3A%20MCUXpresso%20Config%20Tools%2025.09%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3ESDK%3A%20SDK_25_09_00_MIMXRT1170-EVKB%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EKeil%20MDK%3A%205.43.1.0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EKeil%20MDK%20Project%3A%20flexspi_nor_debug%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1170-EVKB%3A%20Continuous%20Reset%20in%20Non-Debug%20Mode%20When%20Using%20ROMAPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258131%22%20target%3D%22_blank%22%3E%40passman%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EIf%20you%20debug%20an%20SDK%20example%2C%20such%20as%20hello_world_cm7%20without%20modifications%2C%20does%20the%20same%20issue%20occur%3F%3C%2FP%3E%0A%3CP%3EAlso%2C%20the%20SDK%20(version%2026.09)%20provides%20an%20example%20in%20Keil%20for%20using%20the%20ROM_API%20called%20%22fsl_romapi_cm7%22%2C%20which%20could%20be%20helpful.%3CBR%20%2F%3EAdditionally%2C%20Chapter%2010.13%2C%20called%20%22ROM%20APIs%22%2C%20offers%20detailed%20information%20and%20code%20examples%20for%20its%20usage.%3C%2FP%3E%0A%3CP%3EBR%3CBR%20%2F%3EHabib%3C%2FP%3E%3C%2FLINGO-BODY%3E
