[MIMXRT1040EVK] Help on Routing QTMR inputs through XBARA
ソリューションへジャンプ
1,080件の閲覧回数
vdpsr
Hi everyone,
I’m new to NXP devices (this is my first post), but I have good experience with MCUs. Right now I’m using the MIMXRT1040-EVK board.
My goal is to use the QTMR in quadrature mode to read two incremental rotary encoders at the same time. I’ve read the reference manual, tried many settings, and made some progress — but I’m stuck when using the XBAR INOUT pins.
What works
I can route the encoder signals to the QTMR timer inputs using either direct pins or XBAR IN signals (like XBAR1_IN22, XBAR1_IN23, etc.). The QTMR counts correctly, and UART shows both encoders working.
Here’s the setup in BOARD_InitPins() that works:
CLOCK_EnableClock(kCLOCK_Iomuxc); CLOCK_EnableClock(kCLOCK_Xbar1); IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_10_XBAR1_IN22, 0U); IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_11_XBAR1_IN23, 0U); IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_14_XBAR1_IN24, 0U); IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_15_XBAR1_IN25, 0U); IOMUXC_GPR->GPR6 = ((IOMUXC_GPR->GPR6 & (~(IOMUXC_GPR_GPR6_QTIMER1_TRM0_INPUT_SEL_MASK | IOMUXC_GPR_GPR6_QTIMER1_TRM1_INPUT_SEL_MASK | IOMUXC_GPR_GPR6_QTIMER1_TRM2_INPUT_SEL_MASK | IOMUXC_GPR_GPR6_QTIMER1_TRM3_INPUT_SEL_MASK))) | IOMUXC_GPR_GPR6_QTIMER1_TRM0_INPUT_SEL(0x01U) | IOMUXC_GPR_GPR6_QTIMER1_TRM1_INPUT_SEL(0x01U) | IOMUXC_GPR_GPR6_QTIMER1_TRM2_INPUT_SEL(0x01U) | IOMUXC_GPR_GPR6_QTIMER1_TRM3_INPUT_SEL(0x01U) ); XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarIn25, kXBARA1_OutputQtimer1Tmr0Input); XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarIn24, kXBARA1_OutputQtimer1Tmr1Input); XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarIn23, kXBARA1_OutputQtimer1Tmr2Input); XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarIn22, kXBARA1_OutputQtimer1Tmr3Input);
What doesn’t work
If I try to use XBAR INOUT pins instead, the QTMR doesn’t get valid signals. I see no counts. I think I’m missing a config step for the INOUT function, but I couldn’t find clear info in the docs.
Here’s my INOUT attempt:
CLOCK_EnableClock(kCLOCK_Iomuxc); CLOCK_EnableClock(kCLOCK_Xbar1); IOMUXC_SetPinMux(IOMUXC_GPIO_SD_B0_00_XBAR1_INOUT04, 0U); IOMUXC_SetPinMux(IOMUXC_GPIO_SD_B0_01_XBAR1_INOUT05, 0U); IOMUXC_SetPinMux(IOMUXC_GPIO_SD_B0_02_XBAR1_INOUT06, 0U); IOMUXC_SetPinMux(IOMUXC_GPIO_SD_B0_03_XBAR1_INOUT07, 0U); IOMUXC_SetPinConfig(IOMUXC_GPIO_SD_B0_00_XBAR1_INOUT04, 0x10B0U); // Not sure if needed IOMUXC_SetPinConfig(IOMUXC_GPIO_SD_B0_01_XBAR1_INOUT05, 0x10B0U); // Not sure if needed IOMUXC_SetPinConfig(IOMUXC_GPIO_SD_B0_02_XBAR1_INOUT06, 0x10B0U); // Not sure if needed IOMUXC_SetPinConfig(IOMUXC_GPIO_SD_B0_03_XBAR1_INOUT07, 0x10B0U); // Not sure if needed IOMUXC_GPR->GPR6 = ((IOMUXC_GPR->GPR6 & (~(IOMUXC_GPR_GPR6_QTIMER4_TRM0_INPUT_SEL_MASK | IOMUXC_GPR_GPR6_QTIMER4_TRM1_INPUT_SEL_MASK | IOMUXC_GPR_GPR6_QTIMER4_TRM2_INPUT_SEL_MASK | IOMUXC_GPR_GPR6_QTIMER4_TRM3_INPUT_SEL_MASK | IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_4_MASK | IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_5_MASK | IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_6_MASK | IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_7_MASK))) | IOMUXC_GPR_GPR6_QTIMER4_TRM0_INPUT_SEL(0x01U) | IOMUXC_GPR_GPR6_QTIMER4_TRM1_INPUT_SEL(0x01U) | IOMUXC_GPR_GPR6_QTIMER4_TRM2_INPUT_SEL(0x01U) | IOMUXC_GPR_GPR6_QTIMER4_TRM3_INPUT_SEL(0x01U) | IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_4(0x00U) | IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_5(0x00U) | IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_6(0x00U) | IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_7(0x00U) ); XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarInout05, kXBARA1_OutputQtimer4Tmr0Input); XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarInout06, kXBARA1_OutputQtimer4Tmr1Input); XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarInout07, kXBARA1_OutputQtimer4Tmr2Input); XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarInout04, kXBARA1_OutputQtimer4Tmr3Input);
My questions
  1. Has anyone used XBAR INOUT pins with QTMR in quadrature mode on the mimxrt 1040 evk (or similar i.MX RT boards)?
  2. Is there a setup step I’m missing ?
  3. Are there known limits when using XBAR INOUT for QTMR inputs?
Summary
  • Board: MIMXRT1040-EVK
  • Goal: Read two encoders with one QTMR
  • Works: Routing through XBAR IN
  • Doesn’t work: Routing through XBAR INOUT
Any tips, examples, or references would really help. Thanks!
タグ(3)
1,070件の閲覧回数
vdpsr
Hi !
My bad, I did not see those DNP (not mounted) 0ohms on the MIMXRT1040EVK board !
This subject can be resolved now
My project works now as expected.
Big thanks to NXP support for pointing out this detail !
See you !  
1,071件の閲覧回数
vdpsr
Hi !
See you !  
%3CLINGO-SUB%20id%3D%22lingo-sub-2168674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BMIMXRT1040EVK%5D%20XBARA%E7%B5%8C%E7%94%B1%E3%81%AEQTMR%E5%85%A5%E5%8A%9B%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%98%E3%83%AB%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20NXP%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%99%E3%81%8C%20(%E3%81%93%E3%82%8C%E3%81%8C%E6%9C%80%E5%88%9D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E3%81%99)%E3%80%81MCU%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E8%B1%8A%E5%AF%8C%E3%81%AA%E7%B5%8C%E9%A8%93%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AFMIMXRT1040-EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81QTMR%20%E3%82%92%E7%9B%B4%E4%BA%A4%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%812%20%E3%81%A4%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AA%E3%83%A1%E3%83%B3%E3%82%BF%E3%83%AB%20%E3%83%AD%E3%83%BC%E3%82%BF%E3%83%AA%E3%83%BC%20%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%80%81%E3%81%82%E3%82%8B%E7%A8%8B%E5%BA%A6%E3%81%AE%E9%80%B2%E6%AD%A9%E3%82%92%E9%81%82%E3%81%92%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81XBAR%20INOUT%20%E3%83%94%E3%83%B3%E3%81%AE%E4%BD%BF%E7%94%A8%E6%99%82%E3%81%AB%E8%A1%8C%E3%81%8D%E8%A9%B0%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1974838675%22%20id%3D%22toc-hId-2000457759%22%3E%E4%BD%95%E3%81%8C%E5%8A%B9%E6%9E%9C%E7%9A%84%E3%81%8B%3C%2FH3%3E%3CP%3E%E7%9B%B4%E6%8E%A5%E3%83%94%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%20XBAR%20IN%20%E4%BF%A1%E5%8F%B7%20(XBAR1_IN22%E3%80%81XBAR1_IN23%20%E3%81%AA%E3%81%A9)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E4%BF%A1%E5%8F%B7%E3%82%92%20QTMR%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%85%A5%E5%8A%9B%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0CAN%E3%80%82QTMR%20%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%80%81UART%20%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBOARD_InitPins()%20%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3ECLOCK_EnableClock(kCLOCK_Iomuxc)%3B%20CLOCK_EnableClock(kCLOCK_Xbar1)%3B%20IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_10_XBAR1_IN22%2C%20%3CSPAN%20class%3D%22%22%3E0U%3C%2FSPAN%3E%20)%3B%20IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_11_XBAR1_IN23%2C%20%3CSPAN%20class%3D%22%22%3E0U%3C%2FSPAN%3E%20)%3B%20IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_14_XBAR1_IN24%2C%20%3CSPAN%20class%3D%22%22%3E0U%3C%2FSPAN%3E%20)%3B%20IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_15_XBAR1_IN25%2C%20%3CSPAN%20class%3D%22%22%3E0U%3C%2FSPAN%3E%20)%3B%20IOMUXC_GPR-%26gt%3BGPR6%20%3D%20((IOMUXC_GPR-%26gt%3BGPR6%20%26amp%3B%20(~(IOMUXC_GPR_GPR6_QTIMER1_TRM0_INPUT_SEL_MASK%20%7C%20IOMUXC_GPR_GPR6_QTIMER1_TRM1_INPUT_SEL_MASK%20%7C%20IOMUXC_GPR_GPR6_QTIMER1_TRM2_INPUT_SEL_MASK%20%7C%20IOMUXC_GPR_GPR6_QTIMER1_TRM3_INPUT_SEL_MASK)))%20%7C%20IOMUXC_GPR_GPR6_QTIMER1_TRM0_INPUT_SEL(%20%3CSPAN%20class%3D%22%22%3E0x01%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_QTIMER1_TRM1_INPUT_SEL(%20%3CSPAN%20class%3D%22%22%3E0x01%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_QTIMER1_TRM2_INPUT_SEL(%20%3CSPAN%20class%3D%22%22%3E0x01%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_QTIMER1_TRM3_INPUT_SEL(%20%3CSPAN%20class%3D%22%22%3E0x01%3C%2FSPAN%3E%20U)%20)%3B%20XBARA_SetSignalsConnection(XBARA1%E3%80%81kXBARA1_InputIomuxXbarIn25%E3%80%81kXBARA1_OutputQtimer1Tmr0Input)%3B%20XBARA_SetSignalsConnection(XBARA1%E3%80%81kXBARA1_InputIomuxXbarIn24%E3%80%81kXBARA1_OutputQtimer1Tmr1Input)%3B%20XBARA_SetSignalsConnection(XBARA1%E3%80%81kXBARA1_InputIomuxXbarIn23%E3%80%81kXBARA1_OutputQtimer1Tmr2Input)%3B%20XBARA_SetSignalsConnection(XBARA1%E3%80%81kXBARA1_InputIomuxXbarIn22%E3%80%81kXBARA1_OutputQtimer1Tmr3Input)%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CH3%20id%3D%22toc-hId-167384212%22%20id%3D%22toc-hId-193003296%22%3E%E4%BD%95%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%3C%2FH3%3E%3CP%3E%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20XBAR%20INOUT%20%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81QTMR%20%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AA%E4%BF%A1%E5%8F%B7%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AF%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82INOUT%20%E9%96%A2%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%89%8B%E9%A0%86%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E6%98%8E%E7%A2%BA%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AEINOUT%E3%81%AE%E8%A9%A6%E3%81%BF%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3ECLOCK_EnableClock(kCLOCK_Iomuxc)%3B%20CLOCK_EnableClock(kCLOCK_Xbar1)%3B%20IOMUXC_SetPinMux(IOMUXC_GPIO_SD_B0_00_XBAR1_INOUT04%2C%20%3CSPAN%20class%3D%22%22%3E0U%3C%2FSPAN%3E%20)%3B%20IOMUXC_SetPinMux(IOMUXC_GPIO_SD_B0_01_XBAR1_INOUT05%2C%20%3CSPAN%20class%3D%22%22%3E0U%3C%2FSPAN%3E%20)%3B%20IOMUXC_SetPinMux(IOMUXC_GPIO_SD_B0_02_XBAR1_INOUT06%2C%20%3CSPAN%20class%3D%22%22%3E0U%3C%2FSPAN%3E%20)%3B%20IOMUXC_SetPinMux(IOMUXC_GPIO_SD_B0_03_XBAR1_INOUT07%2C%20%3CSPAN%20class%3D%22%22%3E0U%3C%2FSPAN%3E%20)%3B%20IOMUXC_SetPinConfig(IOMUXC_GPIO_SD_B0_00_XBAR1_INOUT04%2C%20%3CSPAN%20class%3D%22%22%3E0x10B0%3C%2FSPAN%3E%20U)%3B%20%3CSPAN%20class%3D%22%22%3E%2F%2F%20%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3EIOMUXC_SetPinConfig(IOMUXC_GPIO_SD_B0_01_XBAR1_INOUT05%2C%20%3CSPAN%20class%3D%22%22%3E0x10B0%3C%2FSPAN%3E%20U)%3B%20%3CSPAN%20class%3D%22%22%3E%2F%2F%20%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3EIOMUXC_SetPinConfig(IOMUXC_GPIO_SD_B0_02_XBAR1_INOUT06%2C%20%3CSPAN%20class%3D%22%22%3E0x10B0%3C%2FSPAN%3E%20U)%3B%20%3CSPAN%20class%3D%22%22%3E%2F%2F%20%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3EIOMUXC_SetPinConfig(IOMUXC_GPIO_SD_B0_03_XBAR1_INOUT07%2C%20%3CSPAN%20class%3D%22%22%3E0x10B0%3C%2FSPAN%3E%20U)%3B%20%3CSPAN%20class%3D%22%22%3E%2F%2F%20%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E4%B8%8D%E6%98%8E%3C%2FSPAN%3EIOMUXC_GPR-%26gt%3BGPR6%20%3D%20((IOMUXC_GPR-%26gt%3BGPR6%20%26amp%3B%20(~(IOMUXC_GPR_GPR6_QTIMER4_TRM0_INPUT_SEL_MASK%20%7C%20IOMUXC_GPR_GPR6_QTIMER4_TRM1_INPUT_SEL_MASK%20%7C%20IOMUXC_GPR_GPR6_QTIMER4_TRM2_INPUT_SEL_MASK%20%7C%20IOMUXC_GPR_GPR6_QTIMER4_TRM3_INPUT_SEL_MASK%20%7C%20IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_4_MASK%20%7C%20IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_5_MASK%20%7C%20IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_6_MASK%20%7C%20IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_7_MASK)))%20%7C%20IOMUXC_GPR_GPR6_QTIMER4_TRM0_INPUT_SEL(%20%3CSPAN%20class%3D%22%22%3E0x01%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_QTIMER4_TRM1_INPUT_SEL(%20%3CSPAN%20class%3D%22%22%3E0x01%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_QTIMER4_TRM2_INPUT_SEL(%20%3CSPAN%20class%3D%22%22%3E0x01%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_QTIMER4_TRM3_INPUT_SEL(%20%3CSPAN%20class%3D%22%22%3E0x01%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_4(%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_5(%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_6(%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%20U)%20%7C%20IOMUXC_GPR_GPR6_IOMUXC_XBAR_DIR_SEL_7(%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%20U)%20)%3B%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputIomuxXbarInout05%2C%20kXBARA1_OutputQtimer4Tmr0Input)%3B%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputIomuxXbarInout06%2C%20kXBARA1_OutputQtimer4Tmr1Input)%3B%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputIomuxXbarInout07%2C%20kXBARA1_OutputQtimer4Tmr2Input)%3B%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputIomuxXbarInout04%2C%20kXBARA1_OutputQtimer4Tmr3Input)%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20translate%3D%22no%22%3E%26nbsp%3B%3C%2FPRE%3E%3CH3%20id%3D%22toc-hId--1640070251%22%20id%3D%22toc-hId--1614451167%22%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3Emimxrt%201040%20evk%20(%E3%81%BE%E3%81%9F%E3%81%AF%E5%90%8C%E6%A7%98%E3%81%AE%20i.MX%20RT%20%E3%83%9C%E3%83%BC%E3%83%89)%20%E3%81%A7%E3%80%81%E7%9B%B4%E4%BA%A4%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%20QTMR%20%E3%81%A7%20XBAR%20INOUT%20%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E6%89%8B%E9%A0%86%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EQTMR%20%E5%85%A5%E5%8A%9B%E3%81%AB%20XBAR%20INOUT%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E6%97%A2%E7%9F%A5%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId-847442582%22%20id%3D%22toc-hId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id%3D%22lingo-sub-2170476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BMIMXRT1040EVK%5D%20Help%20on%20Routing%20QTMR%20inputs%20through%20XBARA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81MIMXRT1040EVK%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%20DNP%20(%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84)%200ohm%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BB%8A%E8%A7%A3%E6%B1%BACAN%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Capture%20d%E2%80%99%C3%A9cran%202025-09-16%20151556.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture%20d%E2%80%99%C3%A9cran%202025-09-16%20151556.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357151i10D3308A462EDCAF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Capture%20d%E2%80%99%C3%A9cran%202025-09-16%20151556.png%22%20alt%3D%22Capture%20d%E2%80%99%C3%A9cran%202025-09-16%20151556.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECapture%20d%E2%80%99%C3%A9cran%202025-09-16%20151556.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E6%9C%9F%E5%BE%85%E9%80%9A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E6%8C%87%E6%91%98%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%A3%E3%81%9F%20NXP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%A4%A7%E3%81%84%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%81%AD%20%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
