MCUBoot and Multi-core application
1,315 次查看
silvio-vallorani
Good morning,
I am trying to start the dualcore hello world sample from slot0 using MCUBoot as the bootloader.
I have already change flash section to fit slot0
I use SPT to sign the dual core image with the mcuboot used key and the image aumatically fit on slot0 (as Additional Image), I select mcuboot to be the executable, generate the image and write on the device.
Mcuboot starts and correctly load the slot0 image, but the application crash immedately.
I can attach with J-Link using attach only option from the multicore primary project/image, pause the execution and analyze what's wrong...
I notice that an hardfault arise dung Reset handler routine, exactly when the primary core try to copy from flash to ITC-M7 ram via alias address start from 0x203c0000.
I also have confirmed filtering the copy on 0x203c0000 based and then the application go ahead, but obviously crash when che CM7 should start (doesn't have it's firmware).
ATM, I think that MCUBoot set some kind of memory protection... can you help me to find when the block is and how to remove it?
I can share all, but I use SDK25.06 and default mcuboot, hello_world_primary, hello_world_secondary projects from the example.
The only change I have done is on hello world primary and secondary projects memory map to fit SLOT0.
Thank you very much for your assistance!
1,249 次查看
Gavin_Jia
Hi @silvio-vallorani ,
Thanks for your interest in NXP MIMXRT series!
The RT1180's CM7 core requires a CM33 to kick off. Could this be causing issues with your application? If so, `multicore_trigger_cm33` example project in the SDK may help.
Gavin
1,268 次查看
silvio-vallorani
I think I have found a solution.
It's on the GitHub project under 99_working_solution branch: https://github.com/amm-svallorani/mimxrt1189-mcuboot-multicore-template/tree/99_working_solution
Anyway I really appreciate if someone could review the solution and explain a bit more the thinghs around the topic.
Thank you very much!
1,279 次查看
silvio-vallorani
I have published the demo template on github: https://github.com/amm-svallorani/mimxrt1189-mcuboot-multicore-template
The main branch is the starting point of the application that works, but crash during the load of CM7 data from flash to alias addresses.
In the other branchs I push my tries.
Help me figuring out the problem, please
%3CLINGO-SUB%20id%3D%22lingo-sub-2184769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUBoot%20%E5%92%8C%E5%A4%9A%E6%A0%B8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%97%A9%E4%B8%8A%E5%A5%BD%E3%80%81%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%E4%BD%BF%E7%94%A8%20MCUBoot%20%E4%BD%9C%E4%B8%BA%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BB%8E%20slot0%20%E5%90%AF%E5%8A%A8%E5%8F%8C%E6%A0%B8%20hello%20world%20%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9B%B4%E6%94%B9%E4%BA%86%E9%97%AA%E5%AD%98%E9%83%A8%E5%88%86%EF%BC%8C%E4%BB%A5%E9%80%82%E5%BA%94%E6%8F%92%E6%A7%BD%200%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8SPT%E4%BD%BF%E7%94%A8mcuboot%E4%BD%BF%E7%94%A8%E7%9A%84%E5%AF%86%E9%92%A5%E5%AF%B9%E5%8F%8C%E6%A0%B8%E6%98%A0%E5%83%8F%E8%BF%9B%E8%A1%8C%E7%AD%BE%E5%90%8D%EF%BC%8C%E5%9B%BE%E5%83%8F%E5%B0%86%E8%87%AA%E5%8A%A8%E6%94%BE%E7%BD%AE%E5%9C%A8slot0%E4%B8%8A%EF%BC%88%E4%BD%9C%E4%B8%BA%E9%99%84%E5%8A%A0%E6%98%A0%E5%83%8F%EF%BC%89%EF%BC%8C%E6%88%91%E9%80%89%E6%8B%A9mcuboot%E4%BD%9C%E4%B8%BA%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%EF%BC%8C%E7%94%9F%E6%88%90%E9%95%9C%E5%83%8F%E5%B9%B6%E5%9C%A8%E8%AE%BE%E5%A4%87%E4%B8%8A%E5%86%99%E5%85%A5%E3%80%82%3C%2FP%3E%3CP%3EMcuboot%20%E5%90%AF%E5%8A%A8%E5%B9%B6%E6%AD%A3%E7%A1%AE%E5%8A%A0%E8%BD%BD%20slot0%20%E6%98%A0%E5%83%8F%EF%BC%8C%E4%BD%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%AB%8B%E5%8D%B3%E5%B4%A9%E6%BA%83%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%A4%9A%E6%A0%B8%E4%B8%BB%E9%A1%B9%E7%9B%AE%2F%E6%98%A0%E5%83%8F%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BB%85%E9%99%84%E5%8A%A0%E9%80%89%E9%A1%B9%E9%80%9A%E8%BF%87%20J-Link%20%E9%99%84%E5%8A%A0%EF%BC%8C%E6%9A%82%E5%81%9C%E6%89%A7%E8%A1%8C%E5%B9%B6%E5%88%86%E6%9E%90%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8...%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%BD%93%E4%B8%BB%E5%86%85%E6%A0%B8%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%E5%88%AB%E5%90%8D%E5%9C%B0%E5%9D%80%E4%BB%8E%200x203c0000%20%E5%BC%80%E5%A7%8B%E4%BB%8E%E9%97%AA%E5%AD%98%E5%A4%8D%E5%88%B6%E5%88%B0%20ITC-M7%20%E5%86%85%E5%AD%98%E6%97%B6%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%8C%E8%BF%99%E6%AD%A3%E6%98%AF%E5%9C%A8%20RESET%20%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E4%BE%8B%E7%A8%8B%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E8%BF%98%E7%A1%AE%E8%AE%A4%E5%9C%A8%E5%9F%BA%E4%BA%8E%200x203c0000%20%E7%9A%84%E5%9F%BA%E7%A1%80%E4%B8%8A%E7%AD%9B%E9%80%89%E5%89%AF%E6%9C%AC%E7%84%B6%E5%90%8E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%BB%A7%E7%BB%AD%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%20che%20CM7%20%E5%BA%94%E8%AF%A5%E5%90%AF%E5%8A%A8%EF%BC%88%E6%B2%A1%E6%9C%89%E5%9B%BA%E4%BB%B6%EF%BC%89%E6%97%B6%EF%BC%8C%E6%98%BE%E7%84%B6%E4%BC%9A%E5%B4%A9%E6%BA%83%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EATM%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%20McuBoot%20%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%9F%90%E7%A7%8D%E5%86%85%E5%AD%98%E4%BF%9D%E6%8A%A4...%20%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E6%89%BE%E5%87%BA%E5%8C%BA%E5%9D%97%E6%98%AF%E4%BB%80%E4%B9%88%E6%97%B6%E5%80%99%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E5%88%A0%E9%99%A4%E5%AE%83%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%85%A8%E9%83%A8%E5%85%B1%E4%BA%AB%EF%BC%8C%E4%BD%86%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20SDK25.06%20%E5%92%8C%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%E9%BB%98%E8%AE%A4%20mcuboot%E3%80%81hello_world_primary%E3%80%81hello_world_secondary%20%E9%A1%B9%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%89%80%E5%81%9A%E7%9A%84%E5%94%AF%E4%B8%80%E6%9B%B4%E6%94%B9%E6%98%AF%E5%9C%A8%20Hello%20World%20%E4%B8%BB%E8%A6%81%E5%92%8C%E6%AC%A1%E8%A6%81%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%E4%B8%8A%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%95%B4%EF%BC%8C%E4%BB%A5%E9%80%82%E5%90%88%20SLOT0%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUBoot%20and%20Multi-core%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252871%22%20target%3D%22_blank%22%3E%40silvio-vallorani%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%20NXP%20MIMXRT%20%E7%B3%BB%E5%88%97%E7%9A%84%E5%85%B3%E6%B3%A8%EF%BC%81%3C%2FP%3E%0A%3CP%3ERT1180%20%E7%9A%84%20CM7%20%E5%86%85%E6%A0%B8%E9%9C%80%E8%A6%81%20CM33%20%E6%89%8D%E8%83%BD%E5%90%AF%E5%8A%A8%E3%80%82%E8%BF%99%E6%98%AF%E5%90%A6%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8CSDK%20%E4%B8%AD%E7%9A%84%20%60multicore_trigger_cm33%60%20%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUBoot%20and%20Multi-core%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E6%88%91%E5%B7%B2%E7%BB%8F%E6%89%BE%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E3%80%82%3CBR%20%2F%3E%E5%AE%83%E4%BD%8D%E4%BA%8E%20GitHub%20%E9%A1%B9%E7%9B%AE%E7%9A%84%2099_working_solution%20%E5%88%86%E6%94%AF%E4%B8%8B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Famm-svallorani%2Fmimxrt1189-mcuboot-multicore-template%2Ftree%2F99_working_solution%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fgithub.com%2Famm-svallorani%2Fmimxrt1189-mcuboot-multicore-template%2Ftree%2F99_working_solution%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E6%88%91%E7%9C%9F%E7%9A%84%E5%BE%88%E5%B8%8C%E6%9C%9B%E6%9C%89%E4%BA%BA%E8%83%BD%E5%AE%A1%E6%9F%A5%E4%B8%80%E4%B8%8B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E5%B9%B6%E5%B0%B1%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%A4%9A%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUBoot%20and%20Multi-core%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E5%9C%A8%20github%20%E4%B8%8A%E5%8F%91%E5%B8%83%E4%BA%86%E6%BC%94%E7%A4%BA%E6%A8%A1%E6%9D%BF%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Famm-svallorani%2Fmimxrt1189-mcuboot-multicore-template%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9Ahttps%3A%2F%2Fgithub.com%2Famm-svallorani%2Fmimxrt1189-mcuboot-multicore-template%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%B8%BB%E5%88%86%E6%94%AF%E6%98%AF%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E8%B5%B7%E7%82%B9%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%B0%86%20CM7%20%E6%95%B0%E6%8D%AE%E4%BB%8E%E9%97%AA%E5%AD%98%E5%8A%A0%E8%BD%BD%E5%88%B0%E5%88%AB%E5%90%8D%E5%9C%B0%E5%9D%80%E6%97%B6%E4%BC%9A%E5%B4%A9%E6%BA%83%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%85%B6%E4%BB%96%E5%88%86%E6%94%AF%E4%B8%AD%EF%BC%8C%E6%88%91%E6%8E%A8%E9%80%81%E6%88%91%E7%9A%84%E5%B0%9D%E8%AF%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E6%88%91%E6%89%BE%E5%87%BA%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E
